[Swift-commit] r2823 - trunk/docs
Sat Apr 4 17:54:28 CDT 2009
Author: benc
Date: 2009-04-04 17:54:25 -0500 (Sat, 04 Apr 2009)
New Revision: 2823
Modified:
   trunk/docs/userguide.xml
Log:
more description of floats
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-04-04 22:53:35 UTC (rev 2822)
+++ trunk/docs/userguide.xml	2009-04-04 22:54:25 UTC (rev 2823)
@@ -384,7 +384,7 @@
   <tbody>
    <row><entry>int</entry><entry>integers</entry></row>
    <row><entry>string</entry><entry>strings of text</entry></row>
-   <row><entry>float</entry><entry>floating point numbers</entry></row>
+   <row><entry>float</entry><entry>floating point numbers, that behave the same as Java <literal>double</literal>s</entry></row>
    <row><entry>boolean</entry><entry>true/false</entry></row>
   </tbody>
  </tgroup>
