[petsc-users] Error while building PETSc with MATLAB
INTURU SRINIVAS 20PHD0548 inturu.srinivas2020 at vitstudent.ac.in
Sat Sep 2 02:05:57 CDT 2023
Based on the suggestions given by Sathish, I have tried to configure petsc
3.13.4 with Matlab-R2020b. But, it was not successful. After running make
-j 10 test command I have got the following error message.
not ok tao_leastsquares_tutorials_matlab-matlab_ls_test # Error code: 124
# Running problem 5
# [0]PETSC ERROR: --------------------- Error Message
# [0]PETSC ERROR: Error in external library
# [0]PETSC ERROR: Unable to start MATLAB engine on
# [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
# [0]PETSC ERROR: Petsc Release Version 3.13.4, Aug 01, 2020
# [0]PETSC ERROR: ../matlab_ls_test on a linux-opt named MB108SMEC028 by
vit Sat Sep  2 12:27:22 2023
# [0]PETSC ERROR: Configure options
--with-mpi-dir=/home/vit/sfw/linux/openmpi/4.1.4 COPTFLAGS=-O3
CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=linux-opt --with-debugging=0
--with-x=0 --with-matlab-dir=/usr/local/MATLAB/R2020b
--with-matlab-engine=1 --with-blaslapack-dir=/usr/local/MATLAB/R2020b
--known-64-bit-blas-indices=1
# [0]PETSC ERROR: #1 PetscMatlabEngineCreate() line 67 in
/home/vit/sfw/petsc/3.13.4/src/sys/classes/matlabengine/matlab.c
# [0]PETSC ERROR: #2 main() line 126 in
/home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c
# [0]PETSC ERROR: PETSc Option Table entries:
# [0]PETSC ERROR: -prob_id 5
# [0]PETSC ERROR: -tao_smonitor
# [0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
# MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
# with errorcode 126076.
# NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
# You may or may not see output from other processes, depending on
# exactly when Open MPI kills them.
I request you to help me to sort out this error.
Thanks
Srinivas
On Fri, Sep 1, 2023 at 11:42 PM Amneet Bhalla <mail2amneet at gmail.com> wrote:
> I think there should be two hyphens in
> i.e.:
> On Fri, Sep 1, 2023 at 10:25 AM INTURU SRINIVAS 20PHD0548 via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Thank you Sathish.I will try this
>> On Fri, Sep 1, 2023, 22:53 Satish Balay <balay at mcs.anl.gov> wrote:
>>> yes [and remove fblaslapack. don't know if hypre will work here].
>>> i.e:
>>> ./configure --with-mpi-dir=/home/vit/sfw/linux/openmpi/4.1.4
>>> COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=linux-opt
>>> --with-debugging=0 --with-x=0 \
>>> --with-matlab-dir=/usr/local/MATLAB/R2020b --with-matlab-engine=1
>>> -with-blaslapack-dir=/usr/local/MATLAB/R2020b --known-64-bit-blas-indices=1
>>> Satish
>>> On Fri, 1 Sep 2023, INTURU SRINIVAS 20PHD0548 via petsc-users wrote:
>>> > Hi Satish,
>>> > -with-blaslapack-dir=/path/to/matlab_dir
>>> > Is this what you are suggesting?
>>> > On Fri, Sep 1, 2023, 20:42 Satish Balay <balay at mcs.anl.gov> wrote:
>>> > > Also:
>>> > >     '-known-64-bit-blas-indices=1',
>>> > > Note: most externalpackages might not work in this mode.
>>> > > [we can't really over come such dependency/conflicts across packages]
>>> > > Satish
>>> > > On Fri, 1 Sep 2023, Satish Balay via petsc-users wrote:
>>> > > > Here is the matlab test that runs in CI
>>> > > > https://gitlab.com/petsc/petsc/-/jobs/4904566768
>>> > > > config/examples/arch-ci-linux-matlab-ilp64.py
>>> > > > # Note: regular BLAS [with 32-bit integers] conflict with
>>> > > > # MATLAB BLAS - hence requiring -known-64-bit-blas-indices=1
>>> > > > Ah - so you need to use the ilp64 blas/lapack with matlab  - to
>>> have a
>>> > > compatible build
>>> > > >     '--with-blaslapack-dir='+matlab_dir,
>>> > > > Satish
>>> wrote:
>>> > > > > Hi Amneet,
>>> > > > > Without libmesh, even for PETSc with MATLAB is not working. It is
>>> > > showing
>>> > > > > error for both 3.13.4 and 3.17.5 versions.
