[Swift-commit] r5297 - trunk/tests/cdm
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Mon Nov 14 18:06:08 CST 2011
Author: wozniak
Date: 2011-11-14 18:06:07 -0600 (Mon, 14 Nov 2011)
New Revision: 5297
Modified:
   trunk/tests/cdm/fs.template.data
Log:
Correction to test case
Modified: trunk/tests/cdm/fs.template.data
--- trunk/tests/cdm/fs.template.data	2011-11-14 23:57:28 UTC (rev 5296)
+++ trunk/tests/cdm/fs.template.data	2011-11-15 00:06:07 UTC (rev 5297)
@@ -5,7 +5,7 @@
 rule .*201-output.txt DIRECT _PWD_/201
 rule .*210-input.txt EXTERNAL _PWD_/external.sh
-rule .*211-output.txt DIRECT /tmp
+rule .*211-output.txt DIRECT /
 rule .*301-input.txt BROADCAST _PWD_/301
 rule .*501-output.*.txt GATHER
 rule .*601-input.*.txt LOCAL cp _PWD_/601
