[Swift-commit] r6482 - demo/cray/swift-2.0/part08
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Thu Apr 18 16:07:36 CDT 2013
Author: wozniak
Date: 2013-04-18 16:07:35 -0500 (Thu, 18 Apr 2013)
New Revision: 6482
Added:
   demo/cray/swift-2.0/part08/README.txt
Removed:
Modified:
   demo/cray/swift-2.0/part08/p8.swift
Log:
Latest everything
Property changes on: demo/cray/swift-2.0/part08
___________________________________________________________________
Added: svn:ignore
   + output
p8.tcl
Deleted: demo/cray/swift-2.0/part08/README
--- demo/cray/swift-2.0/part08/README	2013-04-18 18:24:07 UTC (rev 6481)
+++ demo/cray/swift-2.0/part08/README	2013-04-18 21:07:35 UTC (rev 6482)
@@ -1,4 +0,0 @@
-To run:
-run-swift-2-local.sh p8.swift --steps=0 ...
Added: demo/cray/swift-2.0/part08/README.txt
--- demo/cray/swift-2.0/part08/README.txt	                        (rev 0)
+++ demo/cray/swift-2.0/part08/README.txt	2013-04-18 21:07:35 UTC (rev 6482)
@@ -0,0 +1,43 @@
+SUMMARY:
+This test runs the p8.swift script, running some simple scripts as
+apps and producing output in the user directory.
+USAGE:
+Make a work directory called, say, WORK
+$ cd WORK
+# Copy in the Swift script:
+$ cp -r /home/users/p01577/Public/demo/part08/p8.swift .
+# Copy in the input data:
+$ cp -r /home/users/p01577/Public/demo/part08/data .
+$ PATH=$PATH:/home/users/p01577/Public/demo/bin
+$ run-swift-2-qsub.sh p8.swift --work=$PWD
+# Inspect the output:
+$ ls output
+$ ls *.OU
+FURTHER:
+run-swift-2-qsub.sh compiles and runs the Swift script.  It sets
+everything up, including the locations of Swift programs.
+run-swift-2-qsub.sh is user code.  You can edit this
+to change compiler options, run time settings, etc.
+p8.swift is also user code.
+run-swift-2-qsub.sh calls turbine-aprun-run.zsh which is the provided
+interface to Swift.  This script is documented at:
+http://www.mcs.anl.gov/exm/local/guides/turbine-sites.html#_raven
Modified: demo/cray/swift-2.0/part08/p8.swift
--- demo/cray/swift-2.0/part08/p8.swift	2013-04-18 18:24:07 UTC (rev 6481)
+++ demo/cray/swift-2.0/part08/p8.swift	2013-04-18 21:07:35 UTC (rev 6482)
@@ -26,15 +26,17 @@
   int  rnge = toint(argv("range", "100"));
   int  count = toint(argv("count", "10"));
-  file bias = input_file("data/bias.dat");
+  string work = argv("work");
+  file bias = input_file(work+"/data/bias.dat");
   foreach i in [0:nsim-1] {
-    file simout <sprintf("data/sim_%i.out",i)>;
+    file simout <work+sprintf("/data/sim_%i.out",i)>;
     simout = mysim5(steps,rnge,bias,count);
     sims[i] = simout;
-  file stats<"output/average.out">;
+  file stats<work+"/output/average.out">;
   stats = analyze(sims);
   wait (stats) {
     printf("SUCCESS!");
