[Swift-commit] r4927 - wwwdev/main
vytas at ci.uchicago.edu vytas at ci.uchicago.edu
Tue Aug 2 10:25:10 CDT 2011
Author: vytas
Date: 2011-08-02 10:25:07 -0500 (Tue, 02 Aug 2011)
New Revision: 4927
Removed:
   wwwdev/main/index2.php
Log:
original replacement file - contents is now in index.php
Deleted: wwwdev/main/index2.php
--- wwwdev/main/index2.php	2011-08-01 22:15:41 UTC (rev 4926)
+++ wwwdev/main/index2.php	2011-08-02 15:25:07 UTC (rev 4927)
@@ -1,137 +0,0 @@
-<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
-<html xmlns="http://www.w3.org/1999/xhtml">
-<head>
-<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
-<title>Swift - A system for rapid and reliable specification, execution, and management of large scale workflows</title>
-<link href="../css/960_12_col.css" rel="stylesheet" type="text/css" />
-<link href="../css/reset.css" rel="stylesheet" type="text/css" />
-<link href="../css/style3.css" rel="stylesheet" type="text/css" />
-<link href="../css/orbit-1.2.3.css" rel="stylesheet" type="text/css">
-<script type="text/javascript" src="../js/jquery-1.5.1.min.js"></script>
-<script type="text/javascript" src="../js/jquery.orbit-1.2.3.min.js"></script>
-<!--[if IE]>
-			     <style type="text/css">
-			         .timer { display: none !important; }
-			         div.caption { background:transparent; filter:progid:DXImageTransform.Microsoft.gradient(startColorstr=#99000000,endColorstr=#99000000);zoom: 1; }
-			    </style>
-			<![endif]-->
-<script type="text/javascript" src="http://use.typekit.com/dbf2lqy.js"></script>
-<script type="text/javascript">try{Typekit.load();}catch(e){}</script>
-<!-- Run the plugin -->
-		<script type="text/javascript">
-			$(window).load(function() {
-				$('#featured').orbit({
-					bullets: true,
-		</script>
-</head>
-<body>
-<div class="container_12">
-	<!-- header -->
-	<?php require('../inc/header2.php') ?>
-	<!-- end header -->
-  <div class="grid_12">
-    <h1 class="tagline">
-      A system for rapid and reliable specification, execution, and management of large scale workflows.
-    </h1>
-  </div>
-  <!-- end .grid_12 -->
-  <div class="clear"></div>
-  <div class="grid_9">
-  	<div class="container">
-		<?php require('../inc/rotator.php') ?>
-		<img src="../images/rotator_shadow.png" width="674" height="10" />
-	</div>
-  </div>
-  <!-- end .grid_9 -->
-  <div class="grid_3">
-    <div id="box-prime"><div class="button_175"><a href="../packages/swift-0.92.1.tar.gz" onClick="javascript: pageTracker._trackPageview('/swift/packages/swift-0.92.1.tar.gz');">Download Now</a></div><b>0.92.1</b> current version<br />2011/04/13
-	<br /><a href="../downloads/index.php">view all downloads</a></div>
-	<div id="box-prime"><div class="button_175"><a href="../guides/quickstartguide.php">Get Started</a></div>Read our Quick Start Guide
-and start using Swift today!</div>
-  </div>
-  <!-- end .grid_3 -->
-  <div class="grid_6">
-    <p class="indented">
-      <b>Swift</b> is a system for the <b>rapid</b> and <b>reliable</b> specification, execution, and management of <b>large-scale</b> science and engineering <b>workflows</b>. It supports applications that execute many tasks coupled by disk-resident datasets—as is common, for example, when analyzing large quantities of data or performing parameter studies or ensemble simulations. </p>
-	  <p class="highlight-A">A simple scripting language to enable the concise, high-level specifications of complex parallel computations, and mappers for accessing diverse data formats in a convenient manner.</p>
-	  <p class="highlight-B">An execution engine that can manage the dispatch of many (10,000) tasks to many (100) processors, whether on parallel computers, campus grids, or multi-site grids.</p>
-	  <p class="indented">Swift users have achieved multiple-order-of-magnitude savings in program development and execution time.</p>
-  </div>
-  <!-- end .grid_6 -->
-  	<div id="feature">
-    	<h3>
-    	  Who's Using Swift
-    	</h3>
-		<ul class="swift-bullet">
-			<li>physical sciences</li>
-			<li>biological sciences</li>
-			<li>social sciences</li>
-			<li>humanities</li>
-			<li>computer science</li>
-			<li>education</li>
-		</ul>
-		<a href="../papers/index.php" class="trailingLink">read the papers</a>
-	</div>
-	<!-- end feature -->
-		<h3>
-     	 Supported Platforms
-    	</h3>
-		<p class="indented-half">Cillum brisket ad veniam exercitation andouille. Cillum turkey ut jowl in tail. Reprehenderit nisi pig ex culpa qui, ea meatball ball tip tenderloin pancetta pork. </p>
-		<a href="../downloads/index.php" class="trailingLink">explore downloads</a>
-	</div>
-  </div>
-    	<h3>
-     	 What Users Are Saying
-   		</h3>
-		<p class="quote">A few lines of SwiftScript described how our analysis procedures should be applied to thousands of fMRI images. Our computation was performed quickly and reliably. Life is good.</p>
-		<p class="quote-speaker">Dr. Marielle Goodwin<br />
-Director of Brain Trauma Research<br />
-University of Chicago Hospitals</p>
-<a href="../case_studies/index.php" class="trailingLink">more case studies</a>
-	</div>
-		<h3>What's New</h3>
-		<h5>Paper Published</h5>
-		<p>Swift: A Language for Distributed Parallel Scripting</p>
-		<a href="../papers/SwiftLanguageForDistributedParallelScripting.pdf" class="trailingLinkPDF">read the paper</a>
-	</div>
-  </div>
-    <p> </p>
-  </div>
-  </div>
-</div>
-<!-- end .container_12 -->
-<!-- footer -->
-<?php require('../inc/footer2.php') ?>
-<!-- end footer -->
-var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");
-document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"));
-</script>
-try {
-var pageTracker = _gat._getTracker("UA-106257-5");
-pageTracker._trackPageview();
-} catch(err) {}</script>
-</body>
-</html>
\ No newline at end of file
