[Swift-commit] r6348 - trunk/docs/userguide
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Fri Mar 8 01:01:04 CST 2013
Author: ketan
Date: 2013-03-08 01:01:03 -0600 (Fri, 08 Mar 2013)
New Revision: 6348
Modified:
   trunk/docs/userguide/mappers
Log:
fixing the example on regexp and struct regexp mappers
Modified: trunk/docs/userguide/mappers
--- trunk/docs/userguide/mappers	2013-03-08 05:23:36 UTC (rev 6347)
+++ trunk/docs/userguide/mappers	2013-03-08 07:01:03 UTC (rev 6348)
@@ -631,14 +631,12 @@
 Example:
-string s = "picture.gif";
-file f <regexp_mapper;
-  source=s,
-  match="(.*)gif",
-  transform="\\1jpg">;
+file s <"picture.gif">;
+file f <regexp_mapper; source=s,
+  match="(.*)gif", transform="\\1jpg">;
-This example transforms a string ending gif into one ending jpg and
+This example transforms a file ending gif into one ending jpg and
 maps that to a file.
 [options="header, autowidth"]
@@ -649,9 +647,10 @@
 structured regular expression mapper
-The structured_regexp_mapper is similar to the regexp_mapper. The
-structured_regexp_mapper can be applied to lists while the regexp_mapper cannot.
+The structured_regexp_mapper is similar to the regexp_mapper with the only
+difference that it can be applied to arrays while the regexp_mapper cannot.
 |parameter|meaning
@@ -667,14 +666,13 @@
 Example:
-string s[] = ["picture.gif", "hello.gif", "world.gif"];
-file f[] <structured_regexp_mapper;
-          source=s,
-          match="(.*)gif",
+file s[] <filesys_mapper; pattern="*.gif">;
+file f[] <structured_regexp_mapper; source=s,
-This example transforms all strings in a list that end in gif to end in jpg and maps
+This example transforms all files in a list that end in gif to end in jpg and maps
 the list to those files.
 csv mapper
