[petsc-users] Error while building PETSc with MATLAB
INTURU SRINIVAS 20PHD0548 inturu.srinivas2020 at vitstudent.ac.in
Fri Sep 1 12:25:10 CDT 2023
Thank you Sathish.I will try this
On Fri, Sep 1, 2023, 22:53 Satish Balay <balay at mcs.anl.gov> wrote:
> yes [and remove fblaslapack. don't know if hypre will work here].
> i.e:
> ./configure --with-mpi-dir=/home/vit/sfw/linux/openmpi/4.1.4 COPTFLAGS=-O3
> CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=linux-opt --with-debugging=0
> --with-x=0 \
> --with-matlab-dir=/usr/local/MATLAB/R2020b --with-matlab-engine=1
> -with-blaslapack-dir=/usr/local/MATLAB/R2020b --known-64-bit-blas-indices=1
> Satish
> On Fri, 1 Sep 2023, INTURU SRINIVAS 20PHD0548 via petsc-users wrote:
> > Hi Satish,
> > -with-blaslapack-dir=/path/to/matlab_dir
> > Is this what you are suggesting?
> > On Fri, Sep 1, 2023, 20:42 Satish Balay <balay at mcs.anl.gov> wrote:
> > > Also:
> > >     '-known-64-bit-blas-indices=1',
> > > Note: most externalpackages might not work in this mode.
> > > [we can't really over come such dependency/conflicts across packages]
> > > Satish
> > > On Fri, 1 Sep 2023, Satish Balay via petsc-users wrote:
> > > > Here is the matlab test that runs in CI
> > > > https://gitlab.com/petsc/petsc/-/jobs/4904566768
> > > > config/examples/arch-ci-linux-matlab-ilp64.py
> > > > # Note: regular BLAS [with 32-bit integers] conflict with
> > > > # MATLAB BLAS - hence requiring -known-64-bit-blas-indices=1
> > > > Ah - so you need to use the ilp64 blas/lapack with matlab  - to have
> a
> > > compatible build
> > > >     '--with-blaslapack-dir='+matlab_dir,
> > > > Satish
> > > > > Hi Amneet,
> > > > > Without libmesh, even for PETSc with MATLAB is not working. It is
> > > showing
> > > > > error for both 3.13.4 and 3.17.5 versions.
> > > > > I am trying to install IBAMR in HPC cluster with libmesh and this
> is
> > > for
> > > > > general usage not only for WEC. This I tried without linking Matlab
> > > with
> > > > > PETSc. Here also I got the error while configuring libmesh 1.6.2
> that
> > > PETSc
> > > > > was not found but --enable-petsc-required is specified.
> > > > > The reason for specifically asking for libmesh with PETSc and
> Matlab
> > > is in
> > > > > the cfd-mpc-wecs application for complicated geometries it is
> > > mentioned to
> > > > > build cfd-mpc-wecs with libmesh construct.
> > > > > For the past 10 days I am trying these various things and ended up
> with
> > > > > errors.
> > > > > I want to solve this and proceed further to do my research work.
> > > > > Please help me to solve this as soon as possible.
> > > > > Thanks and Regards
> > > > > Srinivas
> > > > > On Fri, Sep 1, 2023, 19:48 Amneet Bhalla <mail2amneet at gmail.com>
> > > wrote:
> > > > > > Hi Srinivas,
> > > > > > As discussed earlier you don’t need libMesh for the WEC
> application.
> > > You
> > > > > > can just work with PETSc 3.17.5 that builds with Matlab.
> > > > > > Do you have a specific reason for wanting to build libMesh?
