[Swift-commit] r2739 - SwiftApps/adem-osg
Tue Mar 24 21:40:46 CDT 2009
Author: houzx
Date: 2009-03-24 21:40:45 -0500 (Tue, 24 Mar 2009)
New Revision: 2739
Removed:
   SwiftApps/adem-osg/setup.sh
Log:
Deleting the old setup.sh
Deleted: SwiftApps/adem-osg/setup.sh
--- SwiftApps/adem-osg/setup.sh	2009-03-24 20:08:53 UTC (rev 2738)
+++ SwiftApps/adem-osg/setup.sh	2009-03-25 02:40:45 UTC (rev 2739)
@@ -1,59 +0,0 @@
-#!/bin/bash
-# set-up environment to run Adem - source me
-dir=`basename $PWD`
-Def_Rep="http://www.ci.uchicago.edu/~houzx/pac-cache"
-if [ "X${GLOBUS_LOCATION}" == "X" ]; then
-   echo "NO GLOBUS Error!"
-else if [ $dir != "adem-osg" ]; then
-   echo "Please cd to adem-osg for first setup!"
-   else if [ "X${ADEM_HOME}" == "X" ] || [ "${ADEM_HOME}" != "$PWD" ]; then
-           export ADEM_HOME=$PWD
-           export PATH=$PATH:$ADEM_HOME/bin
-        fi
-  fi
-fi
-#check the grid proxy
-grid-proxy-info 1>/dev/null 2>/dev/null
-if [ "$?" != 0 ]; then
-  echo "ERROR: Couldn not find a valid proxy, Please check your grid proxy!"
-  exit 1
-  else
-  timel=`grid-proxy-info  |grep timeleft |cut -d: -f2`
-  if [ "$timel" -lt 1 ]; then
-  echo "Warning, Proxy has less than 60 minutes remaining."
-  fi
-fi
-#check pacman
-if [ "X$PACMAN_LOCATION" == "X" ]; then
-/bin/tar -C $ADEM_HOME  -zxf $ADEM_HOME/doc/pacman-3.21.tar.gz
-DIR=$PWD
-cd $ADEM_HOME/pacman-3.21
-source setup.sh 2>/dev/null
-cd $DIR
-fi
-#check application software repository
-if [ "X$REPOSITORY_HOME" == "X" ]; then
-   echo "The default application software repository is:"
-   echo "$Def_Rep"
-   echo "Do you want to set up your own repository?y or n"
-   read response
-   if [ "$response" == "y" ];then
-   echo "Please input your own application software repository:"
-   read rep
-   echo "OK, you should maintain your own repository, to add,update,or remove the pacman files and software packages."
-   export REPOSITORY_HOME=$rep
-   else
-   export REPOSITORY_HOME=$Def_Rep
-   fi
-fi
