[Swift-commit] r2818 - trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui
Sat Apr 4 16:15:59 CDT 2009
Author: hategan
Date: 2009-04-04 16:15:56 -0500 (Sat, 04 Apr 2009)
New Revision: 2818
Modified:
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Button.java
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Component.java
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Container.java
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/DefaultTableCellRenderer.java
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Dialog.java
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Frame.java
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LayeredContainer.java
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Screen.java
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Table.java
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/TableColumn.java
Log:
better handling of focus/focus colors
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Button.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Button.java	2009-04-04 21:15:02 UTC (rev 2817)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Button.java	2009-04-04 21:15:56 UTC (rev 2818)
@@ -15,8 +15,8 @@
 	public Button(String label) {
 		setLabel(label);
-		bgColor = ANSI.BLACK;
-		fgColor = ANSI.WHITE;
+		bgColor = ANSI.WHITE;
+		fgColor = ANSI.BLACK;
 	public Button() {
@@ -43,21 +43,22 @@
 		context.lock();
 		try {
 			context.moveTo(sx, sy);
+			context.fgColor(getFgColor());
+			context.bgColor(getBgColor());
+			context.putChar('[');
 			if (this.hasFocus()) {
-				context.putChar('[');
+			    context.bgColor(ANSI.YELLOW);
-			else {
-				context.putChar(' ');
 			context.spaces(pad);
 			twlabel.draw(context);
+			if (this.hasFocus()) {
 			context.spaces(width - 2 - pad - len);
-			if (this.hasFocus()) {
-				context.putChar(']');
-			else {
+			context.putChar(']');
 		finally {
 			context.unlock();
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Component.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Component.java	2009-04-04 21:15:02 UTC (rev 2817)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Component.java	2009-04-04 21:15:56 UTC (rev 2818)
@@ -5,12 +5,14 @@
 import java.io.IOException;
+import org.apache.log4j.Logger;
 public class Component {
     public static final int BOTTOM_LAYER = 0;
     public static final int NORMAL_LAYER = 1;
     public static final int TOP_LAYER = 2;
-    protected int x, y, width, height, bgColor, fgColor;
+    protected int x, y, width, height, bgColor, fgColor, focusedBgColor;
     protected int sx, sy;
     private boolean visible, valid, focus, focusable;
     private Screen screen;
@@ -19,6 +21,8 @@
     public Component() {
         visible = true;
+        focusable = true;
+        focusedBgColor = ANSI.YELLOW;
     protected void redraw() {
@@ -117,6 +121,14 @@
         this.fgColor = fgColor;
+    public int getFocusedBgColor() {
+        return focusedBgColor;
+    public void setFocusedBgColor(int focusedBgColor) {
+        this.focusedBgColor = focusedBgColor;
     protected void draw(ANSIContext context) throws IOException {
@@ -191,15 +203,19 @@
             if (parent.focus()) {
                 focus = parent.childFocused(this);
+            redraw();
         return focus;
     public boolean unfocus() {
-        focus = false;
-        Container parent = getParent();
-        if (parent != null) {
-            parent.childUnfocused(this);
+        if (focus) {
+            focus = false;
+            Container parent = getParent();
+            if (parent != null) {
+                parent.childUnfocused(this);
+            redraw();
         return true;
@@ -234,4 +250,17 @@
     public void setLayer(int layer) {
         this.layer = layer;
+    public boolean focusNext() {
+        return false;
+    public boolean focusFirst() {
+        if (isFocusable()) {
+            return focus();
+        else {
+            return false;
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Container.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Container.java	2009-04-04 21:15:02 UTC (rev 2817)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Container.java	2009-04-04 21:15:56 UTC (rev 2818)
@@ -9,108 +9,173 @@
 import java.util.List;
 public class Container extends Component {
-	protected List components;
-	protected Component focused, oldFocused;
+    protected List components;
+    protected Component focused, oldFocused;
+    private Boolean focusable;
     public Container() {
         components = new ArrayList();
     public void add(Component comp) {
-    	components.add(comp);
+        components.add(comp);
         comp.setParent(this);
         invalidate();
     public void remove(Component comp) {
-    	components.remove(comp);
-    	if (focused == comp) {
-    		focused = null;
-    	invalidate();
+        components.remove(comp);
+        if (focused == comp) {
+            focused = null;
+        invalidate();
+    protected void invalidate() {
+        super.invalidate();
+        focusable = null;
     public List getComponents() {
-    	return components;
+        return components;
     public void removeAll() {
-    	components.clear();
-    	invalidate();
+        components.clear();
+        invalidate();
     protected void drawTree(ANSIContext context) throws IOException {
-    	super.drawTree(context);
+        super.drawTree(context);
         Iterator i = components.iterator();
