[petsc-users] Using Sundials from PETSc
Mon Oct 16 15:31:14 CDT 2023
On Mon, Oct 16, 2023 at 4:08 PM Vanella, Marcos (Fed) <
marcos.vanella at nist.gov> wrote:
> Hi Mathew, we have code that time splits the combustion step from the
> chemical species transport, so on each computational cell for each fluid
> flow time step, once transport is done we have the mixture chemical
> composition as initial condition. We are looking into doing finite rate
> chemistry with skeletal combustion models (20+ equations) in each cell for
> each fluid time step. Sundials provides the CVODE solver for the time
> integration of these, and would be interesting to see if we can make use of
> GPU acceleration. From their User Guide for Version 6.6.0 there are several
> GPU implementations for building RHS and using linear, nonlinear and stiff
> ODE solvers.
We are doing a similar thing in CHREST (https://www.buffalo.edu/chrest.html).
Since we normally use hundreds of species and thousands of reactions for
the reduced mechanism, we are using TChem2 to build and solve the system in
each cell.
Since these systems are so small, you are likely to need some way of
batching them within a warp. Do you have an idea for this already?
     Matt
> Thank you Satish for the comment. Might be better at this point to first
> get an idea on what the implementation in our code using Sundials directly
> would look like. Then, we can see if it is possible and makes sense to
> access it through PETSc.
> We have things working in CPU making use of and older version of CVODE.
> BTW after some changes in our code we are starting running larger cases
> using GPU accelerated iterative solvers from PETSc, so we have PETSc
> interfaced already.
> Thanks!
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Monday, October 16, 2023 3:03 PM
> *To:* Vanella, Marcos (Fed) <marcos.vanella at nist.gov>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; Paul, Chandan
> (IntlAssoc) <chandan.paul at nist.gov>
> *Subject:* Re: [petsc-users] Using Sundials from PETSc
> On Mon, Oct 16, 2023 at 2:29 PM Vanella, Marcos (Fed) via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Hi, we were wondering if it would be possible to call the latest version
> of Sundials from PETSc?
> The short answer is, no. We are at v2.5 and they are at v6.5. There were
> no dates on the version history page, so I do not know how out of date we
> are. There have not been any requests for update until now.
> We would be happy to get an MR for the updates if you want to try it.
> We are interested in doing chemistry using GPUs and already have
> interfaces to PETSc from our code.
> How does the GPU interest interact with the SUNDIALS version?
>   Thanks,
>      Matt
> Thanks,
> Marcos
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231016/382304f9/attachment.html>
