[Swift-commit] r6349 - branches/release-0.94/src/org/griphyn/vdl/engine
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Mar 8 12:48:03 CST 2013
Author: hategan
Date: 2013-03-08 12:48:02 -0600 (Fri, 08 Mar 2013)
New Revision: 6349
Modified:
   branches/release-0.94/src/org/griphyn/vdl/engine/VariableScope.java
Log:
properly handle inhibitClosing in else branch if a close was added to match what is in the then branch
Modified: branches/release-0.94/src/org/griphyn/vdl/engine/VariableScope.java
--- branches/release-0.94/src/org/griphyn/vdl/engine/VariableScope.java	2013-03-08 07:01:03 UTC (rev 6348)
+++ branches/release-0.94/src/org/griphyn/vdl/engine/VariableScope.java	2013-03-08 18:48:02 UTC (rev 6349)
@@ -308,6 +308,9 @@
 	        inhibitClosing = new HashSet<String>();
 		inhibitClosing.add(name);
+		if (thenScope != null) {
+		    setPreClose(name, 0);
 	public void addVariable(String name, String type, String context, boolean global, XmlObject src) throws CompilationException {
@@ -650,7 +653,7 @@
 	private void setPreClose(String name, int count) {
-	    if (inhibitClosing != null && inhibitClosing.contains(name)) {
+	    if (inhibitClosing != null && inhibitClosing.contains(name) && count != 0) {
 	        return;
 	    setCount("preClose", name, count,
