[Swift-commit] r6333 - branches/faster/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Wed Mar 6 01:22:48 CST 2013
Author: hategan
Date: 2013-03-06 01:22:47 -0600 (Wed, 06 Mar 2013)
New Revision: 6333
Modified:
   branches/faster/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java
Log:
faster runtime stats
Modified: branches/faster/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java
--- branches/faster/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java	2013-03-06 04:25:34 UTC (rev 6332)
+++ branches/faster/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java	2013-03-06 07:22:47 UTC (rev 6333)
@@ -159,6 +159,33 @@
+	private static class MutableInt {
+	    private int value;
+	    public MutableInt() {
+	        value = 0;
+	    public MutableInt(int value) {
+	        this.value = value;
+	    public int getValue() {
+	        return value;
+	    public void setValue(int value) {
+	    public void inc() {
+	        value++;
+	    public String toString() {
+	        return String.valueOf(value);
 	public static class StopProgressTicker extends Node {
         private VarRef<Context> context;
@@ -265,13 +292,13 @@
 			printStates("Final status:");
-		private Map<String, Integer> getSummary() {
+		private Map<String, MutableInt> getSummary() {
 			List<ProgressState> states;
 			synchronized(this.states) {
 				states = new ArrayList<ProgressState>(this.states);
-		    Map<String, Integer> m = new HashMap<String, Integer>();
+		    Map<String, MutableInt> m = new HashMap<String, MutableInt>();
 	        for (ProgressState s : states) {
 	            inc(m, s);
@@ -279,20 +306,19 @@
 		    return m;
-		private void inc(Map<String, Integer> m, ProgressState s) {
+		private void inc(Map<String, MutableInt> m, ProgressState s) {
 		    String v = s.crt;
-		    Integer i = m.get(v);
+		    MutableInt i = m.get(v);
 		    if (i == null) {
-		        i = 1;
+		        i = new MutableInt();
+		        m.put(v, i);
-		    else {
-		        i = i + 1;
-		    m.put(v, i);
+		    i.inc();
         synchronized void printStates(String prefix) {
-			Map<String, Integer> summary = getSummary();
+			Map<String, MutableInt> summary = getSummary();
 			StringBuilder sb = new StringBuilder();
@@ -305,7 +331,7 @@
 			for (int pos = 0; pos < preferredOutputOrder.length; pos++) {
 				String key = preferredOutputOrder[pos];
-				Integer value = summary.get(key);
+				MutableInt value = summary.get(key);
 				if(value != null) {
 				    sb.append("  ");
 				    sb.append(key);
@@ -315,7 +341,7 @@
 				summary.remove(key);
-			for (Map.Entry<String, Integer> s : summary.entrySet()) {
+			for (Map.Entry<String, MutableInt> s : summary.entrySet()) {
 			    sb.append("  ");
 			    sb.append(s.getKey());
 			    sb.append(":");
