[petsc-users] Is precondition works for ill-conditioned jacobian matrix
Zhang, Hong hzhang at mcs.anl.gov
Thu Sep 14 10:05:06 CDT 2023
Gong Ding,
When you use a LU solver, the preconditioner M = inv(LU) = inv (J) on theory. I suspect your jacobian evaluation by 64bit might be inaccurate. What LU solver did you use? Run your code with option '-snes_view -snes_monitor -ksp_monitor' and compare the displays.
Hong
From: petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Mark Adams <mfadams at lbl.gov>
Sent: Thursday, September 14, 2023 5:35 AM
To: Gong Ding <gongding at cn.cogenda.com>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Is precondition works for ill-conditioned jacobian matrix
I would first verify that you are happy with the solution that works.
Next, I would worry about losing accuracy in computing M*J, but you could try it and search for any related work. There may be some tricks.
And MUMPS is good at high accuracy, you might try that and if it fails look at the MUMPS docs for any flags for high-accuracy.
Good luck,
On Thu, Sep 14, 2023 at 5:35 AM Gong Ding <gongding at cn.cogenda.com<mailto:gongding at cn.cogenda.com>> wrote:
Hi all
I find such a nonlinear problem, the jacobian matrix is ill conditioned.
Solve the jacobian matrix by 64bit LU  solver, the Newton method failed
to convergence.
However, when solve the jacobian matrix by 128bit LU solver , Newton
iteration will convergence.
I think this phenomena indicate that , the jacobian matrix is ill
conditioned.
The question is, if I do a precondition as M*J*dx = -M*f(x), here M is
the precondition matrix, . then I solve the matrix A=M*J by a LU solver.
Can I expect that solve A=M*J has a better precision result that help
the convergence of Newton iteration?
Gong Ding
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230914/b0481278/attachment.html>
