sieve-dev Sieve examples
Yaakoub El Khamra yye00 at tacc.utexas.edu
Wed May 12 09:43:37 CDT 2010
So I am trying to build the sieve examples and have run into interesting
errors. I only managed to get the watson example to compile but it segfaults
when I run it. All others refuse to compile with varying errors ranging from
missing header files to:
error: invalid initialization of reference of type
‘ALE::Obj<ALE::IMesh<ALE::LabelSifter<int, int,
ALE::malloc_allocator<ALE::NewSifterDef::Arrow<int, int> > > >,
ALE::malloc_allocator<ALE::IMesh<ALE::LabelSifter<int, int,
ALE::malloc_allocator<ALE::NewSifterDef::Arrow<int, int> > > > > >&’ from
expression of type ‘ALE::Obj<ALE::Mesh, ALE::malloc_allocator<ALE::Mesh> >’
I did compile with fiat and the generator but obviously I am missing
something. Any thoughts/recommendations are greatly appreciated.
Regards
Yaakoub El Khamra
URL: <http://lists.mcs.anl.gov/pipermail/sieve-dev/attachments/20100512/973842d5/attachment.htm>
More information about the sieve-dev mailing list
