[Swift-commit] r6470 - demo/cray/swift-2.0/part08
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Wed Apr 17 14:52:32 CDT 2013
Author: wozniak
Date: 2013-04-17 14:52:32 -0500 (Wed, 17 Apr 2013)
New Revision: 6470
Modified:
   demo/cray/swift-2.0/part08/README
   demo/cray/swift-2.0/part08/p8.swift
Log:
Update README; add success message
Modified: demo/cray/swift-2.0/part08/README
--- demo/cray/swift-2.0/part08/README	2013-04-17 19:51:35 UTC (rev 6469)
+++ demo/cray/swift-2.0/part08/README	2013-04-17 19:52:32 UTC (rev 6470)
@@ -1,94 +1,4 @@
+To run:
-Regular staging with direct data management:
-  swift -config cf -tc.file tc -sites.file cray.xml -cdm.file dm p8.swift -steps=1 -range=1000 -count=6 -nsim=100
-Provider staging:
-  swift -config cf.ps -tc.file tc -sites.file ravenps.xml p8.swift -steps=5 -range=1000 -count=6 -nsim=100
-OLD: FIXME:
-TOPIC: Run the "simulations" on the parallel cluster
-Til now we've been running our "simulations" on the local login host.
-Now we'll run them on the parallel cluster.
-The script will be the same as previous, but we change the tool catalog to
-indicate that our "simulation app" (random4.sh) should be run on the
-"westmere" partition of the Midway cluster using the "slurm" scheduler:
-We changed file "tc" from:
-localhost random4  random4.sh
-localhost average  avg.sh
-to:
-westmere  random4  random4.sh
-And we added the "sites.xml" file which specifies two "pools" of resources,
-the "local host" pool (which we've been using till now) and the "westmere" pool.
-To run, we now add the sites.xml file to the swift command line:
-$ swift -tc.file tc -sites.file sites.xml p7.swift -steps=10 -range=1000 -count=6 -nsim=100
-Note that we're now asking for 100 simulations to be run, each of which
-is to run for 10 steps (ie 10 seconds).
-The sites file looks like this:
-<config>
-  <pool handle="localhost">
-    <execution provider="local"/>
-    <filesystem provider="local"/>
-    <workdirectory>/scratch/midway/{env.USER}/swiftwork</workdirectory>
-  </pool>
-  <pool handle="westmere">
-    <execution provider="coaster" jobmanager="local:slurm"/>
-    <!-- Set partition and account here: -->
-    <profile namespace="globus" key="queue">westmere</profile>
-    <profile namespace="globus" key="ppn">12</profile>
-    <!-- <profile namespace="globus" key="project">pi-wilde</profile> -->
-    <!-- Set number of jobs and nodes per job here: -->
-    <profile namespace="globus" key="slots">1</profile>
-    <profile namespace="globus" key="maxnodes">1</profile>
-    <profile namespace="globus" key="nodegranularity">1</profile>
-    <profile namespace="globus" key="jobsPerNode">12</profile> <!-- apps per node! -->
-    <profile namespace="karajan" key="jobThrottle">.11</profile> <!-- eg .11 -> 12 -->
-    <!-- Set estimated app time (maxwalltime) and requested job time (maxtime) here: -->
-    <profile namespace="globus" key="maxWalltime">00:15:00</profile>
-    <profile namespace="globus" key="maxtime">1800</profile>  <!-- in seconds! -->
-    <!-- Set data staging model and work dir here: -->
-    <!-- Typically leave these constant: -->
-    <profile namespace="globus" key="slurm.exclusive">false</profile>
-    <profile namespace="globus" key="highOverAllocation">100</profile>
-    <profile namespace="globus" key="lowOverAllocation">100</profile>
-    <profile namespace="karajan" key="initialScore">10000</profile>
-  </pool>
-</config>
-Try:
-- running more app() calls at once:  change jobsPerNode and jobThrottle
-- requesting more than 1 slurm job at once: change slots
-- requesting nodes in units greater than 1: change maxnodes and nodeGranularity
+run-swift-2-local.sh p8.swift --steps=0 ...
Modified: demo/cray/swift-2.0/part08/p8.swift
--- demo/cray/swift-2.0/part08/p8.swift	2013-04-17 19:51:35 UTC (rev 6469)
+++ demo/cray/swift-2.0/part08/p8.swift	2013-04-17 19:52:32 UTC (rev 6470)
@@ -2,6 +2,7 @@
 #include <builtins.swift>
 #include <assert.swift>
 #include <files.swift>
+#include <io.swift>
 #include <string.swift>
 #include <sys.swift>
@@ -35,4 +36,7 @@
   file stats<"output/average.out">;
   stats = analyze(sims);
+  wait (stats) {
+    printf("SUCCESS!");