>>> > > > > I am trying to install IBAMR in HPC cluster with libmesh and
>>> this is
>>> > > for
>>> > > > > general usage not only for WEC. This I tried without linking
>>> Matlab
>>> > > with
>>> > > > > PETSc. Here also I got the error while configuring libmesh 1.6.2
>>> that
>>> > > PETSc
>>> > > > > was not found but --enable-petsc-required is specified.
>>> > > > > The reason for specifically asking for libmesh with PETSc and
>>> Matlab
>>> > > is in
>>> > > > > the cfd-mpc-wecs application for complicated geometries it is
>>> > > mentioned to
>>> > > > > build cfd-mpc-wecs with libmesh construct.
>>> > > > > For the past 10 days I am trying these various things and ended
>>> up with
>>> > > > > errors.
>>> > > > > I want to solve this and proceed further to do my research work.
>>> > > > > Please help me to solve this as soon as possible.
>>> > > > > Thanks and Regards
>>> > > > > Srinivas
>>> > > > > On Fri, Sep 1, 2023, 19:48 Amneet Bhalla <mail2amneet at gmail.com>
>>> > > wrote:
>>> > > > > > Hi Srinivas,
>>> > > > > > As discussed earlier you don’t need libMesh for the WEC
>>> application.
>>> > > You
>>> > > > > > can just work with PETSc 3.17.5 that builds with Matlab.
>>> > > > > > Do you have a specific reason for wanting to build libMesh?
>>> > > > > > Thanks,
>>> > > > > > —Amneet
>>> > > > > > On Thu, Aug 31, 2023 at 10:16 PM INTURU SRINIVAS 20PHD0548 via
>>> > > petsc-users
>>> > > > > > <petsc-users at mcs.anl.gov> wrote:
>>> > > > > >> Hi,
>>> > > > > >> I ran "make all" for petsc 3.13.4 by removing all occurrences
>>> of
>>> > > "-lut
>>> > > > > >> -licudata -licui18n -licuuc". When I ran "make test" got the
>>> > > following
>>> > > > > >> errors
>>> > > > > >> in petsc/3.13.4/linux-debug:
>>> > > > > >> TEST
>>> linux-debug/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
>>> Error
>>> > > code: 124
>>> > > > > >> # Running problem 5
>>> > > > > >> https://www.mcs.anl.gov/petsc/documentation/faq.html for
>>> trouble
>>> > > > > >> shooting.
>>> > > > > >> # [0]PETSC ERROR: ../matlab_ls_test on a linux-debug named
>>> > > MB108SMEC028
>>> > > > > >> by vit Fri Sep  1 10:01:11 2023
>>> > > > > >> --CC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc
>>> > > > > >> --CXX=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicxx
>>> > > > > >> --FC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpif90
>>> --with-debugging=1
>>> > > > > >> --download-hypre=1 --download-fblaslapack=1 --with-x=0
>>> > > > > >> --with-matlab-dir=/usr/local/MATLAB/R2020b/
>>> --with-matlab-engine-dir=/usr/local/MATLAB/R2020b/extern/engines/
>>> -------send
>>> > > entire
>>> MPI_COMM_SELF
>>> > > processes.
>>> depending on
>>> > > > > >>  ok tao_leastsquares_tutorials_matlab-matlab_ls_test # SKIP
>>> Command
>>> > > > > >> failed so no diff
>>> > > > > >> in petsc/3.13.4/linux-opt
>>> > > > > >>  TEST
>>> linux-opt/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
>>> Error
>>> > > code: 124
>>> > > > > >> # Running problem 5
>>> trouble
>>> > > > > >> shooting.
>>> > > MB108SMEC028 by
>>> > > > > >> vit Fri Sep  1 10:34:12 2023
>>> --COPTFLAGS=-O3
>>> > > > > >> --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --PETSC_ARCH=linux-opt
>>> > > --with-debugging=0
>>> > > > > >> --download-hypre=1 --with-x=0 --download-fblaslapack=1
>>> -------send
>>> > > entire
>>> MPI_COMM_SELF
>>> > > processes.
>>> depending on
>>> Command
>>> > > > > >> failed so no diff.
>>> > > > > >> The same errors occurred for petsc 3.17.5 version. I am
>>> sharing the
>>> > > > > >> config.log and make.log for both petsc 3.13.4 and petsc
>>> 3.17.5.
>>> > > Please find
>>> > > > > >> the attachment and do the needful.
