[petsc-users] Using PETSc GPU backend
Sat Apr 13 14:04:05 CDT 2024
On Fri, Apr 12, 2024 at 8:19 PM Ng, Cho-Kuen via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Mark. The FEM problem is of high-frequency Helmholtz type for the Maxwell
> equation. The combination "-ksp_type groppcg -pc_type gamg" worked for this
> small problem and the results agreed well with those obtained from the
> direct solver
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> Mark.
> direct solver MUMPS. However, this ksp-pc combination failed to converge
> for much larger problem sizes. What would be a good combination to solve
> this kind of large-scale problems where direct solvers would not be able to
> solve?
Solving high frequency Helmholtz is a hard research problem. There are no
easy answers. I know of no
real solutions for C0 FEM. it seems to be a bad discretization for this
from the start. I have not seen anything reliable that is not mostly
direct, but this is not what I do for a living so something might exist,
although not in any publicly available software.
     Matt
> Thanks,
> Cho
> *From:* Mark Adams <mfadams at lbl.gov>
> *Sent:* Friday, April 12, 2024 4:52 PM
> *To:* Barry Smith <bsmith at petsc.dev>
> *Cc:* Ng, Cho-Kuen <cho at slac.stanford.edu>; petsc-users <
> petsc-users at mcs.anl.gov>; Jacob Faibussowitsch <jacob.fai at gmail.com>
> *Subject:* Re: [petsc-users] Using PETSc GPU backend
> As Barry said, this is a bit small but the performance looks reasonable.
> The solver does very badly, mathematically.
> I would try hypre to get another data point.
> You could also try 'cg' to check that the pipelined version is not a
> problem.
> Mark
> On Fri, Apr 12, 2024 at 3:54 PM Barry Smith <bsmith at petsc.dev> wrote:
> 800k is a pretty small problem for GPUs. We would need to see the runs
> with output from -ksp_view -log_view to see if the timing results are
> reasonable. On Apr 12, 2024, at 1: 48 PM, Ng, Cho-Kuen <cho@ slac.
> stanford. edu> wrote: I performed
>   We would need to see the runs with output from -ksp_view -log_view to
> see if the timing results are reasonable.
> On Apr 12, 2024, at 1:48 PM, Ng, Cho-Kuen <cho at slac.stanford.edu> wrote:
> I performed tests on comparison using KSP with and without cuda backend on
> NERSC's Perlmutter. For a finite element solve with 800k degrees of
> freedom, the best times obtained using MPI and MPI+GPU were
> o MPI - 128 MPI tasks, 27 s
> o MPI+GPU - 4 MPI tasks, 4 GPU's, 32 s
> Is that the performance one would expect using the hybrid mode of
> computation. Attached image shows the scaling on a single node.
> Thanks,
> Cho
> *From:* Ng, Cho-Kuen <cho at slac.stanford.edu>
> *Sent:* Saturday, August 12, 2023 8:08 AM
> *To:* Jacob Faibussowitsch <jacob.fai at gmail.com>
> *Cc:* Barry Smith <bsmith at petsc.dev>; petsc-users <petsc-users at mcs.anl.gov
> Thanks Jacob.
> *From:* Jacob Faibussowitsch <jacob.fai at gmail.com>
> *Sent:* Saturday, August 12, 2023 5:02 AM
> *To:* Ng, Cho-Kuen <cho at slac.stanford.edu>
> > Can petsc show the number of GPUs used?
> -device_view
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> > On Aug 12, 2023, at 00:53, Ng, Cho-Kuen via petsc-users <
> > Barry,
> > I tried again today on Perlmutter and running on multiple GPU nodes
> worked. Likely, I had messed up something the other day. Also, I was able
> to have multiple MPI tasks on a GPU using Nvidia MPS. The petsc output
> shows the number of MPI tasks:
> > KSP Object: 32 MPI processes
> > Thanks,
> > Cho
> > From: Barry Smith <bsmith at petsc.dev>
> > Sent: Wednesday, August 9, 2023 4:09 PM
> > To: Ng, Cho-Kuen <cho at slac.stanford.edu>
> > Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> > Subject: Re: [petsc-users] Using PETSc GPU backend
> >   We would need more information about "hanging". Do PETSc examples and
> tiny problems "hang" on multiple nodes? If you run with -info what are the
> last messages printed? Can you run with a debugger to see where it is
> "hanging"?
> >> On Aug 9, 2023, at 5:59 PM, Ng, Cho-Kuen <cho at slac.stanford.edu> wrote:
> >> Barry and Matt,
> >> Thanks for your help. Now I can use petsc GPU backend on Perlmutter: 1
> node, 4 MPI tasks and 4 GPUs. However, I ran into problems with multiple
> nodes: 2 nodes, 8 MPI tasks and 8 GPUs. The run hung on KSPSolve. How can I
> fix this?
