[Swift-commit] r2781 - trunk/docs
Mon Mar 30 09:52:25 CDT 2009
Author: benc
Date: 2009-03-30 09:52:24 -0500 (Mon, 30 Mar 2009)
New Revision: 2781
Modified:
   trunk/docs/userguide.xml
Log:
"since 0.9" comment for recent docs
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-03-30 14:51:50 UTC (rev 2780)
+++ trunk/docs/userguide.xml	2009-03-30 14:52:24 UTC (rev 2781)
@@ -1445,7 +1445,7 @@
   <varlistentry><term>-tui</term>
     <listitem>
-      Displays an interactive text mode monitor during a run.
+      Displays an interactive text mode monitor during a run. (since Swift 0.9)
     </listitem>
   </varlistentry>
@@ -2894,7 +2894,7 @@
 job directories appear in a different place on the worker node file system
 than on the filesystem access node, with the execution system handling
 translation of the job initial working directory. In such cases,
-<literal>relative</literal> mode must be used.
+<literal>relative</literal> mode must be used. (since Swift 0.9)
 							</para>
 						</listitem>
@@ -3042,7 +3042,7 @@
 each application execution, and will record the stdout of that command in the
 wrapper info log file for that job. This is intended to allow software
 version and other arbitrary information about the remote site to be gathered
-and returned to the submit side.
+and returned to the submit side. (since Swift 0.9)
 		</para>
 	</section>
 	<section id="sitecatalog"><title>The Site Catalog - sites.xml</title>
