[Swift-commit] r4926 - SwiftApps/GOSwift/pykoa/tools
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Mon Aug 1 17:15:41 CDT 2011
Author: jonmon
Date: 2011-08-01 17:15:41 -0500 (Mon, 01 Aug 2011)
New Revision: 4926
Modified:
   SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
Log:
o koa_goswift.py
  -- write stdout/stderr to file after watch mode completes
  -- keep track of stdout/stderr in SwiftObserver
  -- comments
  -- Add exit code to swift.info file in each run directory
Modified: SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift.py	2011-08-01 21:11:20 UTC (rev 4925)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift.py	2011-08-01 22:15:41 UTC (rev 4926)
@@ -27,10 +27,12 @@
     def stdout_event(self, line):
         sys.stdout.write(line)
+        self.lines.append(line)
         return
     def stderr_event(self, line):
         sys.stderr.write(line)
         return
 def setup_opts(argv):
@@ -271,8 +273,8 @@
     os.environ["GLOBUS_SOURCE_PORT_RANGE"] = "50000,51000"
     # Execute the script
-#    cmd = os.path.join(os.environ["HOME"], "Swift_lib/swift-0.92/bin", "swift") # stable 0.92.1 release
-    cmd = os.path.join(os.environ["HOME"], "Swift_lib/bin", "swift")             # trunk release
+#    cmd = os.path.join(os.environ["HOME"], "Swift_lib/0.92", "swift")             # stable 0.92.1 release
+    cmd = os.path.join(os.environ["HOME"], "Swift_lib/trunk", "swift")             # trunk release
     os.chdir(work_directory)
     status = -1
@@ -281,13 +283,16 @@
     if options.watch_swift_stdoutput:
         try:
             with BlockInterrupt():
-                execute = cmd + " -runid "+str(run_id)+" -sites.file sites.xml -tc.file tc -config cf script.swift | tee -a swift.out"
+                execute = cmd + " -runid "+str(run_id)+" -sites.file sites.xml -tc.file tc -config cf script.swift"
                 pykoa.debug( "running %s in watch mode" % (execute))
                 with open(work_directory+"/run.sh", "w") as run_sh:
                     run_sh.write( "#!/bin/bash\n" )
                     run_sh.write( "[ -f /opt/osg/setup.sh ] && source /opt/osg/setup.sh\n")
                     run_sh.write( execute + "\n" )
+                    run_sh.write( "\n" )
+                    run_sh.write( "echo \"\nExit Code: $?\" >> swift.info\n" )
+                    run_sh.write( "exit $?" )
                 os.chmod(work_directory+"/run.sh", stat.S_IRUSR | stat.S_IXUSR )
@@ -298,13 +303,25 @@
                                      stdout=subprocess.PIPE,
                                      stderr=subprocess.PIPE)
+                pid = p.pid
+                with open("swift.info", "w") as swift_info:
+                    swift_info.write("StartTime: "+str(datetime.datetime.utcnow())+"\n")
+                    swift_info.write("Swift pid: "+str(pid)+"\n")
+                    swift_info.write("Run id:    "+str(run_id)+"\n")
+                    swift_info.write("\n")
+                    swift_info.write("Command Line:\n     "+execute+"\n")
                 c = SwiftObserver()
                 status = c.run(p)
-                pid = p.pid
         finally:
             if src_cred:
                 os.remove( proxyfile )
+        with open("swift.out", "w") as swift_out:
+            for line in c.lines:
+                swift_out.write(line)
         sys.stdout.write( "Swift exit status: " + str(status) + "\n" )
     else:
@@ -316,6 +333,8 @@
+            run_sh.write( "echo \"\nExit Code: $? >> swift.info\"\n" )
@@ -329,13 +348,6 @@
         swift_out.close()
-    with open("swift.info", "w") as swift_info:
-        swift_info.write("StartTime: "+str(datetime.datetime.utcnow())+"\n")
-        swift_info.write("Swift pid: "+str(pid)+"\n")
-        swift_info.write("Run id:    "+str(run_id)+"\n")
-        swift_info.write("\n")
-        swift_info.write("Command Line:\n     "+execute+"\n")
     return status
 def create_work_directory():