         while (i.hasNext()) {
-        	Component c = (Component) i.next();
-        	if (c.isVisible()) {
-        		drawChild(c, context);
+            Component c = (Component) i.next();
+            if (c.isVisible()) {
+                drawChild(c, context);
-    protected void drawChild(Component c, ANSIContext context) throws IOException {
-    	c.drawTree(context);
+    protected void drawChild(Component c, ANSIContext context)
+            throws IOException {
+        c.drawTree(context);
-	protected void validate() {
-		if (isValid()) {
-			return;
-		Iterator i = components.iterator();
-		boolean focus = false;
+    protected void validate() {
+        if (isValid()) {
+            return;
+        Iterator i = components.iterator();
+        boolean focus = false;
-        	if (c.hasFocus() && !hasFocus()) {
-        		focus();
+            if (c.hasFocus() && !hasFocus()) {
+                focus();
             c.validate();
         super.validate();
-	public boolean childFocused(Component component) {
-	    oldFocused = focused;
-		boolean f = true;
-		if (focused != null) {
-			f = focused.unfocus();
-			if (f) {
-				focused.focusLost();
-		if (f) {
-			focused = component;
-			focused.focusGained();
-		return f;
-	public void childUnfocused(Component component) {
+    public boolean childFocused(Component component) {
+        oldFocused = focused;
+        boolean f = true;
+        if (focused != null) {
+            f = focused.unfocus();
+            if (f) {
+                focused.focusLost();
+        if (f) {
+            focused = component;
+            focused.focusGained();
+        return f;
+    public void childUnfocused(Component component) {
         if (oldFocused != null && oldFocused != component) {
             oldFocused.focus();
-	public boolean keyboardEvent(Key key) {
-		if (key.modALT() || key.isFunctionKey()) {
-			while (i.hasNext()) {
-				if (((Component) i.next()).keyboardEvent(key)) {
-					return true;
-			return false;
-		else if (focused != null) {
-			return focused.keyboardEvent(key);
-		else {
-			return false;
-	public Component getFocusedComponent() {
-		return focused;
+    public boolean keyboardEvent(Key key) {
+        if (key.modALT() || key.isFunctionKey()) {
+            while (i.hasNext()) {
+                if (((Component) i.next()).keyboardEvent(key)) {
+                    return true;
+            return false;
+        else if (focused != null) {
+            return focused.keyboardEvent(key);
+        else {
+            return false;
+    public Component getFocusedComponent() {
+        return focused;
+    public boolean unfocus() {
+        if (focused != null && !focused.unfocus()) {
+            return false;
+        return super.unfocus();
+        Iterator j = components.iterator();
+        while (j.hasNext()) {
+            Component comp = (Component) j.next();
+            if (comp.focusFirst()) {
+                return true;
+        return false;
+        if (focused == null) {
+            return focusFirst();
+        else if (focused.focusNext()) {
+            return true;
+            if (i.next() == focused) {
+                    Component comp = (Component) i.next();
+                    if (comp.isFocusable()) {
+                        comp.focus();
+                        return true;
+                return false;
+        return false;
+    public boolean isFocusable() {
+        Boolean f = focusable;
+        if (f != null) {
+            return f.booleanValue();
+            if (((Component) i.next()).isFocusable()) {
+                focusable = Boolean.TRUE;
+                return true;
+        //focusable = Boolean.FALSE;
+        return false;
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/DefaultTableCellRenderer.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/DefaultTableCellRenderer.java	2009-04-04 21:15:02 UTC (rev 2817)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/DefaultTableCellRenderer.java	2009-04-04 21:15:56 UTC (rev 2818)
@@ -18,19 +18,25 @@
     public Component getComponent(Table table, Object value,
             boolean isSelected, boolean hasFocus, int row, int column) {
-            setColors(table, isSelected);
+            setColors(table, isSelected, hasFocus);
             label.setText(String.valueOf(value));
             return label;
-    private void setColors(Table table, boolean selected) {
+    private void setColors(Table table, boolean selected, boolean hasFocus) {
         if (!selected) {
             label.setBgColor(table.getBgColor());
             label.setFgColor(table.getFgColor());
         else {
-            label.setBgColor(table.getHighlightBgColor());
-            label.setFgColor(table.getHighlightFgColor());
+            if (hasFocus) {
+                label.setBgColor(table.getFocusedBgColor());
+                label.setFgColor(table.getFgColor());
+            else {
+                label.setBgColor(table.getHighlightBgColor());
+                label.setFgColor(table.getHighlightFgColor());
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Dialog.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Dialog.java	2009-04-04 21:15:02 UTC (rev 2817)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Dialog.java	2009-04-04 21:15:56 UTC (rev 2818)
@@ -3,47 +3,48 @@
 package org.griphyn.vdl.karajan.monitor.monitors.ansi.tui;
+import java.util.Iterator;
 public class Dialog extends Frame {
