[petsc-users] Help with compiling PETSc on Summit with gcc 12.1.0
Barry Smith bsmith at petsc.dev
Fri Feb 9 16:09:49 CST 2024
 error while loading shared libraries: libmpi_ibm_usempif08.so: cannot open shared object file: No such file or directory
 So using the mpif90 does not work because it links a shared library that cannot be found at run time.
 Perhaps that library is only visible on the bach nodes. You can tryed adding -with-batch=0 to the ./configure options
  Barry
> On Feb 9, 2024, at 5:01 PM, Zhang, Chonglin <chonglin.zhang at und.edu> wrote:
> Dear PETSc developers,
> I am trying to compile PETSc on Summit with gcc 12.1.0 and spectrum-mpi 10.4.0.6, but encountered the following configuration issues:
>                       Configuring PETSc to compile on your system
> TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:1271)        *******************************************************************************
>                     OSError while running ./configure
> Cannot run executables created with FC. If this machine uses a batch system
> to submit jobs you will need to configure using ./configure with the additional option  --with-batch.
>  Otherwise there is problem with the compilers. Can you compile and run code with your compiler 'mpif90'?
> Also attached is the configure.log file. Could you help with this issue?
> Thanks,
> Chonglin
> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240209/0af000b4/attachment.html>
