[petsc-users] Compiling PETSc with strumpack in ORNL Frontier
Vanella, Marcos (Fed) marcos.vanella at nist.gov
Fri Apr 5 14:53:55 CDT 2024
Hi Barry, thank you. Attached is the compressed config.log. I'm using the following modules (gnu):
module load PrgEnv-gnu
module load cray-mpich
module load amd-mixed/5.4.0
export MPICH_GPU_SUPPORT_ENABLED=1
Plus PETSC_DIR, PETSC_ARCH defined.
Thank you for your time,
Marcos
Sent: Friday, April 5, 2024 3:46 PM
To: Vanella, Marcos (Fed) <marcos.vanella at nist.gov>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; Reuben D. Budiardja <reubendb at ornl.gov>
Subject: Re: [petsc-users] Compiling PETSc with strumpack in ORNL Frontier
   Please send the entire configure.log
On Apr 5, 2024, at 3:42 PM, Vanella, Marcos (Fed) via petsc-users <petsc-users at mcs.anl.gov> wrote:
This Message Is From an External Sender
This message came from outside your organization.
Hi all, we are trying to compile PETSc in Frontier using the structured matrix hierarchical solver strumpack, which uses GPU and might be a good candidate for our Poisson discretization.
The list of libs I used for PETSc in this case is:
$./configure COPTFLAGS="-O3" CXXOPTFLAGS="-O3" FOPTFLAGS="-O3" FCOPTFLAGS="-O3" HIPOPTFLAGS="-O3 --offload-arch=gfx90a" --with-debugging=0 --with-cc=cc --with-cxx=CC --with-fc=ftn --with-hip --with-hip-arch=gfx908 --with-hipc=hipcc   --LIBS="-L${MPICH_DIR}/lib -lmpi ${CRAY_XPMEM_POST_LINK_OPTS} -lxpmem ${PE_MPICH_GTL_DIR_amd_gfx90a} ${PE_MPICH_GTL_LIBS_amd_gfx90a}" --download-kokkos --download-kokkos-kernels --download-suitesparse --download-hypre --download-superlu_dist --download-strumpack --download-metis --download-slate --download-magma --download-parmetis --download-ptscotch --download-zfp --download-butterflypack --with-openmp-dir=/opt/cray/pe/gcc/12.2.0/snos --download-scalapack --download-cmake --force
I'm getting an error at configure time:
      Trying to download https://urldefense.us/v3/__https://github.com/liuyangzhuan/ButterflyPACK__;!!G_uCfscf7eWS!ZsbcxsTeA5Gnj5SGJGmQ5agJcly9NSQOGKVARBNIlbC_FhaDeJ8zsJzk9Jt9fGJphrID6po6I8VKO0CIj2utu6d2Z7k7ky1W$ <https://urldefense.us/v3/__https://github.com/liuyangzhuan/ButterflyPACK__;!!G_uCfscf7eWS!cW5KuKKMbmDa8n59SJGArXdSxVT_-V0qH3vt1-LE-CAr4wShO2pTXN3GvI0bVCwUh6RWH6z2URqBczHnVEyXXKAJ2LN7JnSj$> for BUTTERFLYPACK
             Configuring BUTTERFLYPACK with CMake; this may take several minutes
            Compiling and installing BUTTERFLYPACK; this may take several minutes
            Trying to download https://urldefense.us/v3/__https://github.com/pghysels/STRUMPACK__;!!G_uCfscf7eWS!ZsbcxsTeA5Gnj5SGJGmQ5agJcly9NSQOGKVARBNIlbC_FhaDeJ8zsJzk9Jt9fGJphrID6po6I8VKO0CIj2utu6d2Z7Uw2Qob$ <https://urldefense.us/v3/__https://github.com/pghysels/STRUMPACK__;!!G_uCfscf7eWS!cW5KuKKMbmDa8n59SJGArXdSxVT_-V0qH3vt1-LE-CAr4wShO2pTXN3GvI0bVCwUh6RWH6z2URqBczHnVEyXXKAJ2FeUr7dA$> for STRUMPACK
               Configuring STRUMPACK with CMake; this may take several minutes
              Compiling and installing STRUMPACK; this may take several minutes
           UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
                               Error running make on  STRUMPACK
 Looking in the configure.log file I see error like this related to strumpack compilation:
/opt/cray/pe/craype/2.7.19/bin/CC -D__HIP_PLATFORM_AMD__=1 -D__HIP_PLATFORM_HCC__=1 -Dstrumpack_EXPORTS -I/autofs/nccs-svm1_home1/vanellam/Software/petsc/arch-linux-frontier-opt-gcc-direct/externalpackages/git.strumpack/src -I/autofs/nccs-svm1_home1/vanellam/Software/petsc/arch-linux-frontier-opt-gcc-direct/externalpackages/git.strumpack/petsc-build -isystem /autofs/nccs-svm1_home1/vanellam/Software/petsc/arch-linux-frontier-opt-gcc-direct/include -isystem /opt/rocm-5.4.0/include -isystem /opt/rocm-5.4.0/hip/include -isystem /opt/rocm-5.4.0/llvm/lib/clang/15.0.0/.. -Wno-lto-type-mismatch -Wno-psabi -O3 -fPIC -fopenmp -Wno-lto-type-mismatch -Wno-psabi -O3 -fPIC -fopenmp -fPIC -Wall -Wno-overloaded-virtual -fopenmp -x hip --offload-arch=gfx900 --offload-arch=gfx906 --offload-arch=gfx908 --offload-arch=gfx90a --offload-arch=gfx1030 -MD -MT CMakeFiles/strumpack.dir/src/clustering/NeighborSearch.cpp.o -MF CMakeFiles/strumpack.dir/src/clustering/NeighborSearch.cpp.o.d -o CMakeFiles/strumpack.dir/src/clustering/NeighborSearch.cpp.o -c /autofs/nccs-svm1_home1/vanellam/Software/petsc/arch-linux-frontier-opt-gcc-direct/externalpackages/git.strumpack/src/clustering/NeighborSearch.cpp
gmake[2]: Leaving directory '/autofs/nccs-svm1_home1/vanellam/Software/petsc/arch-linux-frontier-opt-gcc-direct/externalpackages/git.strumpack/petsc-build'
gmake[1]: Leaving directory '/autofs/nccs-svm1_home1/vanellam/Software/petsc/arch-linux-frontier-opt-gcc-direct/externalpackages/git.strumpack/petsc-build'
stdout:
g++: error: unrecognized command-line option '--offload-arch=gfx900'
It seems the configure is picking up CC (g++) instead of hipcc as the compiler for strumpack.
I wonder if anyone has come across this issue or has any suggestions?
Thanks!
Marcos
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240405/4fd8b43d/attachment-0001.html>
Type: application/x-gzip
Desc: configure.log.gz
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240405/4fd8b43d/attachment-0001.gz>
