[Swift-commit] r2740 - SwiftApps/adem-osg
Tue Mar 24 21:41:16 CDT 2009
Author: houzx
Date: 2009-03-24 21:41:15 -0500 (Tue, 24 Mar 2009)
New Revision: 2740
Removed:
   SwiftApps/adem-osg/setup.csh
Log:
Deleting the old setup.csh
Deleted: SwiftApps/adem-osg/setup.csh
--- SwiftApps/adem-osg/setup.csh	2009-03-25 02:40:45 UTC (rev 2739)
+++ SwiftApps/adem-osg/setup.csh	2009-03-25 02:41:15 UTC (rev 2740)
@@ -1,59 +0,0 @@
-#!/bin/csh
-# set-up environment to run Adem - source me
-dir=`basename ${PWD}`
-Def_Rep="http://www.ci.uchicago.edu/~houzx/pac-cache"
-if ("X${GLOBUS_LOCATION}" == "X") then
-   echo "NO GLOBUS Error!"
- else if (${dir} != "adem-osg") then
-   echo "Please cd to adem-osg for first setup!"
-   else if ("X${ADEM_HOME}" == "X")||("${ADEM_HOME}" != "${PWD}")  then
-   setenv ADEM_HOME ${PWD}
-   setenv PATH ${PATH}:${PWD}/bin
-   endif
- endif
-endif
-#check the grid proxy
-grid-proxy-info 1>/dev/null 2>/dev/null
-if ("$?" != 0) then
-  echo "ERROR: Couldn not find a valid proxy, Please check your grid proxy!"
-  exit 1
-  else
-  timel=`grid-proxy-info  |grep timeleft |cut -d: -f2`
-  if ("$timel" -lt 1) then
-  echo "Proxy has less than 60 minutes remainging - exiting."
-  exit
-  endif
-endif
-#check pacman
-if ("X${PACMAN_LOCATION}" == "X") then
-  /bin/tar -C ${ADEM_HOME}  -zxf ${ADEM_HOME}/doc/pacman-3.21.tar.gz
-  DIR=${PWD}
-  cd ${ADEM_HOME}/pacman-3.21
-  source setup.csh 2>/dev/null
-  cd ${DIR}
-endif
-#check application software repository
-if ("X${REPOSITORY_HOME}" == "X") then
-   echo "The default application software repository is:"
-   echo "${Def_Rep}"
-   echo "Do you want to set up your own repository?y or n"
-   read response
-   if ("${response}" == "y") then
-   echo "Please input your own application software repository:"
-   read rep
-   echo "OK, you should maintain your own repository, to add,update,or remove the pacman files and software packages."
-   setenv REPOSITORY_HOME ${rep}
-   else
-   setenv REPOSITORY_HOME ${Def_Rep}
-   endif
-endif
