[Swift-commit] r6471 - in demo/cray/swift-1.0: . part00 part08
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Wed Apr 17 19:13:29 CDT 2013
Author: wilde
Date: 2013-04-17 19:13:29 -0500 (Wed, 17 Apr 2013)
New Revision: 6471
Added:
   demo/cray/swift-1.0/part00/
   demo/cray/swift-1.0/part00/README
   demo/cray/swift-1.0/part00/p0.swift
   demo/cray/swift-1.0/part00/p0.swift.original
   demo/cray/swift-1.0/part08/apps
   demo/cray/swift-1.0/part08/dmrules
Removed:
   demo/cray/swift-1.0/part08/tc
Modified:
   demo/cray/swift-1.0/part08/README
   demo/cray/swift-1.0/part08/cf
   demo/cray/swift-1.0/part08/raven.xml
   demo/cray/swift-1.0/part08/ravenps.xml
   demo/cray/swift-1.0/setup.sh
Log:
Add part00 for a basic intro to Swift language elements.
Added: demo/cray/swift-1.0/part00/README
--- demo/cray/swift-1.0/part00/README	                        (rev 0)
+++ demo/cray/swift-1.0/part00/README	2013-04-18 00:13:29 UTC (rev 6471)
@@ -0,0 +1,21 @@
+TOPIC: Basics of the Swift language
+A walk through comments, trace() statements (Swift's only form of direct
+printing, variables, arrays, and loops.
+/*Remove the comments marked <--, one at a time,
+  to try the following examples
+  using "swift p0.swift"
+//   (1) Declare, assign, and trace variables:
+/* <-- (1)
+p0.swift.original is provided in case you need to get back to the original
+script.
Added: demo/cray/swift-1.0/part00/p0.swift
--- demo/cray/swift-1.0/part00/p0.swift	                        (rev 0)
+++ demo/cray/swift-1.0/part00/p0.swift	2013-04-18 00:13:29 UTC (rev 6471)
@@ -0,0 +1,76 @@
+tracef("Hello, World!\n");
+#  this is a one-line comment
+// as it this
+/* This is a
+   multi-line c
+/* <-- (1)
+int n;
+string str;
+n=99;
+str = "\n\n hi there! \n\n";
+tracef("\n n=%i str=%s\n\n", n, str);
+//   (2) Declare and trace a  vector
+/* <-- (2)
+int[] ivec = [12,43,56,87,123];
+tracef("ivec: %q\n",ivec);
+trace("ivec",ivec);
+//   (3) foreach: do each loop body in parallel
+/* <-- (3)
+foreach i, value in ivec {
+  tracef("i=%i value=%i\n", i, value);
+//   (4) Use an array constructor to control a foreach loop
+/* <-- (4)
+foreach j, value in [0:9] {
+  tracef("j=%i value=%i\n", j, value);
+//   (5) Data flow evaluation: the statements below execute in reverse order
+/* <-- (5)
+int a, b, c;
+c = 1234;
+a = b;
+b = c;
+trace("dataflow", a, b, c);
+//   (6) The iterate statement executes sequentially
+/* <-- (6)
+iterate iter {
+  trace("iter",iter);
+} until(iter==10);
+// TO ADD: functions, if, select...  Associative arrays... More?
