[Swift-commit] r5298 - trunk/tests/cdm
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Mon Nov 14 18:07:09 CST 2011
Author: wozniak
Date: 2011-11-14 18:07:09 -0600 (Mon, 14 Nov 2011)
New Revision: 5298
Modified:
   trunk/tests/cdm/211-direct-output-abs.swift
Log:
Correction to test case SwiftScript
Modified: trunk/tests/cdm/211-direct-output-abs.swift
--- trunk/tests/cdm/211-direct-output-abs.swift	2011-11-15 00:06:07 UTC (rev 5297)
+++ trunk/tests/cdm/211-direct-output-abs.swift	2011-11-15 00:07:09 UTC (rev 5298)
@@ -9,6 +9,6 @@
 file f1<"211-input.txt">;
 // Will be transformed by CDM to /tmp/211-output.txt:
-file f2<"211-output.txt">;
+file f2<"/tmp/211-output.txt">;
 f2 = copy(f1);
