[Swift-commit] r6553 - SwiftTutorials/OHBM_2013-06-16
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Fri Jun 14 16:19:58 CDT 2013
Author: wilde
Date: 2013-06-14 16:19:57 -0500 (Fri, 14 Jun 2013)
New Revision: 6553
Modified:
   SwiftTutorials/OHBM_2013-06-16/README
   SwiftTutorials/OHBM_2013-06-16/apps
   SwiftTutorials/OHBM_2013-06-16/apps.beagle
   SwiftTutorials/OHBM_2013-06-16/apps.midway
   SwiftTutorials/OHBM_2013-06-16/genatlas.swift
   SwiftTutorials/OHBM_2013-06-16/sites.xml
   SwiftTutorials/OHBM_2013-06-16/swift.properties
Log:
updates for swift version of align() function. Older function is now align_sh().
Modified: SwiftTutorials/OHBM_2013-06-16/README
--- SwiftTutorials/OHBM_2013-06-16/README	2013-06-14 17:13:55 UTC (rev 6552)
+++ SwiftTutorials/OHBM_2013-06-16/README	2013-06-14 21:19:57 UTC (rev 6553)
@@ -48,13 +48,13 @@
   swift genatlas.swift             # processes data/ directory by default
   swift genatlas.swift -d=data_100 # process data_100/ directory
-  # With most parallel work on midway westmere parition:
+  # With most parallel work on a midway parition (edit sites.xml to set partition)
   swift -tc.file apps.midway genatlas.swift
   # From midway to beagle using provider staging:
-   swift -config swift.properties.ps -tc.file apps.beagle genatlas.swift -d=data_100
+  swift -config swift.properties.ps -tc.file apps.beagle genatlas.swift -d=data_100
   # Choices for -tc.file are:
@@ -62,7 +62,7 @@
   apps.beagle  # on beagle, 8 nodes
   apps.midway  # on midway westmere, 1 node
   apps.amazon  # on Amazon EC2 - needs start-coaster-service, see below
-  apps.UC3     # submits to UC3, needs apps to be sent.
+  apps.beagle+midway # both of these
 The output files of the workflow are placed under output/,
 intermediate files under work/.
@@ -79,5 +79,5 @@
   The "aligin" initial stage runs 3 AIR tools under as a single shell
   script, to reduce staging between these steps.
+  A swift version of this function is included as well
Modified: SwiftTutorials/OHBM_2013-06-16/apps
--- SwiftTutorials/OHBM_2013-06-16/apps	2013-06-14 17:13:55 UTC (rev 6552)
+++ SwiftTutorials/OHBM_2013-06-16/apps	2013-06-14 21:19:57 UTC (rev 6553)
@@ -1,5 +1,9 @@
-localhost sh       /bin/sh null null env::AIR5=/home/wilde/software/AIR5.3.0
-#localhost sh       /bin/sh
-localhost softmean /home/wilde/software/AIR5.3.0/bin/softmean
-localhost slicer   /project/wilde/software/fsl-5.0.4/fsl/bin/slicer null null env::FSLOUTPUTTYPE=NIFTI
-localhost convert  convert
+midway sh          /bin/sh null null env::AIR5=/home/wilde/software/AIR5.3.0
+#localhost sh         /bin/sh
+localhost softmean    /home/wilde/software/AIR5.3.0/bin/softmean
+localhost alignlinear /home/wilde/software/AIR5.3.0/bin/alignlinear
+localhost align_warp  /home/wilde/software/AIR5.3.0/bin/align_warp
+localhost slicer      /project/wilde/software/fsl-5.0.4/fsl/bin/slicer null null env::FSLOUTPUTTYPE=NIFTI
+localhost convert     convert
Modified: SwiftTutorials/OHBM_2013-06-16/apps.beagle
--- SwiftTutorials/OHBM_2013-06-16/apps.beagle	2013-06-14 17:13:55 UTC (rev 6552)
+++ SwiftTutorials/OHBM_2013-06-16/apps.beagle	2013-06-14 21:19:57 UTC (rev 6553)
@@ -1,4 +1,8 @@
-beagle    sh       /bin/sh null null env::AIR5=/lustre/beagle/wilde/software/AIR5.3.0
+beagle    sh          /bin/sh null null env::AIR5=/lustre/beagle/wilde/software/AIR5.3.0
+beagle    alignlinear /lustre/beagle/wilde/software/AIR5.3.0/bin/alignlinear
+beagle    align_warp  /lustre/beagle/wilde/software/AIR5.3.0/bin/align_warp
+beagle    reslice     /lustre/beagle/wilde/software/AIR5.3.0/bin/reslice
Modified: SwiftTutorials/OHBM_2013-06-16/apps.midway
--- SwiftTutorials/OHBM_2013-06-16/apps.midway	2013-06-14 17:13:55 UTC (rev 6552)
+++ SwiftTutorials/OHBM_2013-06-16/apps.midway	2013-06-14 21:19:57 UTC (rev 6553)
@@ -1,4 +1,11 @@
-westmere  sh       /bin/sh
+midway    alignlinear /home/wilde/software/AIR5.3.0/bin/alignlinear
+midway    align_warp  /home/wilde/software/AIR5.3.0/bin/align_warp
+midway    reslice     /home/wilde/software/AIR5.3.0/bin/reslice