Added: demo/cray/swift-1.0/part00/p0.swift.original
--- demo/cray/swift-1.0/part00/p0.swift.original	                        (rev 0)
+++ demo/cray/swift-1.0/part00/p0.swift.original	2013-04-18 00:13:29 UTC (rev 6471)
@@ -0,0 +1,74 @@
+// as it this
+/* This is a
+   multi-line c
+/* <-- (1)
+int n;
+string str;
+n=99;
+/* <-- (2)
+/* <-- (3)
+/* <-- (4)
+/* <-- (5)
+int a, b, c;
+c = 1234;
+a = b;
+b = c;
+/* <-- (6)
+iterate iter {
+} until(iter==10);
Modified: demo/cray/swift-1.0/part08/README
--- demo/cray/swift-1.0/part08/README	2013-04-17 19:52:32 UTC (rev 6470)
+++ demo/cray/swift-1.0/part08/README	2013-04-18 00:13:29 UTC (rev 6471)
@@ -1,15 +1,27 @@
+Regular staging with deafult data management:
+  swift -config cf -tc.file apps -sites.file cray.xml  p8.swift -steps=1 -range=1000 -count=6 -nsim=100
 Regular staging with direct data management:
-  swift -config cf -tc.file tc -sites.file cray.xml -cdm.file dm p8.swift -steps=1 -range=1000 -count=6 -nsim=100
+  swift -config cf -tc.file apps -sites.file cray.xml -cdm.file dmrules p8.swift -steps=1 -range=1000 -count=6 -nsim=100
 Provider staging:
-  swift -config cf.ps -tc.file tc -sites.file ravenps.xml p8.swift -steps=5 -range=1000 -count=6 -nsim=100
+  swift -config cf.ps -tc.file apps -sites.file ravenps.xml p8.swift -steps=5 -range=1000 -count=6 -nsim=100
+Adjust the job sizes:
+    <profile namespace="globus" key="slots">6</profile>
+    <profile namespace="globus" key="nodeGranularity">4</profile>
+    <profile namespace="globus" key="maxNodes">4</profile>
+The app list
 OLD: FIXME:
 TOPIC: Run the "simulations" on the parallel cluster
Copied: demo/cray/swift-1.0/part08/apps (from rev 6464, demo/cray/swift-1.0/part08/tc)
--- demo/cray/swift-1.0/part08/apps	                        (rev 0)
+++ demo/cray/swift-1.0/part08/apps	2013-04-18 00:13:29 UTC (rev 6471)
@@ -0,0 +1,8 @@
+#cray random5  /lustre/beagle/wilde/swift/demo/cray/svn/bin/random5.sh
+#cray average  /lustre/beagle/wilde/swift/demo/cray/svn/bin/avg.sh
+#cray random5  /home/users/p01532/swift/demo/svn/bin/random5.sh
+#cray average  /home/users/p01532/swift/demo/svn/bin/avg.sh
+cray random5  random5.sh
+cray average  avg.sh
Modified: demo/cray/swift-1.0/part08/cf
--- demo/cray/swift-1.0/part08/cf	2013-04-17 19:52:32 UTC (rev 6470)
+++ demo/cray/swift-1.0/part08/cf	2013-04-18 00:13:29 UTC (rev 6471)
@@ -1,4 +1,11 @@
-user.home=/lustre/beagle/wilde
+#sites.file=${swift.home}/etc/sites.xml
+#tc.file=${swift.home}/etc/tc.data
+sites.file=./raven.xml
+tc.file=./apps
+#user.home=/lustre/beagle/wilde
 wrapperlog.always.transfer=true
 sitedir.keep=true
 execution.retries=0
Deleted: demo/cray/swift-1.0/part08/dm
--- demo/cray/swift-1.0/part08/dm	2013-04-17 19:52:32 UTC (rev 6470)
+++ demo/cray/swift-1.0/part08/dm	2013-04-18 00:13:29 UTC (rev 6471)
@@ -1,4 +0,0 @@
-#rule .*/data.* DIRECT /lustre/beagle/wilde/swift/demo/cray/svn/part08
-rule .*data/.* DIRECT /home/users/p01532/swift/demo/svn/part08
Copied: demo/cray/swift-1.0/part08/dmrules (from rev 6464, demo/cray/swift-1.0/part08/dm)