> > > > > > Thanks,
> > > > > > —Amneet
> > > > > > On Thu, Aug 31, 2023 at 10:16 PM INTURU SRINIVAS 20PHD0548 via
> > > petsc-users
> > > > > > <petsc-users at mcs.anl.gov> wrote:
> > > > > >> Hi,
> > > > > >> I ran "make all" for petsc 3.13.4 by removing all occurrences of
> > > "-lut
> > > > > >> -licudata -licui18n -licuuc". When I ran "make test" got the
> > > following
> > > > > >> errors
> > > > > >> in petsc/3.13.4/linux-debug:
> > > > > >> TEST
> linux-debug/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
> > > > > >> not ok tao_leastsquares_tutorials_matlab-matlab_ls_test # Error
> > > code: 124
> > > > > >> # Running problem 5
> > > > > >> # [0]PETSC ERROR: --------------------- Error Message
> > > > > >> # [0]PETSC ERROR: Error in external library
> > > > > >> # [0]PETSC ERROR: Unable to start MATLAB engine on
> > > > > >> # [0]PETSC ERROR: See
> > > > > >> https://www.mcs.anl.gov/petsc/documentation/faq.html for
> trouble
> > > > > >> shooting.
> > > > > >> # [0]PETSC ERROR: Petsc Release Version 3.13.4, Aug 01, 2020
> > > > > >> # [0]PETSC ERROR: ../matlab_ls_test on a linux-debug named
> > > MB108SMEC028
> > > > > >> by vit Fri Sep  1 10:01:11 2023
> > > > > >> # [0]PETSC ERROR: Configure options
> > > > > >> --CC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc
> > > > > >> --CXX=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicxx
> > > > > >> --FC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpif90
> --with-debugging=1
> > > > > >> --download-hypre=1 --download-fblaslapack=1 --with-x=0
> > > > > >> --with-matlab-dir=/usr/local/MATLAB/R2020b/
> --with-matlab-engine-dir=/usr/local/MATLAB/R2020b/extern/engines/
> > > > > >> # [0]PETSC ERROR: #1 PetscMatlabEngineCreate() line 67 in
> > > > > >> /home/vit/sfw/petsc/3.13.4/src/sys/classes/matlabengine/matlab.c
> > > > > >> # [0]PETSC ERROR: #2 main() line 126 in
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c
> > > > > >> # [0]PETSC ERROR: PETSc Option Table entries:
> > > > > >> # [0]PETSC ERROR: -prob_id 5
> > > > > >> # [0]PETSC ERROR: -tao_smonitor
> > > > > >> # [0]PETSC ERROR: ----------------End of Error Message
> -------send
> > > entire
> > > > > >> error message to petsc-maint at mcs.anl.gov----------
> > > > > >> # MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
> > > > > >> # with errorcode 126076.
> > > > > >> # NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI
> > > processes.
> > > > > >> # You may or may not see output from other processes, depending
> on
> > > > > >> # exactly when Open MPI kills them.
> > > > > >>  ok tao_leastsquares_tutorials_matlab-matlab_ls_test # SKIP
> Command
> > > > > >> failed so no diff
> > > > > >> in petsc/3.13.4/linux-opt
> > > > > >>  TEST
> linux-opt/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
> > > code: 124
> > > > > >> # Running problem 5
> trouble
> > > > > >> shooting.
> > > > > >> # [0]PETSC ERROR: ../matlab_ls_test on a linux-opt named
> > > MB108SMEC028 by
> > > > > >> vit Fri Sep  1 10:34:12 2023
> --COPTFLAGS=-O3
> > > > > >> --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --PETSC_ARCH=linux-opt
> > > --with-debugging=0
> > > > > >> --download-hypre=1 --with-x=0 --download-fblaslapack=1
> -------send
> > > entire
> > > processes.
> on
> Command
> > > > > >> failed so no diff.
> > > > > >> The same errors occurred for petsc 3.17.5 version. I am sharing
> the
> > > > > >> config.log and make.log for both petsc 3.13.4 and petsc 3.17.5.
> > > Please find
> > > > > >> the attachment and do the needful.