>>> > > > > >> Thanks and regards
>>> > > > > >> Srinivas
>>> > > > > >> On Tue, Aug 29, 2023 at 10:56 PM Satish Balay <
>>> > > wrote:
>>> > > > > >>> Well - you sent in libmesh log not petsc's
>>> configure.log/make.log
>>> > > for
>>> > > > > >>> petsc-3.17
>>> > > > > >>> Anyway - with petsc-3.13 - you have:
>>> > > > > >>> Matlab:
>>> > > > > >>>   Includes: -I/usr/local/MATLAB/R2020b/extern/include
>>> > > > > >>> MatlabEngine:
>>> > > > > >>>   Library:
>>> -Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64:/usr/local/MATLAB/R2020b/bin/glnxa64:/usr/local/MATLAB/R2020b/extern/lib/glnxa64
>>> > > > > >>> -L/usr/local/MATLAB/R2020b/bin/glnxa64
>>> > > > > >>> -L/usr/local/MATLAB/R2020b/extern/lib/glnxa64 -leng -lmex
>>> -lmx
>>> > > -lmat -lut
>>> > > > > >>>   Language used to compile PETSc: C
>>> > > > > >>> With petsc-3.19 (and matlab-R2022a) - we are seeing:
>>> > > > > >>> Matlab:
>>> > > > > >>>   Includes:
>>> -I/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/extern/include
>>> > > > > >>>   Libraries:
>>> -Wl,-rpath,/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
>>> -L/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
>>> > > > > >>> -leng -lmex -lmx -lmat
>>> > > > > >>>   Executable:
>>> > > > > >>>   mex:
>>> /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/mex
>>> > > > > >>>   matlab:
>>> /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/matlab
>>> > > > > >>> -glnxa64
>>> > > > > >>> I.e "-lut -licudata -licui18n -licuuc" are not preset here.
>>> This
>>> > > might
>>> > > > > >>> be a change wrt newer matlab versions.
>>> > > > > >>> You can:
>>> > > > > >>> - edit
>>> /home/vit/sfw/petsc/3.13.4/linux-opt/lib/petsc/conf/petscvariables
>>> > > and
>>> > > > > >>> remove all occurrences of "-lut -licudata -licui18n -licuuc"
>>> > > > > >>> - now run 'make all' in '/home/vit/sfw/petsc/3.13.4'
>>> > > > > >>> And see if the build works now.
>>> > > > > >>> Satish
>>> > > > > >>> On Tue, 29 Aug 2023, INTURU SRINIVAS 20PHD0548 via
>>> petsc-users
>>> > > wrote:
>>> > > > > >>> > I am sharing the log files while building petsc3.13.4 with
>>> > > matlab and
>>> > > > > >>> also
>>> > > > > >>> > the log file while building libmesh with petsc3.17.5 and
>>> matlab.
>>> > > > > >>> Building
>>> > > > > >>> > petsc 3.17.5 with matlab was done successfully. But
>>> libmesh is
>>> > > not
>>> > > > > >>> able to
>>> > > > > >>> > find the petsc
>>> > > > > >>> > Please find the attachments.
>>> > > > > >>> > On Tue, Aug 29, 2023 at 7:31 PM Satish Balay <
>>> > > > > >>> wrote:
>>> > > > > >>> > > Send configure.log, make.log from both petsc-3.13 and
>>> 3.17 [or
>>> > > 3.19].
>>> > > > > >>> > > [you can gzip them to make the logs friendly to mailing
>>> list -
>>> > > or
>>> > > > > >>> send
>>> > > > > >>> > > them to petsc-maint]
>>> > > > > >>> > > And does test suite work with 3.17? [or 3.19?]
>>> > > > > >>> > > Satish
>>> petsc-users
>>> > > wrote:
>>> > > > > >>> > > > I am sharing the make.log file while building
>>> petsc-3.13.4
>>> > > with
>>> > > > > >>> Matlab.
>>> > > > > >>> > > > Please find the attachment and do the needful.
>>> > > > > >>> > > > On Tue, Aug 29, 2023 at 10:19 AM INTURU SRINIVAS
>>> 20PHD0548 <
>>> > > > > >>> > > > inturu.srinivas2020 at vitstudent.ac.in> wrote:
>>> > > > > >>> > > > > I tried with petsc-3.17.5. During building of
>>> libmesh, the
>>> > > error
>>> > > > > >>> shows
>>> > > > > >>> > > > > petsc was not found
>>> > > > > >>> > > > > On Mon, Aug 28, 2023 at 9:43 PM Satish Balay <
>>> > > > > >>> > > wrote:
>>> > > > > >>> > > > >> https://ibamr.github.io/linux says petsc-3.17
>>> > > > > >>> > > > >> Here you are using 3.13
>>> > > > > >>> > > > >> Can you retry with petsc-3.17.5?
