[petsc-users] I cannot find my libpetsc.a in my installation pets-3.4.5
Mon Sep 25 19:44:13 CDT 2023
We generally recommend getting a basic build going for such use case -
and then migrate it to latest version as old versions have more issues
[as you might be encountering now]
Also - you haven't responded to my follow-up regarding the issue you
are encountering.
If you are having build issues - you might want to recheck the
installation instructions (for petsc-3.4) - and send us relevant logs.
Satish
On Tue, 26 Sep 2023, Ivan Luthfi wrote:
> the reason I install the old version is because i try to run an old code
> file that was compiled with the same version
> On Tue, Sep 26, 2023 at 4:20 AM Satish Balay <balay at mcs.anl.gov> wrote:
> > What are you looking at? Send 'ls' from PETSC_DIR/PETSC_ARCH/lib
> > Perhaps its a shared library build - and you have libpetsc.so?
> > BTW: the current release is 3.19 - and you are attempting to build a super
> > old version 3.4.
> > We recommend using the latest version to avoid build and other
> > compatibility issues.
> > Satish
> > > Dear developers,
> > > I cannot find libpetsc.a in my library.
> > > Do you have any suggestion how can I figure this out.
