[Swift-commit] r2922 - trunk/docs
Wed May 13 08:48:57 CDT 2009
Author: benc
Date: 2009-05-13 08:48:57 -0500 (Wed, 13 May 2009)
New Revision: 2922
Modified:
   trunk/docs/userguide.xml
Log:
tidy since message
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-05-13 13:47:52 UTC (rev 2921)
+++ trunk/docs/userguide.xml	2009-05-13 13:48:57 UTC (rev 2922)
@@ -2166,7 +2166,7 @@
 			<para>
 <literal>trace</literal> will log its parameters. By default these will appear on both stdout
 and in the run log file. Some formatting occurs to produce the log message.
-The particular output format should not be relied upon. (new in 0.4)
+The particular output format should not be relied upon. (since Swift 0.4)
 			</para>
 		</section>
