[petsc-users] Parallel processes run significantly slower
Steffen Wilksen | Universitaet Bremen swilksen at itp.uni-bremen.de
Fri Jan 12 08:43:09 CST 2024
  Thank you for your feedback.
@Stefano: the use of my communicator was intentional, since I later
intend to distribute M independent calculations to N processes, each
process then only needing to do M/N calculations. Of course I don't
expect speed up in my example since the number of calculations is
constant and not dependent on N, but I would hope that the time each
process takes does not increase too drastically with N.
@Barry: I tried to do the STREAMS benchmark, these are my results:
1  23467.9961   Rate (MB/s) 1
2  26852.0536   Rate (MB/s) 1.1442
3  29715.4762   Rate (MB/s) 1.26621
4  34132.2490   Rate (MB/s) 1.45442
5  34924.3020   Rate (MB/s) 1.48817
6  34315.5290   Rate (MB/s) 1.46223
7  33134.9545   Rate (MB/s) 1.41192
8  33234.9141   Rate (MB/s) 1.41618
9  32584.3349   Rate (MB/s) 1.38846
10  32582.3962   Rate (MB/s) 1.38838
11  32098.2903   Rate (MB/s) 1.36775
12  32064.8779   Rate (MB/s) 1.36632
13  31692.0541   Rate (MB/s) 1.35044
14  31274.2421   Rate (MB/s) 1.33263
15  31574.0196   Rate (MB/s) 1.34541
16  30906.7773   Rate (MB/s) 1.31698
I also attached the resulting plot. As it seems, I get very bad MPI
speedup (red curve, right?), even decreasing if I use too many
threads. I don't fully understand the reasons given in the discussion
you linked since this is all very new to me, but I take that this is a
problem with my computer which I can't easily fix, right?
----- Message from Barry Smith <bsmith at petsc.dev> ---------
   Date: Thu, 11 Jan 2024 11:56:24 -0500
Subject: Re: [petsc-users] Parallel processes run significantly slower
     To: Steffen Wilksen | Universitaet Bremen <swilksen at itp.uni-bremen.de>
     Cc: PETSc users list <petsc-users at mcs.anl.gov>
>    Take a look at the discussion
> in https://petsc.gitlab.io/-/petsc/-/jobs/5814862879/artifacts/public/html/manual/streams.html and I suggest you run the streams benchmark from the branch barry/2023-09-15/fix-log-pcmpi on your machine to get a baseline for what kind of speedup you can expect.
>       Then let us know your thoughts.
>      Barry
>> On Jan 11, 2024, at 11:37 AM, Stefano Zampini
>> <stefano.zampini at gmail.com> wrote:
>>              You are creating the matrix on the wrong communicator
>> if you want it parallel. You are using PETSc.COMM_SELF
>>                On Thu, Jan 11, 2024, 19:28 Steffen Wilksen |
>> Universitaet Bremen <swilksen at itp.uni-bremen.de> wrote:
>>> _Hi all,
>>> I'm trying to do repeated matrix-vector-multiplication of large
>>> sparse matrices in python using petsc4py. Even the most simple
>>> method of parallelization, dividing up the calculation to run on
>>> multiple processes indenpendtly, does not seem to give a
>>> singnificant speed up for large matrices. I constructed a minimal
>>> working example, which I run using
>>> mpiexec -n N python parallel_example.py,
>>> where N is the number of processes. Instead of taking
>>> approximately the same time irrespective of the number of
>>> processes used, the calculation is much slower when starting more
>>> MPI processes. This translates to little to no speed up when
>>> splitting up a fixed number of calculations over N processes. As
>>> an example, running with N=1 takes 9s, while running with N=4
>>> takes 34s. When running with smaller matrices, the problem is not
>>> as severe (only slower by a factor of 1.5 when setting
>>> MATSIZE=1e+5 instead of MATSIZE=1e+6). I get the same problems
>>> when just starting the script four times manually without using MPI.
>>> I attached both the script and the log file for running the script
>>> with N=4. Any help would be greatly appreciated. Calculations are
>>> done on my laptop, arch linux version 6.6.8 and PETSc version
>>> 3.20.2.
>>> Kind Regards
>>> Steffen_
_----- End message from Barry Smith <bsmith at petsc.dev> -----_
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240112/b5d2304e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240112/b5d2304e/attachment-0001.png>
