[Swift-commit] r6552 - trunk/docs/siteguide
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Fri Jun 14 12:13:55 CDT 2013
Author: ketan
Date: 2013-06-14 12:13:55 -0500 (Fri, 14 Jun 2013)
New Revision: 6552
Modified:
   trunk/docs/siteguide/ec2
Log:
updates based on Justin feedback
Modified: trunk/docs/siteguide/ec2
--- trunk/docs/siteguide/ec2	2013-06-14 13:52:11 UTC (rev 6551)
+++ trunk/docs/siteguide/ec2	2013-06-14 17:13:55 UTC (rev 6552)
@@ -106,6 +106,16 @@
 cp -r ~maheshwari/swift_cloud $HOME/
+Make sure Swift module is loaded and your credentials are added as follows:
+module load swift
+ssh-add
 Replace the hosts.txt found in +swift_cloud+ directory by adding the address/DNS of instances.
 With the ec2 commandline, the list of ip addresses of running instances can be obtained and added to hosts.txt as follows:
