[Swift-commit] r6481 - demo/cray/swift-1.0/part08-cray-loop
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Thu Apr 18 13:24:07 CDT 2013
Author: wilde
Date: 2013-04-18 13:24:07 -0500 (Thu, 18 Apr 2013)
New Revision: 6481
Added:
   demo/cray/swift-1.0/part08-cray-loop/beagle.xml
   demo/cray/swift-1.0/part08-cray-loop/raven-direct.xml
   demo/cray/swift-1.0/part08-cray-loop/raven.xml
Removed:
   demo/cray/swift-1.0/part08-cray-loop/cray.xml
   demo/cray/swift-1.0/part08-cray-loop/pbs.xml
   demo/cray/swift-1.0/part08-cray-loop/ravenps.xml
Modified:
   demo/cray/swift-1.0/part08-cray-loop/README
Log:
Adjust README and sites file names.
Modified: demo/cray/swift-1.0/part08-cray-loop/README
--- demo/cray/swift-1.0/part08-cray-loop/README	2013-04-18 18:12:35 UTC (rev 6480)
+++ demo/cray/swift-1.0/part08-cray-loop/README	2013-04-18 18:24:07 UTC (rev 6481)
@@ -36,21 +36,29 @@
   $ swift p8.swift -nsim=10 -steps=5 -range=1000 -count=5
 !!! STOP HERE - remaining needs adjustments
+PART 2:
 Next, you can experiment with different size runs:
-Adjust the job sizes:
+Adjust the job sizes in sites.xml:
     <profile namespace="globus" key="slots">6</profile>
     <profile namespace="globus" key="nodeGranularity">4</profile>
     <profile namespace="globus" key="maxNodes">4</profile>
+TODO: Explain the above!!!
+PART 3:
+Next, you can experiment with different data management strategy
 In these runs, Swift was moving data to and from the data/ directory by
 staging to the compute node local (RAM) filesystem. For some workflows its
 better to bypass staging and access all input and output files directly.
@@ -59,17 +67,13 @@
 and turning off staging to the local filesystem:
   $ sed -i -e '/SET PROVIDER STAGING/s/=true/=false/p' $HOME/.swift/swift.properties
+  $ cp raven-direct.xml sites.xml
 Now run the script with "direct" data acces
-  swift -sites.file ravenps.xml -cdm.file dmrules p8.swift -steps=1 -range=1000 -count=6 -nsim=10
+  swift -cdm.file dmrules p8.swift -steps=1 -range=1000 -count=6 -nsim=10
-The app list
 OLD: FIXME:
 TOPIC: Run the "simulations" on the parallel cluster
Copied: demo/cray/swift-1.0/part08-cray-loop/beagle.xml (from rev 6480, demo/cray/swift-1.0/part08-cray-loop/cray.xml)
--- demo/cray/swift-1.0/part08-cray-loop/beagle.xml	                        (rev 0)
+++ demo/cray/swift-1.0/part08-cray-loop/beagle.xml	2013-04-18 18:24:07 UTC (rev 6481)
@@ -0,0 +1,31 @@
+<config>
+  <pool handle="localhost">
+    <execution provider="local"/>
+    <filesystem provider="local"/>
+    <workdirectory>/scratch/midway/{env.USER}/swiftwork</workdirectory>
+  </pool>
+  <pool handle="cray">
+    <execution provider="coaster" jobmanager="local:pbs"/>
+    <!-- <profile namespace="globus" key="project">CI-CCR000013</profile> -->
+    <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
+    <!-- <profile namespace="globus" key="queue">scalability</profile> -->
+    <profile namespace="globus" key="queue">batch</profile>
+    <profile namespace="globus" key="jobsPerNode">24</profile>
+    <profile namespace="globus" key="maxTime">1800</profile>
+    <profile namespace="globus" key="slots">1</profile>
+    <profile namespace="globus" key="nodeGranularity">1</profile>
+    <profile namespace="globus" key="maxNodes">1</profile>
+    <profile namespace="karajan" key="jobThrottle">12</profile>
+    <profile namespace="karajan" key="initialScore">10000</profile>
+    <workdirectory>/lustre/beagle/wilde/swift/lab/swiftwork</workdirectory>
+  </pool>
+</config>
Deleted: demo/cray/swift-1.0/part08-cray-loop/cray.xml
--- demo/cray/swift-1.0/part08-cray-loop/cray.xml	2013-04-18 18:12:35 UTC (rev 6480)
+++ demo/cray/swift-1.0/part08-cray-loop/cray.xml	2013-04-18 18:24:07 UTC (rev 6481)
