[Swift-commit] r2817 - trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui
Sat Apr 4 16:15:03 CDT 2009
Author: hategan
Date: 2009-04-04 16:15:02 -0500 (Sat, 04 Apr 2009)
New Revision: 2817
Modified:
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Key.java
Log:
I'm beginning to dislike automatic formatting
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Key.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Key.java	2009-04-04 21:13:59 UTC (rev 2816)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Key.java	2009-04-04 21:15:02 UTC (rev 2817)
@@ -7,184 +7,188 @@
 import java.util.Map;
 public class Key {
-	public static final int KEY_PRESSED = 0;
-	public static final int MOD_ALT = 0x01;
-	public static final int MOD_CTRL = 0x02;
-	public static final int MOD_SHIFT = 0x03;
-	public static final int KEYPAD = 0x1000;
-	public static final int KEYPAD2 = 0x2000;
-	public static final int FN1 = 0x3100;
-	public static final int FN10 = 0x3200;
-	public static final int F1 = FN1 + 0;
-	public static final int F2 = FN1 + 1;
-	public static final int F3 = FN1 + 2;
-	public static final int F4 = FN1 + 3;
-	public static final int F5 = FN1 + 4;
-	public static final int F6 = FN1 + 6;
-	public static final int F7 = FN1 + 7;
-	public static final int F8 = FN1 + 8;
-	public static final int F9 = FN1 + 9;
-	public static final int F10 = FN10 + 0;
-	public static final int F11 = FN10 + 1;
-	public static final int F12 = FN10 + 2;
-	public static final int UP = KEYPAD + 65;
-	public static final int DOWN = KEYPAD + 66;
-	public static final int RIGHT = KEYPAD + 67;
-	public static final int LEFT = KEYPAD + 68;
-	public static final int PGDN = KEYPAD2 + 54;
-	public static final int PGUP = KEYPAD2 + 53;
-	public static final int HOME = KEYPAD2 + 55;
-	public static final int END = KEYPAD2 + 56;
-	public static final int INS = KEYPAD2 + 51;
-	public static final int DEL = KEYPAD2 + 52;
-	public static final int LF = 0x0a;
-	public static final int CR = 0x0d;
-	public static final int BACKSPACE = 0x7f;
-	public static final int ESC = 0x1b;
-	public static final int TAB = 0x09;
-	private static Map names;
-	private static void putName(int key, String name) {
-		names.put(new Integer(key), name);
-	static {
-		names = new HashMap();
-		putName(CR, "CR");
-		putName(LF, "LF");
-		putName(F1, "F1");
-		putName(F2, "F2");
-		putName(F3, "F3");
-		putName(F4, "F4");
-		putName(F5, "F5");
-		putName(F6, "F6");
-		putName(F7, "F7");
-		putName(F8, "F8");
-		putName(F9, "F9");
-		putName(F10, "F10");
-		putName(F11, "F11");
-		putName(F12, "F12");
-		putName(DOWN, "DOWN");
-		putName(UP, "UP");
-		putName(LEFT, "LEFT");
-		putName(RIGHT, "RIGHT");
-		putName(BACKSPACE, "BACKSPACE");
-		putName(ESC, "ESC");
-		putName(PGDN, "PGDN");
-		putName(PGUP, "PGUP");
-		putName(HOME, "HOME");
-		putName(END, "END");
-		putName(INS, "INS");
-		putName(DEL, "DEL");
-		putName(TAB, "TAB");
-	private final int type;
-	private final int modifiers;
-	private final int key;
-	public Key(int key) {
-		this(0, key);
-	public Key(int modifiers, int key) {
-		this.type = KEY_PRESSED;
-		this.modifiers = modifiers;
-		this.key = key;
+    public static final int KEY_PRESSED = 0;
+    public static final int MOD_ALT = 0x01;
+    public static final int MOD_CTRL = 0x02;
+    public static final int MOD_SHIFT = 0x03;
-	public Key(int code0, int code1, int code2) {
-		this.modifiers = code2;
-		this.key = code0 * 0xff + code1;
+    public static final int KEYPAD = 0x1000;
+    public static final int KEYPAD2 = 0x2000;
+    public static final int FN1 = 0x3100;
+    public static final int FN10 = 0x3200;
-	public int getKey() {
-		return key;
+    public static final int F1 = FN1 + 0;
+    public static final int F2 = FN1 + 1;
+    public static final int F3 = FN1 + 2;
+    public static final int F4 = FN1 + 3;
+    public static final int F5 = FN1 + 4;
+    public static final int F6 = FN1 + 6;
+    public static final int F7 = FN1 + 7;
+    public static final int F8 = FN1 + 8;
+    public static final int F9 = FN1 + 9;
+    public static final int F10 = FN10 + 0;
+    public static final int F11 = FN10 + 1;
+    public static final int F12 = FN10 + 2;
-	public int getModifiers() {
-		return modifiers;
+    public static final int UP = KEYPAD + 65;
+    public static final int DOWN = KEYPAD + 66;
+    public static final int RIGHT = KEYPAD + 67;
+    public static final int LEFT = KEYPAD + 68;
+    public static final int PGDN = KEYPAD2 + 54;
+    public static final int PGUP = KEYPAD2 + 53;
+    public static final int HOME = KEYPAD2 + 55;
+    public static final int END = KEYPAD2 + 56;
+    public static final int INS = KEYPAD2 + 51;
