[Swift-commit] r2670 - provenancedb
Mon Mar 9 11:26:38 CDT 2009
Author: benc
Date: 2009-03-09 11:26:38 -0500 (Mon, 09 Mar 2009)
New Revision: 2670
Modified:
   provenancedb/import-all
Log:
build everylog version file in pwd rather than in the log-processing directory
Modified: provenancedb/import-all
--- provenancedb/import-all	2009-03-09 16:17:16 UTC (rev 2669)
+++ provenancedb/import-all	2009-03-09 16:26:38 UTC (rev 2670)
@@ -8,14 +8,11 @@
 source paths.source
 export PATH=$LOGDIR:$PROVDIR:$PATH
-pushd $LOGDIR
 create-everylog-vs-versions-data $LOGREPO
-popd
 # TODO better tmp handling that always using the same name in a shared
 # directory
-cp $LOGDIR/everylog-vs-versions.data /tmp/
+cp everylog-vs-versions.data /tmp/
 echo first commandline param is $1
 if [ "$1" == "rebuild" ]; then
