[petsc-users] Non-linear solve: DIVERGED_LINE_SEARCH
Thu Sep 7 13:27:46 CDT 2023
On Thu, Sep 7, 2023 at 10:18 AM Karthikeyan Chockalingam - STFC UKRI <
karthikeyan.chockalingam at stfc.ac.uk> wrote:
> Yes, I had to zero both the Jacobian and Residual which fixed the SNES
> convergence problem!
> This is my first time solving using SNES. From the tutorial
> https://petsc4py.readthedocs.io/en/stable/manual/snes/
> I didn’t notice the Jacobian and Residual had to be zeroed.
Yes, these examples are all FD so the entries are not added to, but set
directly. The FEM examples do this zeroing out in the wrapper functions
like DMComputeResidualLocal, so it is hard to see.
     Matt
> Thank you.
> Best,
> Karthik.
> *From: *Matthew Knepley <knepley at gmail.com>
> *Date: *Thursday, 7 September 2023 at 14:32
> *To: *Chockalingam, Karthikeyan (STFC,DL,HC) <
> *Cc: *Stefano Zampini <stefano.zampini at gmail.com>, petsc-users at mcs.anl.gov
> <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Non-linear solve: DIVERGED_LINE_SEARCH
> On Thu, Sep 7, 2023 at 9:28 AM Karthikeyan Chockalingam - STFC UKRI <
> Thank you for your response.
> I will test the Jacobian.
> The linear solve in the second step convergences. Is it possible that
> Jacobian had been zeroed out?
> I think you miss my point. Suppose you did not zero out the Jacobian when
> you started adding entries. Then you will get something close to twice the
> value. The linear system will solve fine, but the sep would be wrong.
>   Thanks,
>      Matt
> Best,
> Karthik.
> *Date: *Thursday, 7 September 2 ot023 at 14:19
> On Thu, Sep 7, 2023 at 8:49 AM Karthikeyan Chockalingam - STFC UKRI via
> petsc-users <petsc-users at mcs.anl.gov> wrote:
> I just noticed that the line search diverges even for the linear Poisson
> equation (where the Jacobian is a constant). I am not sure, what I am doing
> wrong.
> You need to test the Jacobian. We have facilities for this. Run using
>   --snes_test_jacobian
> This will tell you at each step whether the Jacobian matches the finite
> difference approximant. It looks like your Jacobian at the second step is
> wrong. Is it possible that you are not zeroing out the matrix before adding
> in updates? That would make the second step wrong.
>   Thanks,
>      Matt
> Best,
> Karthik.
> *From: *Chockalingam, Karthikeyan (STFC,DL,HC) <
> *Date: *Thursday, 7 September 2023 at 12:19
> *To: *Stefano Zampini <stefano.zampini at gmail.com>
> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> I am trying to solve the non-linear scalar problem
> -\nabla \cdot \big( (1+u^2)\nabla u\big)=f
> Using finite element formulation.
> The linear iteration converged – does that mean my Jacobian is correct??
> I am hoping the non-linear residual goes down to 1-e11.
> Kind regards,
> Karthik.
> *From: *Stefano Zampini <stefano.zampini at gmail.com>
> *Date: *Thursday, 7 September 2023 at 11:49
> The solver did not diverge.
> It was the line search that was not able to make further progress in
> minimizing the 2-norm of the residual.
> This is common in nonlinear solvers. It would help if you tell us what you
> are trying to solve.
> Note that at the first step, your residual norm is already 1.e-6. What
> kind of accuracy do you want?
> Il giorno gio 7 set 2023 alle ore 13:08 Karthikeyan Chockalingam - STFC
> UKRI via petsc-users <petsc-users at mcs.anl.gov> ha scritto:
> Hello,
> The non-linear solution diverged. The final solution seems right and I
> believe the Jacobian is correct (not 100% certain).
> I am not sure if I doing something wrong in the solver setting.
>  0 SNES Function norm 3.890991210938e-03
>     0 KSP Residual norm 9.037762538598e+00
>     1 KSP Residual norm 2.120375403775e-01
>     2 KSP Residual norm 5.155439334511e-03
>     3 KSP Residual norm 1.394364169369e-04
>     4 KSP Residual norm 9.233543407204e-06
>   Linear solve converged due to CONVERGED_RTOL iterations 4
>       Line search: Using full step: fnorm 3.890991210938e-03 gnorm
> 7.701511565083e-06
>   1 SNES Function norm 7.701511565083e-06
>     0 KSP Residual norm 5.630229687829e-03
>     1 KSP Residual norm 1.030475601271e-04
>     2 KSP Residual norm 2.576454714319e-06
>     3 KSP Residual norm 6.669316846898e-08
>     4 KSP Residual norm 3.215810984829e-09
>       Line search: gnorm after quadratic fit 1.805500533481e-05
>       Line search: Cubic step no good, shrinking lambda, current gnorm
> 2.563759884284e-05 lambda=3.0804668685096816e-02
> 3.332721829751e-05 lambda=3.0804668685096817e-03
> 4.102754045833e-05 lambda=3.0804668685096822e-04
> 4.872893294880e-05 lambda=3.0804668685096822e-05
> 5.643043250787e-05 lambda=3.0804668685096822e-06
> 6.413194279696e-05 lambda=3.0804668685096827e-07
> 7.183345417492e-05 lambda=3.0804668685096828e-08
> 7.953496567312e-05 lambda=3.0804668685096829e-09
> 8.723647719173e-05 lambda=3.0804668685096831e-10
> 9.493798871875e-05 lambda=3.0804668685096832e-11
> 1.026395002516e-04 lambda=3.0804668685096835e-12
> 1.103410117889e-04 lambda=3.0804668685096835e-13
>       Line search: unable to find good step length! After 12 tries
>       Line search: fnorm=7.7015115650831560e-06,
> gnorm=1.1034101178892401e-04, ynorm=6.2052357872955976e-03,
> minlambda=9.9999999999999998e-13, lambda=3.0804668685096835e-13, initial
> slope=-5.9313318983096354e-11
> Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations 1
> Thank you for your help.
> Kind regards,
> Karthik.
> *Dr. Karthik Chockalingam*
> Senior Research Software Engineer
> High Performance Systems Engineering Group
> Hartree Centre | Science and Technology Facilities Council
>  *Error! Filename not specified.*
> Stefano
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230907/3b0f3f14/attachment-0001.html>
