[Swift-commit] r2948 - trunk/docs
Tue May 26 03:52:22 CDT 2009
Author: benc
Date: 2009-05-26 03:52:22 -0500 (Tue, 26 May 2009)
New Revision: 2948
Modified:
   trunk/docs/provenance.xml
Log:
remove old todo list
Modified: trunk/docs/provenance.xml
--- trunk/docs/provenance.xml	2009-05-26 08:51:36 UTC (rev 2947)
+++ trunk/docs/provenance.xml	2009-05-26 08:52:22 UTC (rev 2948)
@@ -1961,27 +1961,6 @@
 </section>
-<section><title>things to do next:</title>
-<para>over next week:</para>
-<para>i) get import scripts sorted properly (which will include
-perhaps some sorting out of the log-processing packaging too) - to the
-extent that other people could be expected to run this stuff themselves
-(so will need some basic documentation too). also should be able to
-import the results of the unit tests automatically, and perhaps stuff in the
-log repo that is done with a sufficiently recent version.</para>
-<para>ii) experiment with RDF for the q1 and q4 queries that I've
-experimented with for the others.</para>
-<para>iii) tidy up report - conclusions, recommendations, direction for
-further work, options for further work (eg more provenance? live status?
-any of the 'not this' things should be done?).</para>
-<para>
-separate out patches into different pieces - eg logging that can be
-committed now.
-</para>
-</section>
 <section><title>Processing i2u2 cosmic metadata</title>
 <para>i2u2 cosmic metadata is extracted from a VDS1 VDC.</para>
 <para>
