[petsc-users] KSP has an extra iteration when use shell matrix
Barry Smith bsmith at petsc.dev
Tue Jan 30 20:18:35 CST 2024
   It is not running an extra KSP iteration. This "extra" matmult is normal and occurs in many of the SNESLineSearchApply_* functions, for example, https://petsc.org/release/src/snes/linesearch/impls/bt/linesearchbt.c.html#SNESLineSearchApply_BT It is used to decide if the Newton step results in sufficient decrease of the function value.
  Barry
> On Jan 30, 2024, at 3:19 PM, Yi Hu <y.hu at mpie.de> wrote:
> Hello Barry,
> Thanks for your reply. The monitor options are fine. I actually meant my modification of snes tutorial ex1f.F90 does not work and has some unexpected behavior. I basically wanted to test if I can use a shell matrix as my jacobian (code is here https://github.com/hyharry/small_petsc_test/blob/master/test_shell_jac/ex1f.F90). After compile my modified version and run with these monitor options, it gives me the following,
>  ( in rhs )
>  ( leave rhs )
>   0 SNES Function norm 6.041522986797e+00
>  ++++++++++++ in jac shell +++++++++++
>     0 KSP Residual norm 6.041522986797e+00
>  === start mymult ===
>  === done mymult ===
>     1 KSP Residual norm 5.065392549852e-16
>   Linear solve converged due to CONVERGED_RTOL iterations 1
>  === done mymult ===
>  ( in rhs )
>  ( leave rhs )
>   1 SNES Function norm 3.512662245652e+00
>     0 KSP Residual norm 3.512662245652e+00
>  === done mymult ===
>     1 KSP Residual norm 6.230314124713e-16
>  === done mymult ===
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>   2 SNES Function norm 8.969285922373e-01
>     0 KSP Residual norm 8.969285922373e-01
>  === done mymult ===
>     1 KSP Residual norm 0.000000000000e+00
>   Linear solve converged due to CONVERGED_ATOL iterations 1
>  === done mymult ===
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>   3 SNES Function norm 4.863816734540e-01
>     0 KSP Residual norm 4.863816734540e-01
>  === done mymult ===
>  === done mymult ===
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>   4 SNES Function norm 3.512070785520e-01
>     0 KSP Residual norm 3.512070785520e-01
>  === done mymult ===
>  === done mymult ===
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>   5 SNES Function norm 2.769700293115e-01
>     0 KSP Residual norm 2.769700293115e-01
>  === done mymult ===
>     1 KSP Residual norm 1.104778916974e-16
>  === done mymult ===
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>   6 SNES Function norm 2.055345318150e-01
>     0 KSP Residual norm 2.055345318150e-01
>  === done mymult ===
>  === done mymult ===
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>   7 SNES Function norm 1.267482220786e-01
>     0 KSP Residual norm 1.267482220786e-01
>  === done mymult ===
>     1 KSP Residual norm 1.498679601680e-17
>  === done mymult ===
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>   8 SNES Function norm 3.468150619264e-02
>     0 KSP Residual norm 3.468150619264e-02
>  === done mymult ===
>     1 KSP Residual norm 5.944160522951e-18
>  === done mymult ===
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>  ( in rhs )
>  ( leave rhs )
>  === done mymult ===
> Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations 8
> Number of SNES iterations =     8
> After each "Linear solve converged due to CONVERGED_ATOL iterations", the code starts to do mymult again. So I thought it did an extra (unwanted) KSP iteration. I would like to ask if this extra iteration could be disabled, or maybe I am wrong about it.
> Best regards,
> Yi
> On 1/30/24 18:35, Barry Smith wrote:
>>   How do I see a difference? What does "hence ruin my previous converged KSP result" mean? A different answer at the end of the KSP solve?
>> $ ./joe > joe.basic
>> ~/Src/petsc/src/ksp/ksp/tutorials (barry/2023-09-15/fix-log-pcmpi=) arch-fix-log-pcmpi
>> $ ./joe -ksp_monitor -ksp_converged_reason -snes_monitor > joe.monitor
>> $ diff joe.basic joe.monitor
>> 0a1,36
>> >   Linear solve converged due to CONVERGED_RTOL_NORMAL iterations 1
>> >     1 KSP Residual norm 1.535110861002e-17
>>> On Jan 30, 2024, at 11:19 AM, Yi Hu <y.hu at mpie.de> <mailto:y.hu at mpie.de> wrote:
>>> Dear PETSc team,
>>> I am still trying to sort out my previous thread https://lists.mcs.anl.gov/pipermail/petsc-users/2024-January/050079.html using a minimal working example. However, I encountered another problem. Basically I combined the basic usage of SNES solver and shell matrix and tried to make it work. The jacobian of my snes is replaced by a customized MATOP_MULT. The minimal example code can be viewed here https://github.com/hyharry/small_petsc_test/blob/master/test_shell_jac/ex1f.F90
>>> When running with -ksp_monitor -ksp_converged_reason, it shows an extra mymult step, and hence ruin my previous converged KSP result. Implement a customized converged call-back also does not help. I am wondering how to skip this extra ksp iteration. Could anyone help me on this?
>>> Thanks for your help.
>>> Best wishes,
>>> Yi
>>> Stay up to date and follow us on LinkedIn, Twitter and YouTube.
>>> Max-Planck-Institut für Eisenforschung GmbH
>>> Max-Planck-Straße 1
>>> D-40237 Düsseldorf
>>> Handelsregister B 2533
>>> Amtsgericht Düsseldorf
>>> Geschäftsführung
>>> Prof. Dr. Gerhard Dehm
>>> Prof. Dr. Jörg Neugebauer
>>> Prof. Dr. Dierk Raabe
>>> Dr. Kai de Weldige
>>> Ust.-Id.-Nr.: DE 11 93 58 514
>>> Steuernummer: 105 5891 1000
>>> Please consider that invitations and e-mails of our institute are
>>> only valid if they end with …@mpie.de.
>>> If you are not sure of the validity please contact rco at mpie.de <mailto:rco at mpie.de>
>>> Bitte beachten Sie, dass Einladungen zu Veranstaltungen und E-Mails
>>> aus unserem Haus nur mit der Endung …@mpie.de gültig sind.
>>> In Zweifelsfällen wenden Sie sich bitte an rco at mpie.de <mailto:rco at mpie.de>
> Max-Planck-Straße 1
> D-40237 Düsseldorf
> Geschäftsführung
> Dr. Kai de Weldige
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240130/602b266c/attachment-0001.html>
