[petsc-users] Help with compiling PETSc on Summit with gcc 12.1.0
Zhang, Chonglin chonglin.zhang at und.edu
Fri Feb 9 16:01:58 CST 2024
Dear PETSc developers,
I am trying to compile PETSc on Summit with gcc 12.1.0 and spectrum-mpi 10.4.0.6, but encountered the following configuration issues:
                      Configuring PETSc to compile on your system
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:1271)        *******************************************************************************
                    OSError while running ./configure
Cannot run executables created with FC. If this machine uses a batch system
to submit jobs you will need to configure using ./configure with the additional option  --with-batch.
 Otherwise there is problem with the compilers. Can you compile and run code with your compiler 'mpif90'?
Also attached is the configure.log file. Could you help with this issue?
Chonglin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240209/92d790db/attachment-0001.html>
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240209/92d790db/attachment-0001.obj>