Modified: SwiftTutorials/OHBM_2013-06-16/genatlas.swift
--- SwiftTutorials/OHBM_2013-06-16/genatlas.swift	2013-06-14 17:13:55 UTC (rev 6552)
+++ SwiftTutorials/OHBM_2013-06-16/genatlas.swift	2013-06-14 21:19:57 UTC (rev 6553)
@@ -7,13 +7,10 @@
   file image;
-# import AIRdefs
-app (Volume alignedVol) align (file script, Volume reference, Volume input)
-  sh @script @filename(reference.image) @filename(input.image) @filename(alignedVol.image);
+# import AIR
 app (Volume atlas) softmean (Volume v[])
   softmean @filename(atlas.header) "y" "null" @filenames(v);
@@ -29,10 +26,53 @@
   convert @i @o;
+app (file warp) alignlinear (Volume ref, Volume subject, string params[])
+  alignlinear @filename(ref.header) @filename(subject.header) @filename(warp) params;
+app (file warp) alignwarp (Volume ref, Volume subject, file initWarp, string params[])
+  align_warp @filename(ref.header) @filename(subject.header) @filename(warp) "-f" @filename(initWarp) params;
+app (Volume v) reslice (file warp, Volume subject)
+  reslice @filename(warp) @filename(v.header) "-a" @filename(subject.header);
+# start of genatlas workflow
+file   alignScript<"align.sh">;
+  /* This script does:
+  time $AIR5/bin/alignlinear $ref $anat init.warp \
+    -m 15 -t1 55 -t2 55 -x 1 -r 8 -c 0.1 -h 8
+  time $AIR5/bin/align_warp  $ref $anat refined.warp \
+    -m 1 12 -b1 .1 .1 .1  -b2 .1 .1 .1 -f init.warp -h 10000 -s 1024 2 2 -c .01 # -v -q -s 1024 2 2 -c .01
+  time $AIR5/bin/reslice refined.warp $resliced -a $anat
+app (Volume alignedVol) align_sh (file script, Volume reference, Volume input)
+  sh @script @filename(reference.image) @filename(input.image) @filename(alignedVol.image);
+(Volume alignedVol) native_align (Volume ref, Volume subject)
+  file firstwarp = alignlinear(ref, subject,
+                     ["-m","15","-t1","55","-t2","55","-x","1","-r","8","-c","0.1","-h","8"]);
+  file refinedWarp = alignwarp(ref, subject, firstwarp,
+                      ["-m","1","12","-b1",".1",".1",".1","-b2",".1",".1",".1",
+                       "-h","10000","-s","1024","2","2","-c",".01"]);
+  alignedVol = reslice(refinedWarp,subject);
 # Start code here
 string dataDir = @arg("d","data");
-file   alignScript<"align.sh">;
 Volume referenceVolume<ext; exec="volmapper",name="data/reference">;
 Volume inputVolumes []<ext; exec="volmapper",prefix=@strcat(dataDir,"/anatomy")>;
@@ -40,7 +80,8 @@
 foreach v, i in inputVolumes {
   Volume aligned<ext; exec="volmapper",name=@strcat("work/aligned",i)>;
-  aligned = align(alignScript,referenceVolume, v);
+  // aligned = align(alignScript,referenceVolume, v);
+  aligned = native_align(referenceVolume, v);
   outputVolumes[i] = aligned;
@@ -56,6 +97,12 @@
 zSlice = convert(slicer(atlasVolume,"z"));
 /******* The following code to be removed
 string testNames[] = imageNames(outputVolumes);
Modified: SwiftTutorials/OHBM_2013-06-16/sites.xml
--- SwiftTutorials/OHBM_2013-06-16/sites.xml	2013-06-14 17:13:55 UTC (rev 6552)
+++ SwiftTutorials/OHBM_2013-06-16/sites.xml	2013-06-14 21:19:57 UTC (rev 6553)
@@ -9,11 +9,11 @@
     <profile namespace="karajan" key="jobThrottle">.03</profile> <!-- eg .11 -> 12 -->
   </pool>
-  <pool handle="westmere">
+  <pool handle="midway">
     <execution provider="coaster" jobmanager="local:slurm"/>
     <!-- Set partition and account here: -->
-    <profile namespace="globus" key="queue">westmere</profile>
+    <profile namespace="globus" key="queue">bigmem</profile>
     <profile namespace="globus" key="ppn">12</profile>
     <!-- <profile namespace="globus" key="project">pi-wilde</profile> -->
Modified: SwiftTutorials/OHBM_2013-06-16/swift.properties
--- SwiftTutorials/OHBM_2013-06-16/swift.properties	2013-06-14 17:13:55 UTC (rev 6552)
+++ SwiftTutorials/OHBM_2013-06-16/swift.properties	2013-06-14 21:19:57 UTC (rev 6553)
@@ -3,7 +3,7 @@
 tc.file=apps
 use.provider.staging=false
-provider.staging.pin.swiftfiles=true
+provider.staging.pin.swiftfiles=false
 use.wrapper.staging=false
 status.mode=provider