>>> > > > > >>> > > > >> Satish
>>> > > > > >>> > > > >> On Mon, 28 Aug 2023, INTURU SRINIVAS 20PHD0548 via
>>> > > petsc-users
>>> > > > > >>> wrote:
>>> > > > > >>> > > > >> > Hello,
>>> > > > > >>> > > > >> > I want to build PETSc with MATLAB for working on
>>> the
>>> > > > > >>> simulation
>>> > > > > >>> > > using
>>> > > > > >>> > > > >> IBAMR
>>> > > > > >>> > > > >> > open software. While building the PETSc, using the
>>> > > following
>>> > > > > >>> > > > >> > export PETSC_DIR=$PWD
>>> > > > > >>> > > > >> > export PETSC_ARCH=linux-debug
>>> > > > > >>> > > > >> > ./configure \
>>> > > > > >>> > > > >> >   --CC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicc \
>>> > > > > >>> > > > >> >   --CXX=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicxx \
>>> > > > > >>> > > > >> >   --FC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpif90 \
>>> > > > > >>> > > > >> >   --with-debugging=1 \
>>> > > > > >>> > > > >> >   --download-hypre=1 \
>>> > > > > >>> > > > >> >   --download-fblaslapack=1 \
>>> > > > > >>> > > > >> >   --with-x=0 \
>>> > > > > >>> > > > >> > make -j4
>>> > > > > >>> > > > >> > make -j4 test
>>> > > > > >>> > > > >> > I got the following error
>>> > > > > >>> > > > >> > CLINKER
>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o: in
>>> > > > > >>> > > > >> > function `EvaluateResidual':
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:32:
>>> > > > > >>> > > > >> > undefined reference to `PetscMatlabEnginePut'
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:33:
>>> > > > > >>> > > > >> > undefined reference to `PetscMatlabEngineEvaluate'
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:35:
>>> > > > > >>> > > > >> > undefined reference to `PetscMatlabEngineGet'
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> > > > > >>> > > > >> > function `EvaluateJacobian':
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:46:
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:47:
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:49:
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> > > > > >>> > > > >> > function `TaoPounders':
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:75:
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> > > > > >>> > > > >> > function `main':
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:126:
>>> > > > > >>> > > > >> > undefined reference to `PetscMatlabEngineCreate'
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:127:
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:139:
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:140:
>>> > > > > >>> > > > >> > undefined reference to `PetscMatlabEngineGetArray'
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:142:
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:144:
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:146:
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:148:
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:154:
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:157:
>>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:158:
>>> > > > > >>> > > > >> > undefined reference to `PetscMatlabEngineDestroy'
>>> > > > > >>> > > > >> > collect2: error: ld returned 1 exit status
>>> > > > > >>> > > > >> > make: *** [gmakefile.test:185:
>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test]
>>> > > > > >>> > > > >> Error 1
>>> > > > > >>> > > > >> > make: *** Waiting for unfinished jobs....
>>> > > > > >>> > > > >> > Please help me to solve this issue
>>> > > > > >>> > > > >> > Thank you
>>> > > > > >>> > > > >> > Srinivas
>>> > > > > >> *Disclaimer:This message was sent from Vellore Institute of
>>> > > Technology.
>>> > > > > >> The contents of this email may contain legally protected
>>> > > confidential or
>>> > > > > >> privileged information of “Vellore Institute of Technology”.
>>> If
>>> > > you are
>>> > > > > >> not the intended recipient, you should not disseminate,
>>> distribute
>>> > > or copy
>>> > > > > >> this e-mail. Please notify the sender immediately and destroy
>>> all
>>> > > copies of
>>> > > > > >> this message and any attachments. If you have received this
>>> email
>>> > > in error,
>>> > > > > >> please promptly notify the sender by reply email and delete
>>> the
>>> > > original
>>> > > > > >> email and any backup copies without reading them.*
>> *Disclaimer:This message was sent from Vellore Institute of Technology.
>> The contents of this email may contain legally protected confidential or
>> privileged information of “Vellore Institute of Technology”.  If you are
>> not the intended recipient, you should not disseminate, distribute or copy
>> this e-mail. Please notify the sender immediately and destroy all copies of
>> this message and any attachments. If you have received this email in error,
>> please promptly notify the sender by reply email and delete the original
> --Amneet
**Disclaimer:*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230902/673023bc/attachment-0001.html>