--- demo/cray/swift-1.0/part08/dmrules	                        (rev 0)
+++ demo/cray/swift-1.0/part08/dmrules	2013-04-18 00:13:29 UTC (rev 6471)
@@ -0,0 +1,4 @@
+#rule .*/data.* DIRECT /lustre/beagle/wilde/swift/demo/cray/svn/part08
+rule .*data/.* DIRECT /home/users/p01532/swift/demo/svn/part08
Modified: demo/cray/swift-1.0/part08/raven.xml
--- demo/cray/swift-1.0/part08/raven.xml	2013-04-17 19:52:32 UTC (rev 6470)
+++ demo/cray/swift-1.0/part08/raven.xml	2013-04-18 00:13:29 UTC (rev 6471)
@@ -3,7 +3,7 @@
   <pool handle="localhost">
     <execution provider="local"/>
     <filesystem provider="local"/>
-    <workdirectory>/home/users/{env.USER}/swiftwork</workdirectory>
+    <workdirectory>{env.PWD}/swiftwork</workdirectory>
   </pool>
   <pool handle="cray">
@@ -18,15 +18,17 @@
     <profile namespace="globus" key="jobsPerNode">32</profile>
     <profile namespace="globus" key="maxTime">1800</profile>
-    <profile namespace="globus" key="slots">6</profile>
-    <profile namespace="globus" key="nodeGranularity">4</profile>
-    <profile namespace="globus" key="maxNodes">4</profile>
+    <profile namespace="globus" key="slots">1</profile>
+    <profile namespace="globus" key="nodeGranularity">1</profile>
+    <profile namespace="globus" key="maxNodes">1</profile>
     <profile namespace="karajan" key="jobThrottle">6.00</profile>
     <profile namespace="karajan" key="initialScore">10000</profile>
+    <profile namespace="env" key="PATHPREFIX">{env.PATHPREFIX}</profile>
   </pool>
Modified: demo/cray/swift-1.0/part08/ravenps.xml
--- demo/cray/swift-1.0/part08/ravenps.xml	2013-04-17 19:52:32 UTC (rev 6470)
+++ demo/cray/swift-1.0/part08/ravenps.xml	2013-04-18 00:13:29 UTC (rev 6471)
@@ -3,7 +3,7 @@
   </pool>
@@ -18,13 +18,15 @@
     <workdirectory>/dev/shm/{env.USER}/swiftwork</workdirectory>
Deleted: demo/cray/swift-1.0/part08/tc
--- demo/cray/swift-1.0/part08/tc	2013-04-17 19:52:32 UTC (rev 6470)
+++ demo/cray/swift-1.0/part08/tc	2013-04-18 00:13:29 UTC (rev 6471)
@@ -1,6 +0,0 @@
-#cray random5  /lustre/beagle/wilde/swift/demo/cray/svn/bin/random5.sh
-#cray average  /lustre/beagle/wilde/swift/demo/cray/svn/bin/avg.sh
-cray random5  /home/users/p01532/swift/demo/svn/bin/random5.sh
-cray average  /home/users/p01532/swift/demo/svn/bin/avg.sh
Modified: demo/cray/swift-1.0/setup.sh
--- demo/cray/swift-1.0/setup.sh	2013-04-17 19:52:32 UTC (rev 6470)
+++ demo/cray/swift-1.0/setup.sh	2013-04-18 00:13:29 UTC (rev 6471)
@@ -1,18 +1,20 @@
-module load swift
+# module load java # to get Oracle/Sun JDK
+# module load swift
-export SBATCH_RESERVATION=swift
-DIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )"
+# export SBATCH_RESERVATION=swift
-echo Adding $DIR/bin to PATH:
+export PATHPREFIX="$( cd "$( dirname "${BASH_SOURCE[0]}" )/../bin" && pwd )"
+echo   Set PATHPREFIX=$PATHPREFIX
-PATH=$DIR/bin:$PATH
+PATH=/home/users/p01532/swift/rev/0.94/bin:$PATHPREFIX:$PATH
-echo $PATH
+return
 mkdir -p $HOME/.swift
 if [ -f $HOME/.swift/swift.properties ]; then
   echo Adding properties to end of $HOME/.swift/swift.properties
 else
