sieve-dev Obtain all elements that has some given face/edge/vertex
Shi Jin jinzishuai at gmail.com
Tue Feb 5 11:23:01 CST 2008
Hi there,
Suppose I am given some point in the sieve data structure, such as a face,
edge or vertex. Is there a function that can return a list of owning
elements, faces or edges? I know there is a nCone() function that can return
a list of vertexes, edges or faces for a given element. But I wonder whether
the reverse is possible.
Thank you very much.
Sincerely,
Shi Jin, Ph.D.
http://www.ualberta.ca/~sjin1/
URL: <https://lists.mcs.anl.gov/mailman/private/sieve-dev/attachments/20080205/3e15347c/attachment.htm>
More information about the sieve-dev mailing list
