[Swift-commit] r2780 - trunk/tests/language-behaviour
Mon Mar 30 09:51:50 CDT 2009
Author: benc
Date: 2009-03-30 09:51:50 -0500 (Mon, 30 Mar 2009)
New Revision: 2780
Modified:
   trunk/tests/language-behaviour/run
Log:
record timestamps in behaviour tests
Modified: trunk/tests/language-behaviour/run
--- trunk/tests/language-behaviour/run	2009-03-30 11:56:36 UTC (rev 2779)
+++ trunk/tests/language-behaviour/run	2009-03-30 14:51:50 UTC (rev 2780)
@@ -44,7 +44,7 @@
   if [ "$RESUME" == "y" ]; then
   	echo Skipping test $t
   else
-	echo Running test $t
+	echo Running test $t at $(date)
 	swift ${SWIFT_TEST_PARAMS} ${t}.swift
 	if [ "$?" -ne "0" ]; then echo "SWIFT RETURN CODE NON-ZERO - test $testfn"; exit 1; fi
 	echo expecting $EXPECTEDS
@@ -88,7 +88,7 @@
     fi
   done
-  echo "Test passed"
+  echo "Test passed at $(date)"
   if [ "$SUB" == "" ]; then
   	echo ----------===========================----------
   fi
