[Swift-commit] r2822 - trunk/docs
Sat Apr 4 17:53:40 CDT 2009
Author: benc
Date: 2009-04-04 17:53:35 -0500 (Sat, 04 Apr 2009)
New Revision: 2822
Modified:
   trunk/docs/userguide.xml
Log:
make 'since version ...' style more consistent
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-04-04 21:17:51 UTC (rev 2821)
+++ trunk/docs/userguide.xml	2009-04-04 22:53:35 UTC (rev 2822)
@@ -2041,12 +2041,9 @@
 For arrays of structs, the file should contain a heading row listing
 structure member names separated by whitespace. There should be one row
 for each element of the array, with structure member elements listed in
-the same order as the header row and separated by whitespace.
+the same order as the header row and separated by whitespace. (since Swift 0.4)
 			</para>
-			<para>
-This procedure is new in 0.4.
-			</para>
 		</section>
 		<section id="procedure.readdata2"><title>readdata2</title>
 			<para>
@@ -2082,7 +2079,7 @@
 			</para>
 			<para>
-This procedure is new in 0.7.
+(since Swift 0.7)
 			</para>
 		</section>
 		<section id="procedure.print"><title>print</title>