> >> Best,
> >> Cho
> >> Sent: Monday, July 17, 2023 6:58 AM
> >>  The examples that use DM, in particular DMDA all trivially support
> using the GPU with -dm_mat_type aijcusparse -dm_vec_type cuda
> >>> On Jul 17, 2023, at 1:45 AM, Ng, Cho-Kuen <cho at slac.stanford.edu>
> wrote:
> >>> Barry,
> >>> Thank you so much for the clarification.
> >>> I see that ex104.c and ex300.c use  MatXAIJSetPreallocation(). Are
> there other tutorials available?
> >>> Cho
> >>> Sent: Saturday, July 15, 2023 8:36 AM
> >>>      Cho,
> >>>     We currently have a crappy API for turning on GPU support, and our
> documentation is misleading in places.
> >>>     People constantly say "to use GPU's with PETSc you only need to
> use -mat_type aijcusparse (for example)" This is incorrect.
> >>>  This does not work with code that uses the convenience Mat
> constructors such as MatCreateAIJ(), MatCreateAIJWithArrays etc. It only
> works if you use the constructor approach of MatCreate(), MatSetSizes(),
> MatSetFromOptions(), MatXXXSetPreallocation(). ...  Similarly you need to
> use VecCreate(), VecSetSizes(), VecSetFromOptions() and -vec_type cuda
> >>>    If you use DM to create the matrices and vectors then you can use
> >>>    Sorry for the confusion.
> >>>    Barry
> >>>> On Jul 15, 2023, at 8:03 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> >>>> On Sat, Jul 15, 2023 at 1:44 AM Ng, Cho-Kuen <cho at slac.stanford.edu>
> wrote:
> >>>> Matt,
> >>>> After inserting 2 lines in the code:
> >>>>   ierr =
> MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
> >>>>   ierr = MatSetFromOptions(A);CHKERRQ(ierr);
> >>>>   ierr = MatCreateAIJ(PETSC_COMM_WORLD,mlocal,mlocal,m,n,
> d_nz,PETSC_NULL,o_nz,PETSC_NULL,&A);;CHKERRQ(ierr);
> >>>> "There are no unused options." However, there is no improvement on
> the GPU performance.
> >>>> 1. MatCreateAIJ() sets the type, and in fact it overwrites the Mat
> you created in steps 1 and 2. This is detailed in the manual.
> >>>> 2. You should replace MatCreateAIJ(), with MatSetSizes() before
> MatSetFromOptions().
> >>>>   THanks,
> >>>>     Matt
> >>>>  Thanks,
> >>>> Cho
> >>>>  From: Matthew Knepley <knepley at gmail.com>
> >>>> Sent: Friday, July 14, 2023 5:57 PM
> >>>> Cc: Barry Smith <bsmith at petsc.dev>; Mark Adams <mfadams at lbl.gov>;
> >>>>  On Fri, Jul 14, 2023 at 7:57 PM Ng, Cho-Kuen <cho at slac.stanford.edu>
> wrote:
> >>>> I managed to pass the following options to PETSc using a GPU node on
> Perlmutter.
> >>>>     -mat_type aijcusparse -vec_type cuda -log_view -options_left
> >>>> Below is a summary of the test using 4 MPI tasks and 1 GPU per task.
> >>>> o #PETSc Option Table entries:
> >>>> -log_view
> >>>>    -options_left
> >>>>    -vec_type cuda
> >>>>    #End of PETSc Option Table entries
> >>>>    WARNING! There are options you set that were not used!
> >>>>    WARNING! could be spelling mistake, etc!
> >>>>    There is one unused database option. It is:
> >>>>    Option left: name:-mat_type value: aijcusparse
> >>>> The -mat_type option has not been used. In the application code, we
> use
> >>>> If you create the Mat this way, then you need MatSetFromOptions() in
> order to set the type from the command line.
> >>>>   Thanks,
> >>>>      Matt
> >>>>  o The percent flops on the GPU for KSPSolve is 17%.
> >>>> In comparison with a CPU run using 16 MPI tasks, the GPU run is an
> order of magnitude slower. How can I improve the GPU performance?
> >>>> Thanks,
> >>>> Cho
> >>>>  From: Ng, Cho-Kuen <cho at slac.stanford.edu>
> >>>> Sent: Friday, June 30, 2023 7:57 AM
> >>>> To: Barry Smith <bsmith at petsc.dev>; Mark Adams <mfadams at lbl.gov>
> >>>> Cc: Matthew Knepley <knepley at gmail.com>; petsc-users at mcs.anl.gov <
> >>>>  Barry, Mark and Matt,
> >>>> Thank you all for the suggestions. I will modify the code so we can
> pass runtime options.
> >>>> Cho
> >>>> Sent: Friday, June 30, 2023 7:01 AM
> >>>> To: Mark Adams <mfadams at lbl.gov>
> >>>> Cc: Matthew Knepley <knepley at gmail.com>; Ng, Cho-Kuen <
> cho at slac.stanford.edu>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> >>>>   Note that options like -mat_type aijcusparse  -vec_type cuda only
> work if the program is set up to allow runtime swapping of matrix and
> vector types. If you have a call to MatCreateMPIAIJ() or other specific
> types then then these options do nothing but because Mark had you use
> -options_left the program will tell you at the end that it did not use the
> option so you will know.