-	private Component sfocus;
+    private Component sfocus;
-	public Dialog() {
-		bgColor = ANSI.WHITE;
-		fgColor = ANSI.BLACK;
-		setFilled(true);
+    public Dialog() {
+        setFilled(true);
-	public void display(Screen screen) {
-		sfocus = screen.getFocusedComponent();
-		screen.add(this);
-		focus();
+    public void display(Screen screen) {
+        sfocus = screen.getFocusedComponent();
+        screen.add(this);
+        focusFirst();
-	public void close() {
-		getScreen().remove(this);
-		setVisible(false);
-		if (sfocus != null) {
-			sfocus.focus();
+    public void close() {
+        getScreen().remove(this);
+        setVisible(false);
+        if (sfocus != null) {
+            sfocus.focus();
-	public void center(Container c) {
-		x = (c.getWidth() - width) / 2;
-		y = (c.getHeight() - height) / 2;
+    public void center(Container c) {
+        x = (c.getWidth() - width) / 2;
+        y = (c.getHeight() - height) / 2;
-		if (key.getKey() == Key.ESC) {
-			close();
-			return true;
-		else {
-			return super.keyboardEvent(key);
+        if (key.getKey() == Key.ESC) {
+            close();
+            return true;
+        else {
+            return super.keyboardEvent(key);
-    public static int displaySimpleDialog(Screen screen, String title, String msg,
-            String[] buttons) {
+    public static int displaySimpleDialog(Screen screen, String title,
+            String msg, String[] buttons) {
         final Dialog d = new Dialog();
         d.setTitle(title);
         Label l = new Label();
@@ -68,7 +69,8 @@
                     d.close();
             d.add(bs[i]);
         d.center(screen);
@@ -84,4 +86,25 @@
         return r[0];
+            return true;
+                        return true;
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Frame.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Frame.java	2009-04-04 21:15:02 UTC (rev 2817)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Frame.java	2009-04-04 21:15:56 UTC (rev 2818)
@@ -21,11 +21,11 @@
 			context.bgColor(bgColor);
 			context.fgColor(fgColor);
 			if (filled) {
-				context.filledFrame(sx, sy, width, height);
+				context.filledRect(sx + 1, sy + 1, width - 2, height - 2);
-			else {
-				context.frame(sx, sy, width, height);
+			context.frame(sx, sy, width, height);
+			context.bgColor(bgColor);
 			if (title != null) {
 				int tl = title.length() + 2;
 				int space = width - tl;
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LayeredContainer.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LayeredContainer.java	2009-04-04 21:15:02 UTC (rev 2817)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LayeredContainer.java	2009-04-04 21:15:56 UTC (rev 2818)
@@ -114,6 +114,20 @@
 			return keyboardEvent(key, TOP_LAYER) || keyboardEvent(key, NORMAL_LAYER)
 					|| keyboardEvent(key, BOTTOM_LAYER);
+		else if (key.equals(Key.TAB)) {
+		        focusFirst();
+		    else {
+		    	if (focused.keyboardEvent(key)) {
+		    	    return true;
+		    	else {
+		    		focused.focusNext();
+		    return true;
@@ -122,7 +136,50 @@
-	protected boolean keyboardEvent(Key key, int layer) {
+	    for (int i = 0; i < layers.length; i++) {
+	        if (layers[i] != null) {
+	            Iterator j = layers[i].iterator();
+	            if (j.hasNext()) {
+	                if (((Component) j.next()).focusFirst()) {
+	                    return true;
+	    return false;
+        boolean found = false;
+            return true;
+                    if (found) {
+                            return true;
+                    if (j.next() == focused) {
+                        found = true;
+        return false;
+    protected boolean keyboardEvent(Key key, int layer) {
 		if (layers[layer] == null) {
 			return false;
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Screen.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Screen.java	2009-04-04 21:15:02 UTC (rev 2817)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Screen.java	2009-04-04 21:15:56 UTC (rev 2818)
@@ -42,7 +42,7 @@
 			drawTree(context);
 			if (status != null) {
-				context.moveTo(0, height);
+				context.moveTo(1, height);
 				context.bgColor(ANSI.RED);
 				context.fgColor(ANSI.YELLOW);
 				context.text(status);
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Table.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Table.java	2009-04-04 21:15:02 UTC (rev 2817)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Table.java	2009-04-04 21:15:56 UTC (rev 2818)
@@ -210,4 +210,18 @@
     public int getHighlightBgColor() {
         return fgColor;
+        return true;
+        focus();
+        return true;
+        return false;
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/TableColumn.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/TableColumn.java	2009-04-04 21:15:02 UTC (rev 2817)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/TableColumn.java	2009-04-04 21:15:56 UTC (rev 2818)
@@ -28,7 +28,7 @@
         int fr = table.getFirstRow();
         for (int i = 0; i < Math.min(model.getRowCount(), height - 2); i++) {
             Component comp = table.getCellRenderer().getComponent(table,
-                model.getValueAt(i + fr, index), i + fr == selectedRow, false,
+                model.getValueAt(i + fr, index), i + fr == selectedRow, getParent().hasFocus(),
                 i + fr, index);
             comp.setAbsoluteLocation(sx, sy + i + 2);
             comp.setSize(getWidth(), 1);
