[Swift-commit] r2949 - trunk/docs
Tue May 26 03:53:06 CDT 2009
Author: benc
Date: 2009-05-26 03:53:06 -0500 (Tue, 26 May 2009)
New Revision: 2949
Modified:
   trunk/docs/provenance.xml
Log:
remove another todo list
Modified: trunk/docs/provenance.xml
--- trunk/docs/provenance.xml	2009-05-26 08:52:22 UTC (rev 2948)
+++ trunk/docs/provenance.xml	2009-05-26 08:53:06 UTC (rev 2949)
@@ -1948,19 +1948,6 @@
-<section><title>stuff</title>
-<para>
-TODO transcribe info from the pile of papers I wrote. esp query analysis
-and the list of things that this section of work does *not* address.
-</para>
-<para>
-Explicitly attempt to avoid
-<ulink url="http://thedailywtf.com/Articles/The_Inner-Platform_Effect.aspx">Inner platform effect</ulink> which was a criticism of the metadata
-handling of the VDS1 VDC.
-</para>
-</section>
 <section><title>Processing i2u2 cosmic metadata</title>
 <para>i2u2 cosmic metadata is extracted from a VDS1 VDC.</para>
 <para>