+    public static final int DEL = KEYPAD2 + 52;
-	public int getType() {
-		return type;
-	public boolean modALT() {
-		return (modifiers & MOD_ALT) != 0;
-	public boolean modCTRL() {
-		return (modifiers & MOD_CTRL) != 0;
-	public boolean modSHIFT() {
-		return (modifiers & MOD_SHIFT) != 0;
-	public boolean isEnter() {
-	    return modifiers == 0 && (key == CR || key == LF);
-	public String toString() {
-		StringBuffer sb = new StringBuffer();
-		if (modCTRL()) {
-			sb.append("CTRL+");
-		if (modALT()) {
-			sb.append("ALT+");
-		if (key < 128 && key >= 32) {
-			sb.append((char) key);
-		else {
-			if (modSHIFT()) {
-				sb.append("SHIFT+");
-			String name = (String) names.get(new Integer(key));
-			if (name != null) {
-				sb.append(name);
-			else {
-				sb.append('#');
-				sb.append(key);
-		sb.append("-"+modifiers);
-		sb.append("-"+key);
-		return sb.toString();
+    public static final int LF = 0x0a;
+    public static final int CR = 0x0d;
+    public static final int BACKSPACE = 0x7f;
+    public static final int ESC = 0x1b;
+    public static final int TAB = 0x09;
-	public boolean equals(Object obj) {
-		if (obj instanceof Key) {
-			Key other = (Key) obj;
-			return modifiers == other.modifiers && key == other.key;
-		else {
-			return false;
-	public boolean equals(int key) {
-	    if (this.key == key && modifiers == 0) {
-	        return true;
-	    else {
-	        return false;
+    private static Map names;
-	public int hashCode() {
-		return modifiers + key;
+    private static void putName(int key, String name) {
+        names.put(new Integer(key), name);
-	public boolean isFunctionKey() {
-		return key >= F1 && key <= F9;
+    static {
+        names = new HashMap();
+        putName(CR, "CR");
+        putName(LF, "LF");
+        putName(F1, "F1");
+        putName(F2, "F2");
+        putName(F3, "F3");
+        putName(F4, "F4");
+        putName(F5, "F5");
+        putName(F6, "F6");
+        putName(F7, "F7");
+        putName(F8, "F8");
+        putName(F9, "F9");
+        putName(F10, "F10");
+        putName(F11, "F11");
+        putName(F12, "F12");
+        putName(DOWN, "DOWN");
+        putName(UP, "UP");
+        putName(LEFT, "LEFT");
+        putName(RIGHT, "RIGHT");
+        putName(BACKSPACE, "BACKSPACE");
+        putName(ESC, "ESC");
+        putName(PGDN, "PGDN");
+        putName(PGUP, "PGUP");
+        putName(HOME, "HOME");
+        putName(END, "END");
+        putName(INS, "INS");
+        putName(DEL, "DEL");
+        putName(TAB, "TAB");
+    private final int type;
+    private final int modifiers;
+    private final int key;
+    public Key(int key) {
+        this(0, key);
+    public Key(int modifiers, int key) {
+        this.type = KEY_PRESSED;
+        this.modifiers = modifiers;
+        this.key = key;
+    public Key(int code0, int code1, int code2) {
+        this.modifiers = code2;
+        this.key = code0 * 0xff + code1;
+    public int getKey() {
+        return key;
+    public int getModifiers() {
+        return modifiers;
+    public int getType() {
+        return type;
+    public boolean modALT() {
+        return (modifiers & MOD_ALT) != 0;
+    public boolean modCTRL() {
+        return (modifiers & MOD_CTRL) != 0;
+    public boolean modSHIFT() {
+        return (modifiers & MOD_SHIFT) != 0;
+    public boolean isEnter() {
+        return modifiers == 0 && (key == CR || key == LF);
+    public String toString() {
+        StringBuffer sb = new StringBuffer();
+        if (modCTRL()) {
+            sb.append("CTRL+");
+        if (modALT()) {
+            sb.append("ALT+");
+        if (key < 128 && key >= 32) {
+            sb.append((char) key);
+        else {
+            if (modSHIFT()) {
+                sb.append("SHIFT+");
+            String name = (String) names.get(new Integer(key));
+            if (name != null) {
+                sb.append(name);
+            else {
+                sb.append('#');
+                sb.append(key);
+        sb.append("-" + modifiers);
+        sb.append("-" + key);
+        return sb.toString();
+    public char getChar() {
+        return (char) key;
+    public boolean equals(Object obj) {
+        if (obj instanceof Key) {
+            Key other = (Key) obj;
+            return modifiers == other.modifiers && key == other.key;
+        else {
+            return false;
+    public boolean equals(int key) {
+        if (this.key == key && modifiers == 0) {
+            return true;
+        else {
+            return false;
+    public int hashCode() {
+        return modifiers + key;
+    public boolean isFunctionKey() {
+        return key >= F1 && key <= F9;
