[Swift-commit] r2435 - trunk/docs
Sun Jan 11 05:15:00 CST 2009
Author: benc
Date: 2009-01-11 05:14:59 -0600 (Sun, 11 Jan 2009)
New Revision: 2435
Modified:
   trunk/docs/quickstartguide.xml
   trunk/docs/reallyquickstartguide.xml
   trunk/docs/userguide.xml
Log:
update docs to reflect change of cog module name from vdsk to swift
Modified: trunk/docs/quickstartguide.xml
--- trunk/docs/quickstartguide.xml	2009-01-11 11:03:51 UTC (rev 2434)
+++ trunk/docs/quickstartguide.xml	2009-01-11 11:14:59 UTC (rev 2435)
@@ -78,7 +78,7 @@
 				build instructions are available on the <ulink
 				url="http://www.ci.uchicago.edu/swift/downloads/index.php#nightly">Swift
 				downloads page</ulink>. Once built, the <filename
-				class="directory">dist/vdsk-svn</filename> directory
+				class="directory">dist/swift-svn</filename> directory
 				will contain a self-contained build which can be used in place or moved to a different location.
 				You should then proceed to the <link
 				linkend="configure">configuration section</link>.
@@ -93,16 +93,16 @@
 		<para>
 			Simply unpack the downloaded package (<filename
-			class="file">vdsk-<version>.tar.gz</filename>) into a
+			class="file">swift-<version>.tar.gz</filename>) into a
 			directory of your choice:
 <programlisting>
 <prompt>></prompt> <command>tar</command> <option>-xzvf</option> <filename
-class="file">vdsk-<version>.tar.gz</filename>
+class="file">swift-<version>.tar.gz</filename>
 </programlisting>
 			This will create a <filename
-			class="directory">vdsk-<version></filename> directory
+			class="directory">swift-<version></filename> directory
 			containing the build.
 		</para>
Modified: trunk/docs/reallyquickstartguide.xml
--- trunk/docs/reallyquickstartguide.xml	2009-01-11 11:03:51 UTC (rev 2434)
+++ trunk/docs/reallyquickstartguide.xml	2009-01-11 11:14:59 UTC (rev 2435)
@@ -40,7 +40,7 @@
 				<para>
 					Unpack it and add the <filename
-					class="directory">vdsk-xyz/bin</filename> directory to your
+					class="directory">swift-xyz/bin</filename> directory to your
 					<envar>PATH</envar>.
 				</para>
@@ -63,7 +63,7 @@
 				<para>
 					Edit <filename
-					class="file">vdsk-xyz/etc/swift.properties</filename>. You
+					class="file">swift-xyz/etc/swift.properties</filename>. You
 					should add your numeric IP address there
 					(<property>ip.address</property>=<literal>x.y.z.w</literal>).
@@ -77,7 +77,7 @@
 					are configured for local submission):
 <programlisting>
-<command>cd</command> vdsk-xyz/etc
+<command>cd</command> swift-xyz/etc
 <command>cp</command> sites.xml.example sites.xml
 <command>cp</command> tc.data.example tc.data
 </programlisting>
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-01-11 11:03:51 UTC (rev 2434)
+++ trunk/docs/userguide.xml	2009-01-11 11:14:59 UTC (rev 2435)
@@ -2730,12 +2730,12 @@
 		<para>
 with-provider-deef - build with Falkon provider deef. In order for this
 option to work, it is necessary to check out the provider-deef code in
-the cog/modules directory alongside vdsk:
+the cog/modules directory alongside swift:
 			<screen>
 $ <userinput>cd cog/modules</userinput>
 $ <userinput>svn co https://svn.ci.uchicago.edu/svn/vdl2/provider-deef</userinput>
-$ <userinput>cd ../vdsk</userinput>
+$ <userinput>cd ../swift</userinput>
 $ <userinput>ant -Dwith-provider-deef=true redist</userinput>
 			</screen>
@@ -2745,12 +2745,12 @@
 that provides delays and unreliability for the purposes of testing Swift's
 fault tolerance mechanisms. In order for this option to work, it is
 necessary to check out the provider-wonky code in the cog/modules
-directory alongside vdsk:
+directory alongside swift:
 			<screen>
 $ <userinput>svn co https://svn.ci.uchicago.edu/svn/vdl2/provider-wonky</userinput>
 $ <userinput>ant -Dwith-provider-wonky=true redist</userinput>
 			</screen>
 		</para>