> > > > > >> Thanks and regards
> > > > > >> Srinivas
> > > > > >> On Tue, Aug 29, 2023 at 10:56 PM Satish Balay <
> > > wrote:
> > > > > >>> Well - you sent in libmesh log not petsc's
> configure.log/make.log
> > > for
> > > > > >>> petsc-3.17
> > > > > >>> Anyway - with petsc-3.13 - you have:
> > > > > >>> Matlab:
> > > > > >>>   Includes: -I/usr/local/MATLAB/R2020b/extern/include
> > > > > >>> MatlabEngine:
> > > > > >>>   Library:
> -Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64:/usr/local/MATLAB/R2020b/bin/glnxa64:/usr/local/MATLAB/R2020b/extern/lib/glnxa64
> > > > > >>> -L/usr/local/MATLAB/R2020b/bin/glnxa64
> > > > > >>> -L/usr/local/MATLAB/R2020b/extern/lib/glnxa64 -leng -lmex -lmx
> > > -lmat -lut
> > > > > >>>   Language used to compile PETSc: C
> > > > > >>> With petsc-3.19 (and matlab-R2022a) - we are seeing:
> > > > > >>> Matlab:
> > > > > >>>   Includes:
> -I/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/extern/include
> > > > > >>>   Libraries:
> -Wl,-rpath,/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
> -L/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
> > > > > >>> -leng -lmex -lmx -lmat
> > > > > >>>   Executable:
> > > > > >>>   mex:
> > > /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/mex
> > > > > >>>   matlab:
> /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/matlab
> > > > > >>> -glnxa64
> > > > > >>> I.e "-lut -licudata -licui18n -licuuc" are not preset here.
> This
> > > might
> > > > > >>> be a change wrt newer matlab versions.
> > > > > >>> You can:
> > > > > >>> - edit
> /home/vit/sfw/petsc/3.13.4/linux-opt/lib/petsc/conf/petscvariables
> > > and
> > > > > >>> remove all occurrences of "-lut -licudata -licui18n -licuuc"
> > > > > >>> - now run 'make all' in '/home/vit/sfw/petsc/3.13.4'
> > > > > >>> And see if the build works now.
> > > > > >>> Satish
> > > > > >>> On Tue, 29 Aug 2023, INTURU SRINIVAS 20PHD0548 via petsc-users
> > > wrote:
> > > > > >>> > I am sharing the log files while building petsc3.13.4 with
> > > matlab and
> > > > > >>> also
> > > > > >>> > the log file while building libmesh with petsc3.17.5 and
> matlab.
> > > > > >>> Building
> > > > > >>> > petsc 3.17.5 with matlab was done successfully. But libmesh
> is
> > > not
> > > > > >>> able to
> > > > > >>> > find the petsc
> > > > > >>> > Please find the attachments.
> > > > > >>> > On Tue, Aug 29, 2023 at 7:31 PM Satish Balay <
> > > > > >>> wrote:
> > > > > >>> > > Send configure.log, make.log from both petsc-3.13 and 3.17
> [or
> > > 3.19].
> > > > > >>> > > [you can gzip them to make the logs friendly to mailing
> list -
> > > or
> > > > > >>> send
> > > > > >>> > > them to petsc-maint]
> > > > > >>> > > And does test suite work with 3.17? [or 3.19?]
> > > > > >>> > > Satish
> petsc-users
> > > wrote:
> > > > > >>> > > > I am sharing the make.log file while building
> petsc-3.13.4
> > > with
> > > > > >>> Matlab.
> > > > > >>> > > > Please find the attachment and do the needful.
> > > > > >>> > > > On Tue, Aug 29, 2023 at 10:19 AM INTURU SRINIVAS
> 20PHD0548 <
> > > > > >>> > > > inturu.srinivas2020 at vitstudent.ac.in> wrote:
> > > > > >>> > > > > I tried with petsc-3.17.5. During building of libmesh,
> the
> > > error
> > > > > >>> shows
> > > > > >>> > > > > petsc was not found
> > > > > >>> > > > > On Mon, Aug 28, 2023 at 9:43 PM Satish Balay <
> > > > > >>> > > wrote:
> > > > > >>> > > > >> https://ibamr.github.io/linux says petsc-3.17
> > > > > >>> > > > >> Here you are using 3.13
> > > > > >>> > > > >> Can you retry with petsc-3.17.5?
