[Swift-commit] r6334 -	branches/faster/src/org/griphyn/vdl/karajan/lib
    hategan at ci.uchicago.edu
    Wed Mar  6 01:23:15 CST 2013
Author: hategan
Date: 2013-03-06 01:23:14 -0600 (Wed, 06 Mar 2013)
New Revision: 6334
Modified:
   branches/faster/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java
Log:
avoid creating arrays when not necessary
Modified: branches/faster/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java
--- branches/faster/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java	2013-03-06 07:22:47 UTC (rev 6333)
+++ branches/faster/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java	2013-03-06 07:23:14 UTC (rev 6334)
@@ -24,6 +24,7 @@
 import java.util.TreeMap;
 import k.rt.Channel;
+import k.rt.ExecutionException;
 import k.rt.Stack;
 import org.apache.log4j.Logger;
@@ -44,40 +45,60 @@
 	public Object function(Stack stack) {
-		ArrayList<DSHandle> l = new ArrayList<DSHandle>();
-		Channel<Object> items = c_vargs.get(stack);
-		for (Object item : items) {
-			if(!(item instanceof DSHandle)) {
-				throw new RuntimeException("Cannot handle argument implemented by " + item.getClass());
-			if (item instanceof ArrayDataNode) {
-				ArrayDataNode array = (ArrayDataNode) item;
-				Map<Comparable<?>, DSHandle> m = array.getArrayValue();
-				SortedMap<Comparable<?>, DSHandle> sorted = new TreeMap<Comparable<?>, DSHandle>(new PathElementComparator());
-				sorted.putAll(m);
-				l.addAll(m.values());
-			else {
-			    l.add((DSHandle) item);
-			// TODO this does not correctly handle structs or
-			// externals - at the moment, probably neither of
-			// those should be usable as a string. It also
-			// does not handle nested arrays. However, none of
-			// those should get here in normal operation due
-			// to static type-checking
-		return l;
+	    Channel<Object> items = c_vargs.get(stack);
+	    // prefer lower memory usage over speed here
+	    // although the penalty is only there if there are arrays in the arguments
+	    if (hasArrays(items)) {
+	        return expandArrays(items);
+	    else {
+	        return items.getAll();
-	class StringsAsIntegersComparator implements Comparator<Object> {
+	private Object expandArrays(Channel<Object> items) {
+        ArrayList<DSHandle> l = new ArrayList<DSHandle>();
+        for (Object item : items) {
+            if (item instanceof ArrayDataNode) {
+                ArrayDataNode array = (ArrayDataNode) item;
+                Map<Comparable<?>, DSHandle> m = array.getArrayValue();
+                SortedMap<Comparable<?>, DSHandle> sorted = new TreeMap<Comparable<?>, DSHandle>(new PathElementComparator());
+                sorted.putAll(m);
+                l.addAll(m.values());
+            else {
+                l.add((DSHandle) item);
+            // TODO this does not correctly handle structs or
+            // externals - at the moment, probably neither of
+            // those should be usable as a string. It also
+            // does not handle nested arrays. However, none of
+            // those should get here in normal operation due
+            // to static type-checking
+        return l;
+    private boolean hasArrays(Channel<Object> items) {
+	    boolean arraySeen = false;
+            if(!(item instanceof DSHandle)) {
+                throw new ExecutionException(this, "Cannot handle argument implemented by " + item.getClass());
+                arraySeen = true;
+        return arraySeen;
+    class StringsAsIntegersComparator implements Comparator<Object> {
 		public int compare(Object l, Object r) {
 			Integer lnum = new Integer((String)l);
 			Integer rnum = new Integer((String)r);
 			return lnum.compareTo(rnum);
More information about the Swift-commit
