[Swift-commit] r2671 - trunk/src/org/griphyn/vdl/karajan/lib
Mon Mar 9 12:18:21 CDT 2009
Author: hategan
Date: 2009-03-09 12:18:20 -0500 (Mon, 09 Mar 2009)
New Revision: 2671
Added:
   trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
Log:
forgot the essential part
Added: trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
--- trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	2009-03-09 17:18:20 UTC (rev 2671)
@@ -0,0 +1,222 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Mar 21, 2005
+package org.griphyn.vdl.karajan.lib;
+import java.io.IOException;
+import java.util.ArrayList;
+import java.util.Iterator;
+import java.util.List;
+import org.apache.log4j.Logger;
+import org.globus.cog.karajan.arguments.Arg;
+import org.globus.cog.karajan.stack.VariableNotFoundException;
+import org.globus.cog.karajan.stack.VariableStack;
+import org.globus.cog.karajan.util.Identifier;
+import org.globus.cog.karajan.util.KarajanIterator;
+import org.globus.cog.karajan.util.ThreadingContext;
+import org.globus.cog.karajan.util.TypeUtil;
+import org.globus.cog.karajan.workflow.ExecutionException;
+import org.globus.cog.karajan.workflow.events.Event;
+import org.globus.cog.karajan.workflow.events.EventBus;
+import org.globus.cog.karajan.workflow.events.EventListener;
+import org.globus.cog.karajan.workflow.events.EventTargetPair;
+import org.globus.cog.karajan.workflow.events.FutureNotificationEvent;
+import org.globus.cog.karajan.workflow.futures.FutureEvaluationException;
+import org.globus.cog.karajan.workflow.futures.FutureIterator;
+import org.globus.cog.karajan.workflow.futures.FutureIteratorIncomplete;
+import org.globus.cog.karajan.workflow.nodes.AbstractParallelIterator;
+import org.griphyn.vdl.util.VDL2Config;
+public class ThrottledParallelFor extends AbstractParallelIterator {
+	public static final Logger logger = Logger
+			.getLogger(ThrottledParallelFor.class);
+	public static final int DEFAULT_MAX_THREADS = 1024;
+	public static final Arg A_NAME = new Arg.Positional("name");
+	public static final Arg A_IN = new Arg.Positional("in");
+	static {
+		setArguments(ThrottledParallelFor.class, new Arg[] { A_NAME, A_IN });
+	public static final String THREAD_COUNT = "#threadcount";
+	private int maxThreadCount = -1;
+	public void iterate(VariableStack stack, Identifier var, KarajanIterator i)
+			throws ExecutionException {
+		if (elementCount() > 0) {
+			if (logger.isDebugEnabled()) {
+				logger.debug("iterateParallel: " + stack.parentFrame());
+			stack.setVar(VAR, var);
+			setChildFailed(stack, false);
+			stack.setVar(CALLER, this);
+			initializeChannelBuffers(stack);
+			initThreadCount(stack);
+			citerate(stack, var, i);
+		else {
+			complete(stack);
+	protected void citerate(VariableStack stack, Identifier var,
+			KarajanIterator i) throws ExecutionException {
+		ThreadCount tc = getThreadCount(stack);
+		try {
+			while (i.hasNext()) {
+				Object value = tc.tryIncrement(i);
+				VariableStack copy = stack.copy();
+				copy.enter();
+				ThreadingContext.set(copy, ThreadingContext.get(copy).split(
+						i.current()));
+				setIndex(copy, getArgCount());
+				setArgsDone(copy);
+				copy.setVar(var.getName(), value);
+				addChannelBuffers(copy);
+				startElement(getArgCount(), copy);
+			int left = tc.decrement();
+			if (left == 0) {
+				complete(stack);
+		catch (FutureIteratorIncomplete fii) {
+			stack.setVar(ITERATOR, i);
+			fii.getFutureIterator().addModificationAction(
+					this,
+					new FutureNotificationEvent(ITERATE, this, fii
+							.getFutureIterator(), stack));
+	protected void iterationCompleted(VariableStack stack)
+		closeBuffers(stack);
+		stack.leave();
+		int running = tc.decrement();
+		if (running == 0) {
+			complete(stack);
+	private void initThreadCount(VariableStack stack) {
+		if (maxThreadCount < 0) {
+			try {
+				maxThreadCount = TypeUtil.toInt(VDL2Config.getConfig()
+						.getProperty("foreach.max.threads", String.valueOf(DEFAULT_MAX_THREADS)));
+			catch (IOException e) {
+				maxThreadCount = DEFAULT_MAX_THREADS;
+		stack.setVar(THREAD_COUNT, new ThreadCount(maxThreadCount));
+	private ThreadCount getThreadCount(VariableStack stack)
+			throws VariableNotFoundException {
+		return (ThreadCount) stack.getVar(THREAD_COUNT);
+	private static class ThreadCount implements FutureIterator {
+		private int maxThreadCount;
+		private int crt;
+		private List listeners;
+		public ThreadCount(int maxThreadCount) {
+			this.maxThreadCount = maxThreadCount;
+			crt = 1;
+		public synchronized Object tryIncrement(KarajanIterator i) {
+			if (crt < maxThreadCount) {
+				Object o = i.next();
+				crt++;
+				return o;
+			else {
+				throw new FutureIteratorIncomplete(this, this);
+		public synchronized int decrement() {
+			crt--;
+			notifyListeners();
+			return crt;
+		private void notifyListeners() {
+			if (listeners != null) {
+				Iterator i = listeners.iterator();
+					EventTargetPair etp = (EventTargetPair) i.next();
+					i.remove();
+					EventBus.post(etp.getTarget(), etp.getEvent());
+		public boolean hasAvailable() {
+			return false;
+		public int count() {
+			return 0;
+		public int current() {
+			return 0;
+		public Object peek() {
+			return null;
+		public boolean hasNext() {
+			return false;
+		public Object next() {
+			return null;
+		public void remove() {
+		public synchronized void addModificationAction(EventListener target,
+				Event event) {
+			if (listeners == null) {
+				listeners = new ArrayList();
+			listeners.add(new EventTargetPair(event, target));
+		public void close() {
+		public void fail(FutureEvaluationException e) {
+		public Object getValue() throws ExecutionException {
+			return null;
+		public boolean isClosed() {
+			return false;
\ No newline at end of file
