[Swift-commit] r2921 - in trunk: docs src/org/griphyn/vdl/engine
Wed May 13 08:47:53 CDT 2009
Author: benc
Date: 2009-05-13 08:47:52 -0500 (Wed, 13 May 2009)
New Revision: 2921
Modified:
   trunk/docs/userguide.xml
   trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
Log:
remove print internal procedure which was deprecated in r1344
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-05-13 13:45:53 UTC (rev 2920)
+++ trunk/docs/userguide.xml	2009-05-13 13:47:52 UTC (rev 2921)
@@ -2162,16 +2162,6 @@
 (since Swift 0.7)
 			</para>
 		</section>
-		<section id="procedure.print"><title>print</title>
-			<para>
-Deprecated - use <literal><link linkend="procedure.trace">trace</link></literal> instead.
-			</para>
-			<para>
-print will print its parameters to stdout; but will do this at a point
-in execution that is undefined. Specifically, it will not necessarily
-wait for its parameters to be properly set.
-			</para>
-		</section>
 		<section id="procedure.trace"><title>trace</title>
 			<para>
 <literal>trace</literal> will log its parameters. By default these will appear on both stdout
Modified: trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
--- trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java	2009-05-13 13:45:53 UTC (rev 2920)
+++ trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java	2009-05-13 13:47:52 UTC (rev 2921)
@@ -116,10 +116,6 @@
 		readData2.addOutputArg(rd2OutputArg);
 		proceduresMap.put("readData2", readData2);
-		ProcedureSignature print = new ProcedureSignature("print");
-		print.setAnyNumOfInputArgs();
-		proceduresMap.put("print", print);
 		ProcedureSignature trace = new ProcedureSignature("trace");
 		trace.setAnyNumOfInputArgs();
 		proceduresMap.put("trace", trace);
