[Swift-commit] r2173 - trunk/docs
Mon Aug 4 09:33:57 CDT 2008
Author: benc
Date: 2008-08-04 09:33:56 -0500 (Mon, 04 Aug 2008)
New Revision: 2173
Modified:
   trunk/docs/userguide.xml
Log:
a bit more info about the external mapper
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2008-08-04 14:09:37 UTC (rev 2172)
+++ trunk/docs/userguide.xml	2008-08-04 14:33:56 UTC (rev 2173)
@@ -960,6 +960,12 @@
 		</listitem>
 		</itemizedlist>
 	</listitem>
+	<listitem>
+The output of the executable should consist of two columns of data, separated
+by a space. The first column should be the path of the mapped variable,
+in SwiftScript syntax (for example [2] means the 2nd element of an
+array) or the symbol $ to represent the root of the mapped variable.
+	</listitem>
 	<listitem> Example:
 With the following in mapper.sh,