> > > > > >>> > > > >> Satish
> > > > > >>> > > > >> On Mon, 28 Aug 2023, INTURU SRINIVAS 20PHD0548 via
> > > petsc-users
> > > > > >>> wrote:
> > > > > >>> > > > >> > Hello,
> > > > > >>> > > > >> > I want to build PETSc with MATLAB for working on the
> > > > > >>> simulation
> > > > > >>> > > using
> > > > > >>> > > > >> IBAMR
> > > > > >>> > > > >> > open software. While building the PETSc, using the
> > > following
> > > > > >>> > > > >> > export PETSC_DIR=$PWD
> > > > > >>> > > > >> > export PETSC_ARCH=linux-debug
> > > > > >>> > > > >> > ./configure \
> > > > > >>> > > > >> >   --CC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicc \
> > > > > >>> > > > >> >   --CXX=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicxx \
> > > > > >>> > > > >> >   --FC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpif90 \
> > > > > >>> > > > >> >   --with-debugging=1 \
> > > > > >>> > > > >> >   --download-hypre=1 \
> > > > > >>> > > > >> >   --download-fblaslapack=1 \
> > > > > >>> > > > >> >   --with-x=0 \
> > > > > >>> > > > >> > make -j4
> > > > > >>> > > > >> > make -j4 test
> > > > > >>> > > > >> > I got the following error
> > > > > >>> > > > >> > CLINKER
> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test
> > > > > >>> > > > >> > /usr/bin/ld:
> > > linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o:
> in
> > > > > >>> > > > >> > function `EvaluateResidual':
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:32:
> > > > > >>> > > > >> > undefined reference to `PetscMatlabEnginePut'
> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:33:
> > > > > >>> > > > >> > undefined reference to `PetscMatlabEngineEvaluate'
> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:35:
> > > > > >>> > > > >> > undefined reference to `PetscMatlabEngineGet'
> > > > > >>> > > > >> > /usr/bin/ld:
> in
> > > > > >>> > > > >> > function `EvaluateJacobian':
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:46:
> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:47:
> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:49:
> > > > > >>> > > > >> > /usr/bin/ld:
> in
> > > > > >>> > > > >> > function `TaoPounders':
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:75:
> > > > > >>> > > > >> > /usr/bin/ld:
> in
> > > > > >>> > > > >> > function `main':
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:126:
> > > > > >>> > > > >> > undefined reference to `PetscMatlabEngineCreate'
> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:127:
> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:139:
> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:140:
> > > > > >>> > > > >> > undefined reference to `PetscMatlabEngineGetArray'
> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:142:
> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:144:
> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:146:
> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:148:
> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:154:
> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:157:
> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:158:
> > > > > >>> > > > >> > undefined reference to `PetscMatlabEngineDestroy'
> > > > > >>> > > > >> > collect2: error: ld returned 1 exit status
> > > > > >>> > > > >> > make: *** [gmakefile.test:185:
> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test]
> > > > > >>> > > > >> Error 1
> > > > > >>> > > > >> > make: *** Waiting for unfinished jobs....
> > > > > >>> > > > >> > Please help me to solve this issue
> > > > > >>> > > > >> > Thank you
> > > > > >>> > > > >> > Srinivas
> > > > > >> *Disclaimer:This message was sent from Vellore Institute of
> > > Technology.
> > > > > >> The contents of this email may contain legally protected
> > > confidential or
> > > > > >> privileged information of “Vellore Institute of Technology”.  If
> > > you are
> > > > > >> not the intended recipient, you should not disseminate,
> distribute
> > > or copy
> > > > > >> this e-mail. Please notify the sender immediately and destroy
> all
> > > copies of
> > > > > >> this message and any attachments. If you have received this
> email
> > > in error,
> > > > > >> please promptly notify the sender by reply email and delete the
> > > original
> > > > > >> email and any backup copies without reading them.*
**Disclaimer:*
This message was sent from Vellore Institute of Technology.
The contents of this email may contain legally protected confidential or
privileged information of “Vellore Institute of Technology”.  If you are
not the intended recipient, you should not disseminate, distribute or copy
this e-mail. Please notify the sender immediately and destroy all copies of
this message and any attachments. If you have received this email in error,
please promptly notify the sender by reply email and delete the original
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230901/21c95d26/attachment-0001.html>
