[petsc-users] Unique number in each element of a DMPlex mesh
Berend van Wachem berend.vanwachem at ovgu.de
Mon Jan 22 12:58:30 CST 2024
Dear Matt,
Thanks for your quick response.
I have a DMPlex with a polyhedral mesh, and have defined a number of vectors with data at the cell center. I have generated data
for a number of timesteps, and I write the data for each point to a file together with the (x,y,z) co-ordinate of the cell center.
When I want to do a restart from the DMPlex, I recreate the DMplex with the polyhedral mesh, redistribute it, and for each cell
center find the corresponding (x,y,z) co-ordinate and insert the data that corresponds to it. This is quite expensive, as it
means I need to compare doubles very often.
But reading your response, this may not be a bad way of doing it?
Berend.
On 1/22/24 18:58, Matthew Knepley wrote:
> On Mon, Jan 22, 2024 at 10:49 AM Berend van Wachem <berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>> wrote:
>     Dear Petsc-Team,
>     Is there a good way to define a unique integer number in each element
>     (e.g. a cell) of a DMPlex mesh, which is in the same location,
>     regardless of the number of processors or the distribution of the mesh
>     over the processors?
>     So, for instance, if I have a DMPlex box mesh, the top-right-front
>     corner element (e.g. cell) will always have the same unique number,
>     regardless of the number of processors the mesh is distributed over?
>     I want to be able to link the results I have achieved with a mesh from
>     DMPlex on a certain number of cores to the same mesh from a DMPlex on a
>     different number of cores.
>     Of course, I could make a tree based on the distance of each element to
>     a certain point (based on the X,Y,Z co-ordinates of the element), and go
>     through this tree in the same way and define an integer based on this,
>     but that seems rather cumbersome.
> I think this is harder than it sounds. The distance will not work because it can be very degenerate.
> You could lexicographically sort the coordinates, but this is hard in parallel. It is fine if you are willing
> to gather everything on one process. You could put down a p4est, use the Morton order to number them since this is stable for a
> given refinement. And then within each box lexicographically sort the centroids. This is definitely cumbersome, but I cannot
> think of anything else. This also might have parallel problems since you need to know how much overlap you need to fill each box.
>    Thanks,
>        Matt
>     Thanks and best regards, Berend.
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to
> which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