@@ -1,31 +0,0 @@
-<config>
-  <pool handle="localhost">
-    <execution provider="local"/>
-    <filesystem provider="local"/>
-    <workdirectory>/scratch/midway/{env.USER}/swiftwork</workdirectory>
-  </pool>
-  <pool handle="cray">
-    <execution provider="coaster" jobmanager="local:pbs"/>
-    <!-- <profile namespace="globus" key="project">CI-CCR000013</profile> -->
-    <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
-    <!-- <profile namespace="globus" key="queue">scalability</profile> -->
-    <profile namespace="globus" key="queue">batch</profile>
-    <profile namespace="globus" key="jobsPerNode">24</profile>
-    <profile namespace="globus" key="maxTime">1800</profile>
-    <profile namespace="globus" key="slots">1</profile>
-    <profile namespace="globus" key="nodeGranularity">1</profile>
-    <profile namespace="globus" key="maxNodes">1</profile>
-    <profile namespace="karajan" key="jobThrottle">12</profile>
-    <profile namespace="karajan" key="initialScore">10000</profile>
-    <workdirectory>/lustre/beagle/wilde/swift/lab/swiftwork</workdirectory>
-  </pool>
-</config>
Deleted: demo/cray/swift-1.0/part08-cray-loop/pbs.xml
--- demo/cray/swift-1.0/part08-cray-loop/pbs.xml	2013-04-18 18:12:35 UTC (rev 6480)
+++ demo/cray/swift-1.0/part08-cray-loop/pbs.xml	2013-04-18 18:24:07 UTC (rev 6481)
@@ -1,23 +0,0 @@
-<config>
-  <pool handle="pbs">
-  </pool>
-</config>
Copied: demo/cray/swift-1.0/part08-cray-loop/raven-direct.xml (from rev 6480, demo/cray/swift-1.0/part08-cray-loop/raven.xml)
--- demo/cray/swift-1.0/part08-cray-loop/raven-direct.xml	                        (rev 0)
+++ demo/cray/swift-1.0/part08-cray-loop/raven-direct.xml	2013-04-18 18:24:07 UTC (rev 6481)
@@ -0,0 +1,35 @@
+<config>
+    <workdirectory>{env.PWD}/swiftwork</workdirectory>
+  </pool>
+    <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=32</profile>
+    <!-- <profile namespace="globus" key="queue">batch</profile> -->
+    <profile namespace="globus" key="queue">small</profile>
+    <profile namespace="globus" key="jobsPerNode">32</profile>
+    <profile namespace="karajan" key="jobThrottle">6.00</profile>
+    <profile namespace="env" key="PATHPREFIX">{env.PATHPREFIX}</profile>
+  </pool>
+</config>
Deleted: demo/cray/swift-1.0/part08-cray-loop/raven.xml
--- demo/cray/swift-1.0/part08-cray-loop/raven.xml	2013-04-18 18:12:35 UTC (rev 6480)
+++ demo/cray/swift-1.0/part08-cray-loop/raven.xml	2013-04-18 18:24:07 UTC (rev 6481)
@@ -1,35 +0,0 @@
-<config>
-    <workdirectory>{env.PWD}/swiftwork</workdirectory>
-  </pool>
-    <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=32</profile>
-    <!-- <profile namespace="globus" key="queue">batch</profile> -->
-    <profile namespace="globus" key="queue">small</profile>
-    <profile namespace="globus" key="jobsPerNode">32</profile>
-    <profile namespace="karajan" key="jobThrottle">6.00</profile>
-    <profile namespace="env" key="PATHPREFIX">{env.PATHPREFIX}</profile>
-  </pool>
-</config>
Copied: demo/cray/swift-1.0/part08-cray-loop/raven.xml (from rev 6480, demo/cray/swift-1.0/part08-cray-loop/ravenps.xml)
--- demo/cray/swift-1.0/part08-cray-loop/raven.xml	                        (rev 0)
@@ -0,0 +1,35 @@
+<config>
+  </pool>
+    <workdirectory>/dev/shm/{env.USER}/swiftwork</workdirectory>
+  </pool>
+</config>
Deleted: demo/cray/swift-1.0/part08-cray-loop/ravenps.xml
--- demo/cray/swift-1.0/part08-cray-loop/ravenps.xml	2013-04-18 18:12:35 UTC (rev 6480)
+++ demo/cray/swift-1.0/part08-cray-loop/ravenps.xml	2013-04-18 18:24:07 UTC (rev 6481)
@@ -1,35 +0,0 @@
-<config>
-  </pool>
-    <workdirectory>/dev/shm/{env.USER}/swiftwork</workdirectory>
-  </pool>
-</config>
