[Swift-commit] r3065 - SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain
Thu Aug 6 10:56:09 CDT 2009
Author: andric
Date: 2009-08-06 10:56:09 -0500 (Thu, 06 Aug 2009)
New Revision: 3065
Modified:
   SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/PK2mediator.swift
Log:
put 'r_script' argument back in med_args. different sites (and diff versions of swift) having trouble recognizing this arg
Modified: SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/PK2mediator.swift
--- SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/PK2mediator.swift	2009-08-06 15:54:50 UTC (rev 3064)
+++ SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/PK2mediator.swift	2009-08-06 15:56:09 UTC (rev 3065)
@@ -17,7 +17,7 @@
 ## Mediator app declaration:
 app (file q_result, PeakResult outObj) run_query (string med_args, file config, PeakfitR code){
-    Mediator med_args stdout=@filename(q_result) "--r_script" @filename(code.ShellpeakMediatorPK2);
+    Mediator med_args stdout=@filename(q_result) @filename(code.ShellpeakMediatorPK2);
 ## this process sets parameters and calls Mediator:
@@ -28,7 +28,7 @@
     file q_result<single_file_mapper; file=@strcat("Qresults/",subject,"_",h,"vert",vert,".qresult")>;
     string med_args = @strcat("--user ","andric"," --conf ", @filename(config)," --db ", db," --host ", host,
         " --subject ", subject,
-        " --query ", query_outline," --r_swift_args ", @filename(outObj)," --outprefix ", theoutprefix);
+        " --query ", query_outline," --r_swift_args ", @filename(outObj)," --outprefix ", theoutprefix, " --r_script Rscripts/ShellpeakMediatorPK2.R");
     trace(med_args);
     (q_result, outObj) = run_query(med_args, config, code);
