[petsc-users] I cannot find my libpetsc.a in my installation pets-3.4.5
Ivan Luthfi ivanluthfi5 at gmail.com
Mon Sep 25 19:49:18 CDT 2023
Sorry, In the petsc_lib i only found out the libpetsc.so, but not
libpetsc.a,
are they functionality the same ?
thank you for your recommendation, i will try as your recommendation step
by step, because the code uses some deprecated function that I have to
changed to be compiled in the latest version
On Tue, Sep 26, 2023 at 8:44 AM Satish Balay <balay at mcs.anl.gov> wrote:
> We generally recommend getting a basic build going for such use case -
> and then migrate it to latest version as old versions have more issues
> [as you might be encountering now]
> Also - you haven't responded to my follow-up regarding the issue you
> are encountering.
> If you are having build issues - you might want to recheck the
> installation instructions (for petsc-3.4) - and send us relevant logs.
> Satish
> On Tue, 26 Sep 2023, Ivan Luthfi wrote:
> > the reason I install the old version is because i try to run an old code
> > file that was compiled with the same version
> > On Tue, Sep 26, 2023 at 4:20 AM Satish Balay <balay at mcs.anl.gov> wrote:
> > > What are you looking at? Send 'ls' from PETSC_DIR/PETSC_ARCH/lib
> > > Perhaps its a shared library build - and you have libpetsc.so?
> > > BTW: the current release is 3.19 - and you are attempting to build a
> super
> > > old version 3.4.
> > > We recommend using the latest version to avoid build and other
> > > compatibility issues.
> > > Satish
> > > > Dear developers,
> > > > I cannot find libpetsc.a in my library.
> > > > Do you have any suggestion how can I figure this out.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230926/528deae1/attachment.html>
