[Swift-commit] r6386 - branches/release-0.94/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sun Mar 17 02:48:18 CDT 2013
Author: hategan
Date: 2013-03-17 02:47:59 -0500 (Sun, 17 Mar 2013)
New Revision: 6386
Modified:
   branches/release-0.94/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
Log:
fixed extra call to decRefs when self closing is enabled (bug 955)
Modified: branches/release-0.94/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
--- branches/release-0.94/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	2013-03-16 22:48:10 UTC (rev 6385)
+++ branches/release-0.94/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	2013-03-17 07:47:59 UTC (rev 6386)
@@ -119,17 +119,36 @@
 			    startIteration(tc, var, i.current(), tc.tryIncrement(), stack);
-			decRefs(tc.rc);
+			if (!tc.selfClose) {
+			    decRefs(tc.rc);
 			int left;
 			synchronized(tc) {
-			    // can only have closed and running = 0 in one place
+			    // can only have closed and running = 0 in one of the two critical sections
+			    // related to tc. One (CS1) is this and the other one (CS2) is:
+			    // closed = tc.isClosed();
+			    // running = tc.decrement();
+			    // If on the last iteration CS1 runs before CS2, then:
+			    // CS1 - (closed = true, left > 0), CS2 - (closed = true, --running == 0)
+			    // If CS2 runs before CS1:
+			    // CS2 - (closed = false, --running == 0), CS1 - (closed = true, left == 0).
 			    tc.close();
 			    left = tc.current();
 			if (left == 0) {
-				complete(stack);
+			    // i.e., no iteration running
+			        // when selfClose is on, decRefs() and complete() are called
+			        // as part of the self closing logic, so don't invoke them again
+			        complete(stack);
+			else {
+			    // complete() will be called when
+			    // the last iteration completes (in iterationCompleted).
 		catch (FutureIteratorIncomplete fii) {
 			synchronized (stack.currentFrame()) {
@@ -231,9 +250,11 @@
 		boolean done = false;
 		if (running == 0) {
 		    if (closed) {
+		        // write refs were decremented when the last
+		        // iteration was started
 		        complete(stack);
-		    if (tc.selfClose && !iteratorHasValues) {
+		    else if (tc.selfClose && !iteratorHasValues) {
 		        decRefs(tc.rc);
 		        complete(stack);
