[Swift-commit] r2434 - nmi-build-test
Sun Jan 11 05:03:51 CST 2009
Author: benc
Date: 2009-01-11 05:03:51 -0600 (Sun, 11 Jan 2009)
New Revision: 2434
Modified:
   nmi-build-test/coaster
   nmi-build-test/debug-x86_64-hang
   nmi-build-test/main
   nmi-build-test/with-deef
Log:
change NMI build/test to use swift module name introduced in r2433
Modified: nmi-build-test/coaster
--- nmi-build-test/coaster	2009-01-11 11:01:41 UTC (rev 2433)
+++ nmi-build-test/coaster	2009-01-11 11:03:51 UTC (rev 2434)
@@ -2,14 +2,14 @@
 which ant
 which javac
-mv trunk cog/modules/vdsk
-cd cog/modules/vdsk/
+mv trunk cog/modules/swift
+cd cog/modules/swift/
 echo building...
 ant redist -Dwith-provider-coaster=true || exit 1
 # echo testing...
-# export PATH=`pwd`/dist/vdsk-svn/bin:$PATH
+# export PATH=`pwd`/dist/swift-svn/bin:$PATH
 # cd tests/misc
 # ./coaster.sh || exit 4
Modified: nmi-build-test/debug-x86_64-hang
--- nmi-build-test/debug-x86_64-hang	2009-01-11 11:01:41 UTC (rev 2433)
+++ nmi-build-test/debug-x86_64-hang	2009-01-11 11:03:51 UTC (rev 2434)
@@ -3,19 +3,19 @@
 which javac
 #locate ant
 #locate javac
 wget http://www.ci.uchicago.edu/~benc/tmp/more-debug-hanging-wh
 patch -p0 < more-debug-hanging-wh && echo patch was successful
 echo building...
 ant redist || exit 1
 echo testing...
-export PATH=`pwd`/dist/vdsk-svn/bin:$PATH
+export PATH=`pwd`/dist/swift-svn/bin:$PATH
 cd tests/language-behaviour
Modified: nmi-build-test/main
--- nmi-build-test/main	2009-01-11 11:01:41 UTC (rev 2433)
+++ nmi-build-test/main	2009-01-11 11:03:51 UTC (rev 2434)
@@ -3,14 +3,14 @@
 which javac
 #locate ant
 #locate javac
 echo building...
 echo testing...
 cd tests/language
 ./run || exit 2
Modified: nmi-build-test/with-deef
--- nmi-build-test/with-deef	2009-01-11 11:01:41 UTC (rev 2433)
+++ nmi-build-test/with-deef	2009-01-11 11:03:51 UTC (rev 2434)
@@ -3,10 +3,10 @@
 which javac
 #locate ant
 #locate javac
 mv provider-deef cog/modules
 echo building...
 ant -Dwith-provider-deef redist || exit 1