> >>>>> On Jun 30, 2023, at 9:30 AM, Mark Adams <mfadams at lbl.gov> wrote:
> >>>>> PetscCall(PetscInitialize(&argc, &argv, NULL, help)); gives us the
> args and you run:
> >>>>> a.out -mat_type aijcusparse -vec_type cuda -log_view -options_left
> >>>>> Mark
> >>>>> On Fri, Jun 30, 2023 at 6:16 AM Matthew Knepley <knepley at gmail.com>
> wrote:
> >>>>> On Fri, Jun 30, 2023 at 1:13 AM Ng, Cho-Kuen via petsc-users <
> >>>>> Mark,
> >>>>> The application code reads in parameters from an input file, where
> we can put the PETSc runtime options. Then we pass the options to
> PetscInitialize(...). Does that sounds right?
> >>>>> PETSc will read command line argument automatically in
> PetscInitialize() unless you shut it off.
> >>>>>   Thanks,
> >>>>>     Matt
> >>>>>  Cho
> >>>>> Sent: Thursday, June 29, 2023 8:32 PM
> >>>>>  Mark,
> >>>>> Thanks for the information. How do I put the runtime options for the
> executable, say, a.out, which does not have the provision to append
> arguments? Do I need to change the C++ main to read in the options?
> >>>>> Cho
> >>>>>  From: Mark Adams <mfadams at lbl.gov>
> >>>>> Sent: Thursday, June 29, 2023 5:55 PM
> >>>>>  Run with options: -mat_type aijcusparse -vec_type cuda -log_view
> -options_left
> >>>>> The last column of the performance data (from -log_view) will be the
> percent flops on the GPU. Check that that is > 0.
> >>>>> The end of the output will list the options that were used and
> options that were _not_ used (if any). Check that there are no options left.
> >>>>> Mark
> >>>>> On Thu, Jun 29, 2023 at 7:50 PM Ng, Cho-Kuen via petsc-users <
> >>>>> I installed PETSc on Perlmutter using "spack install
> petsc+cuda+zoltan" and used it by "spack load petsc/fwge6pf". Then I
> compiled the application code (purely CPU code) linking to the petsc
> package, hoping that I can get performance improvement using the petsc GPU
> backend. However, the timing was the same using the same number of MPI
> tasks with and without GPU accelerators. Have I missed something in the
> process, for example, setting up PETSc options at runtime to use the GPU
> backend?
> >>>>> Thanks,
> >>>>> Cho
> >>>>> What most experimenters take for granted before they begin their
> experiments lead.
> >>>>> -- Norbert Wiener
> >>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eg-3VACvaflfdBfbxZoYCH53G1IX8r45qgpJlLNf-5DmCA76FwHJE8L8Wi4YY5HS--UbBRgFmMuKY7bvm-c0$
> <https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fMikK_wvRIVkv5jLV6EHt_rPhWLibqlxAAYjRVMbAEGOUp417LWCH59TvzCtcD3j4dOd4xR_tUy2MRnqU1N7kew$>
> experiments lead.
> >>>> -- Norbert Wiener
> experiments lead.
> >>>> -- Norbert Wiener
> wrote:
> >>> Barry,
> >>> Cho
> >>>      Cho,
> >>>    Barry
> wrote:
> >>>> Matt,
> >>>>   ierr =
> >>>>   THanks,
> >>>>     Matt
> >>>>  Thanks,
> >>>> Cho
> Perlmutter.
> >>>> -log_view
> >>>>    -options_left
> >>>>    -vec_type cuda
> use
> >>>>   Thanks,
> >>>>      Matt
> >>>> Thanks,
> >>>> Cho
> >>>> Cho
> args and you run:
> >>>>> Mark
> >>>>> Mark,
> >>>>>   Thanks,
> >>>>>     Matt
> >>>>>  Cho
> >>>>>  Mark,
> >>>>> Cho
> -options_left
> >>>>> Mark
> backend?
> >>>>> Thanks,
> >>>>> Cho
> experiments lead.
> >>>>> -- Norbert Wiener
> experiments lead.
> >>>> -- Norbert Wiener
> experiments lead.
> >>>> -- Norbert Wiener
> <Untitled.png>
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eg-3VACvaflfdBfbxZoYCH53G1IX8r45qgpJlLNf-5DmCA76FwHJE8L8Wi4YY5HS--UbBRgFmMuKY7bvm-c0$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eg-3VACvaflfdBfbxZoYCH53G1IX8r45qgpJlLNf-5DmCA76FwHJE8L8Wi4YY5HS--UbBRgFmMuKY5RLdH2L$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240413/8f605b57/attachment-0001.html>
