[Swift-commit] r2172 - provider-wonky/src/org/globus/cog/abstraction/impl/execution/wonky
Mon Aug 4 09:09:38 CDT 2008
Author: benc
Date: 2008-08-04 09:09:37 -0500 (Mon, 04 Aug 2008)
New Revision: 2172
Modified:
   provider-wonky/src/org/globus/cog/abstraction/impl/execution/wonky/JobSubmissionTaskHandler.java
Log:
strictattr and permitattr=<attr> options for wonky sites
Modified: provider-wonky/src/org/globus/cog/abstraction/impl/execution/wonky/JobSubmissionTaskHandler.java
--- provider-wonky/src/org/globus/cog/abstraction/impl/execution/wonky/JobSubmissionTaskHandler.java	2008-08-02 21:06:38 UTC (rev 2171)
+++ provider-wonky/src/org/globus/cog/abstraction/impl/execution/wonky/JobSubmissionTaskHandler.java	2008-08-04 14:09:37 UTC (rev 2172)
@@ -96,13 +96,27 @@
                 spec = (JobSpecification) this.task.getSpecification();
             } catch (Exception e) {
                 throw new IllegalSpecException(
-                        "Exception while retreiving Job Specification", e);
+                        "Exception while retrieving Job Specification", e);
             if (logger.isDebugEnabled()) {
                 logger.debug(spec.toString());
+            Collection attributeNames = spec.getAttributeNames();
+            Iterator attributeIterator = attributeNames.iterator();
+            if(siteOptions.contains("strictattr")) {
+                logger.debug("Strict attribute checking is enabled");
+                while(attributeIterator.hasNext()) {
+                    String attrName = (String)attributeIterator.next();
+                    if(!siteOptions.contains("permitattr=" + attrName)) {
+                        logger.error("Job specification attribute was passed that should not have been: "+attrName);
+                        this.task.setStatus(Status.FAILED);
+                        return;
             try {
                 if (logger.isInfoEnabled()) {
                     logger.info("Submitting task " + task);
